terboggs Posted November 14 Share Posted November 14 I own a 2001 Monoco Exec and my toilet water is now overflowing. What could cause that, I tried to do a search for this topic. And what kind of Toliet would that model have. Terrence Boggs Swimming in Water Link to comment Share on other sites More sharing options...
DavidL Posted November 14 Share Posted November 14 Without knowing anything about the specific toilet...is it overflowing because the flush water isn't shutting off? And eventually it does? And the toilet is flushing fine? For example, on my most recent RV trip, my son complained that the toilet was overfilling. Further examination showed that in actuality it wasnt' flushing and he kept pushing the flush / fill button which then filled it up. The flush blade was sticking from non use. Once the flush blade was coaxed to move, all was fine again an no more toilet drama for the trip. Link to comment Share on other sites More sharing options...
Dr4Film Posted November 14 Share Posted November 14 A photo of the toilet would help to identify the model and brand. It's possible that it has the Sealand Magnum Opus toilet unless someone has replaced with something else. The Magnum Opus has a control board with a switch on it to choose three different levels of water that will fill the bowl. L/M/H. Possibly the control board has gone wonky. Link to comment Share on other sites More sharing options...
Fasthobie16 Posted November 14 Share Posted November 14 Try wiggling the foot peddle up and down. It should rest in the middle somewhere. If that doesn’t stop the problem you’ll have to replace the flush valve. Easy job. Just be sure you turn off t water pump 😎 . if you have a Dometic/Sealand toilet like I have in my 2000 Dynasty, there’s plenty of them on eBay and Amazon available .(get one that will fit your toilet model #). Mine took a part no. 385314349 . It fits several Sealand models . If I remember, mine is a model 501. YouTube has some good videos on replacing them . ( You don’t have to remove the toilet bowl for this job like you do to replace the flush seal .) When I replaced mine, I put a little dab of silicone grease on the top of the ball that rides on the foot leaver so it could move smoothly . Hope that helps you with the fix. Link to comment Share on other sites More sharing options...
Martinvz Posted November 14 Share Posted November 14 Use your cellphone camera to find the model number that can be on the side or even the back. It is often under a skirt, as in my toilet’s case, that you first need to remove to find the model. Then you can use that model to google the cause and find suitable parts. Link to comment Share on other sites More sharing options...
terboggs Posted November 14 Author Share Posted November 14 thank you ,looks like i need to use my camera first Link to comment Share on other sites More sharing options...
terboggs Posted November 15 Author Share Posted November 15 Which brand is this tolet. Oddly it stp stopped flooding for. a few hours and then started up last night, what would cause an off and on ? 22 hours ago, Dr4Film said: A photo of the toilet would help to identify the model and brand. It's possible that it has the Sealand Magnum Opus toilet unless someone has replaced with something else. The Magnum Opus has a control board with a switch on it to choose three different levels of water that will fill the bowl. L/M/H. Possibly the control board has gone wonky. Where would the control board be hidden/ Link to comment Share on other sites More sharing options...
Steven P Posted November 15 Share Posted November 15 I'm not familiar w that toilet but I'll try to help. It looks like a manual toilet, hence the foot pedal flusher. One time when mine did this I had an airlock from changing from onboard to city water. Once I shut the water off to the toilet and ran the water it worked itself out. However, in yours if it's doing this randomly, id think there is something wrong or worn in the foot lever mechanism. I'm not familiar enough with the internal mechanisms of these to offer much more help. There should be a water supply line behind the toilet w a valve you can shut off/on at least temporarily so u can use the toilet and stop the flooding while researching. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted November 15 Share Posted November 15 That is a china bowl manual toilet so there is no control board. Your problem is most likely in the foot control which dumps the bowl and adds water as long as you hold your foot on the pedal. Not sure what brand and model it is but hopefully someone with the same vintage coach may chime in with that information. The most popular brands for toilets are Thetford, Dometic and Sealand. Link to comment Share on other sites More sharing options...
Martinvz Posted November 15 Share Posted November 15 (edited) I had a leak in the inlet valve (different foot operated Thedford toilet) due to a crack and had to replace the valve. It can be done but my days of hugging the throne are long gone. So I ordered the new valve and then pulled the complete toilet and then rebuilt it in a much easier location. It provided the opportunity to clean where it had not and replace the seals. The job is not really difficult but the removal can be a little messy. Reinstalled after lubricating and since then no issues at all. These thrones do age and a one-time clean and lube may just be a good investment. Edited November 15 by Martinvz Link to comment Share on other sites More sharing options...
terboggs Posted November 15 Author Share Posted November 15 anyone know the model Link to comment Share on other sites More sharing options...
Tom Cherry Posted November 15 Share Posted November 15 13 minutes ago, terboggs said: anyone know the model Look on your BUILD SHEET. Mine has the Thetford 34425. It has a FILL or FLUSH valve and is a DROP IT DOWN unit and the wand for rinsing. It also comes in the ADA height. We replaced ours with the higher one a few years ago. The "flange" in the floor is universal and the "J Bolts" slide around so that any popular or commercial RV toilet will bolt down. You replace the Gas Seal. The water should hook up and work just fine. If your toilet (the name should be somewhere on the lid) is NOT working...as in the The Thetford will work there. NOW, I used Sealand Manual RV toilet....as Clement Clarke Moore said..."Paraphrasing"...What, to my wondering eyes should appear...but a Dometic (Sealand) Traveler 510 Plus..... https://www.aquastardistributors.com/product/dometic-traveler-510-plus-gravity-toilet/?gad_source=1&gclid=CjwKCAiA9dGqBhAqEiwAmRpTC91TJ8Rt3p3z4596Pfoe7r2bsMur-0oA0y0PIhU3x4i3vhmMWTAoVRoC22MQAvD_BwE You can order parts for it. You will probably have to remove it. So you need a New Gas Ring seal. You also OUGHT to replace the valve and O-Ring in the bowl... THEN of course a new flush valve. Dometic or Sealand will have parts....you can probably get a Bill or Materials online and find the parts. TYPICALLY, when you replace the lower (ball) seal and O-ring, they include a new Gas (wax) seal as well. Then just replace the entire flush valve. Call Dometic and they can help. Pulling the toilet is easy.. Two Nuts. Put some "towels around". Then move it to a work bench and fix it there.. I changed mine out in the parking lot of a CW in Knoxville, TN. Only needed a box wrench for the nuts. I also rebuilt it once after the valve had a leak. Easy to do on a workbench. That's about it. Link to comment Share on other sites More sharing options...
terboggs Posted November 15 Author Share Posted November 15 you are correct i have the sealand traveler yeh thank ou Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 15 Share Posted November 15 All the automatic things are fine until the auto leaves the mantic. I replaced mine with a manual toilet. One less thing to worry about for a full timer. Chuck B Link to comment Share on other sites More sharing options...
Solution Fasthobie16 Posted November 16 Solution Share Posted November 16 In my previous post I gave the flush valve part number for the model 501 toilet. Yours looks like mine. Part # 385314349 .Travler 501. Link to comment Share on other sites More sharing options...
