ido70 Posted December 16, 2023 Share Posted December 16, 2023 My 2004 Windsor is laid up in Houston with no 12v electrical getting to the coach. I am 6 hours away in Donna. The service shop I left it with for other work (now completed) has run into a wall. Can anyone recommend a Houston shop with lots of experience on old Monaco’s. It’s at RV Masters now but they are stumped. Link to comment Share on other sites More sharing options...
Donflem Posted December 16, 2023 Share Posted December 16, 2023 Is the salesman switch inside the door on? Link to comment Share on other sites More sharing options...
ido70 Posted December 16, 2023 Author Share Posted December 16, 2023 It has been disabled. Link to comment Share on other sites More sharing options...
Donflem Posted December 16, 2023 Share Posted December 16, 2023 🤔 Link to comment Share on other sites More sharing options...
jacwjames Posted December 16, 2023 Share Posted December 16, 2023 Battery disconnect switch, they fail internally. Check voltage on the battery side then the coach side. If bad they could connect the two leads together but then you won't be able to stop voltage draws. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 16, 2023 Share Posted December 16, 2023 Try PPL - https://www.pplmotorhomes.com/service-department Link to comment Share on other sites More sharing options...
Chargerman Posted December 16, 2023 Share Posted December 16, 2023 Did they have the coach plugged in? If not maybe the batteries have run down? Link to comment Share on other sites More sharing options...
donbouv22 Posted December 16, 2023 Share Posted December 16, 2023 If it’s a Cummins there is a Cummins shop in Houston. Link to comment Share on other sites More sharing options...
ido70 Posted December 16, 2023 Author Share Posted December 16, 2023 Not a motor problem, txs New batteries, new inverter/converter. RV ran over very rough ground and I am thinking a loose relay, fuse, wire somewhere but they cannot find it. Link to comment Share on other sites More sharing options...
Chargerman Posted December 17, 2023 Share Posted December 17, 2023 Breaker on converter? Link to comment Share on other sites More sharing options...
Dennis H Posted December 18, 2023 Share Posted December 18, 2023 Have you tried electrical with the generator running? Do you have power when plugged in? There is a fuse in the house battery compartment. Also the ground should be there. Start there with a meter to check battery output at the source. Check that ground lug then work outward.... PPL has an excellent repair shop, give them a call if you're unable/unsure of how to check things out yourself.....Dennis Link to comment Share on other sites More sharing options...
Solution ido70 Posted December 18, 2023 Author Solution Share Posted December 18, 2023 Good news all, RV fixed, tested and driven, ready to pickup. Not sure exactly what was cause (small circuit board inside front panel). We will return to Houston, pickup and continue North, homeward bound, mentally exhausted… will be selling this old girl this spring…we’re getting too old for this stress. Merry Christmas all! Link to comment Share on other sites More sharing options...
