dirtydeeds Posted July 14, 2021 Share Posted July 14, 2021 Here’s as much info as I can think of: When hooked to 110v shore power 20amp breaker, if I try to run two of the 3 roof top air conditioners, something ‘pops’. It’s not the inverter. It’s not the breaker for either A/c, it’s not the shore power breaker. The RV has an Intelletec panel which loses power completely. The display goes completely off. I can’t find where the breaker is to the panel. Even the owners manual doesn’t say anything. abybody have any experience with this? Link to comment Share on other sites More sharing options...
Just Jim Posted July 14, 2021 Share Posted July 14, 2021 You need much more than 20 amps to run 3 AC units. 1 Link to comment Share on other sites More sharing options...
Guest Jester1 Posted July 14, 2021 Share Posted July 14, 2021 Pretty sure you have to have 50 amps for these coaches. It is very hard on the transfer switch and inverter. Had to replace my inverter because I didn’t pay attention and plugged into a 30amp and tried it. Link to comment Share on other sites More sharing options...
willbo777 Posted July 14, 2021 Share Posted July 14, 2021 I doubt you could run 1 AC on 20 amp, maybe if nothing else was on. 2 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 14, 2021 Share Posted July 14, 2021 You are doing good to run 1 roof air on 20 amps with nothing else being powered. Chuck B 2004 Windsor 1 Link to comment Share on other sites More sharing options...
Scotty Hutto Posted July 14, 2021 Share Posted July 14, 2021 The “pop” is the Intellitec system doing what it’s designed to do - manage the load. It has a relay at each AC unit and if the total coach power exceeds 20A (assuming you have it set to 20A and not the default 30A), it turns off one of the ACs to keep from overloading the shore power system. Even if set to 30A, it will likely shed load when the second AC comes on. Each AC unit typically uses about 14A, so just normal lights, etc, plus 1 AC unit will run on 20A, but add a second AC and you blow through both 20A and 30A, so it sheds load. The Intellitec is controlled by a board usually located in the breaker panel. Hope that’s helpful. 1 Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted July 14, 2021 Share Posted July 14, 2021 You also need to check to see if you have a Todd/Toddco black color power transfer switch. If you do, you need to unplug your coach from Any shore power. Monaco had a recall on that PTS because it will cause a fire in your coach. Since Monaco is no longer in business, the cost of replacement is on you. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
waterskier_1 Posted July 14, 2021 Share Posted July 14, 2021 2 hours ago, Jester1 said: Pretty sure you have to have 50 amps for these coaches. It is very hard on the transfer switch and inverter. Had to replace my inverter because I didn’t pay attention and plugged into a 30amp and tried it. Your inverter is not in the circuit (unless rewired) ought the A/Cs. The shore power goes through the transfer signal to the main breaker panel and then thru the individual circuit breaker for the A/C. You don't need an inverter for A/C. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 14, 2021 Share Posted July 14, 2021 (edited) When hooked to any shore power that is less than 30 amps, you need to push the button at the bottom of the Intellitec display that says "30/20 Select". Then you need to go to your Inverter Setup and choose the LOWEST setting for battery charge rate. This will allow the most use of the small amount of amps available to use inside the coach. However, even a 20 amp service will not allow you to use a full 20 amps. One AC will use over 15 amps to start up unless you have Soft Starts installed in your AC's and when running it should be about 13 amps. To run TWO AC's you need a minimum of 30 amps with Soft Starts installed. Edited July 14, 2021 by Dr4Film Link to comment Share on other sites More sharing options...
Rick A Posted July 14, 2021 Share Posted July 14, 2021 (edited) Pretty simple: 20 amps is barely enough to run a kettle. Trying to run 3 aircons on 20 amps is insane. A little basic electric knowledge is essential. There is a chart in the manual that explains this concept. Edited July 14, 2021 by Rick A 2 Link to comment Share on other sites More sharing options...
seadoo200hp Posted July 15, 2021 Share Posted July 15, 2021 You must like your inside ice cold.. I haven't seen a Diplomat of 2004 vintage with 3 roof A/C's. I know this modification can be done but the original system isn't set up for 3 roof A/C's. You need 50 Amps for 2 roof top A/C's to run full on. Link to comment Share on other sites More sharing options...
brokenarrow1244 Posted July 15, 2021 Share Posted July 15, 2021 Here is what my board looked like, I believe it was due to a power surge while using ac with gen start up. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted July 15, 2021 Share Posted July 15, 2021 1 hour ago, brokenarrow1244 said: Here is what my board looked like, I believe it was due to a power surge while using ac with gen start up. Yikes! That would cause a “pop” AND let the magic smoke out! Link to comment Share on other sites More sharing options...
Rick A Posted July 15, 2021 Share Posted July 15, 2021 Awh, that’s a sad picture! Link to comment Share on other sites More sharing options...
