Greg Carter Posted July 8, 2022 Share Posted July 8, 2022 I know this has been asked but thought I’d just check Has anyone found a compatable fuel filter that fits the old Wynn system used by Monaco Current filter is a Racor S3230P which allows the original lower water separator and switch to be used. While I found a Donaldson replacement it will not take the original lower bowl and water switch. Thank you __________________ 95 Dynasty 36 97 Dynasty 40 original to the family Link to comment Share on other sites More sharing options...
Old Dog Posted July 8, 2022 Share Posted July 8, 2022 Most of the major filter mfg web sites have a cross reference ability. I have found other brand filters for the Racor Primary that has the clear bowl and water sensor. Don't have access to the actual number right now. Sorry Link to comment Share on other sites More sharing options...
Just Jim Posted July 8, 2022 Share Posted July 8, 2022 I have not bought any in over a year as I usually buy several when I order them, but I've not had a problem getting them. My difficulty was the 300200 pre filter, which from time to time seems to be on back order. Again... I bought 5-6 of those last time. Link to comment Share on other sites More sharing options...
Doug and Nicki Posted July 8, 2022 Share Posted July 8, 2022 Go to NAPA. They matched mine to one of their brand. I just picked one up yesterday. Pricey at $65. My Racor number is different than yours, but they will be able to cross reference it. Link to comment Share on other sites More sharing options...
Just Jim Posted July 8, 2022 Share Posted July 8, 2022 https://www.mddistributorsstore.com/index.php?page=seek&id[m]=pattern&id[q]=S3230P This is where I buy mine. Link to comment Share on other sites More sharing options...
Specialk Posted July 8, 2022 Share Posted July 8, 2022 I believe Fleetguard “FS19592” is a direct replacement for this filter. Although, as others have mentioned you should be able to cross to several other manufacturers at the parts store. I currently use a Baldwin filter for this water separator filter, and get along fine. Link to comment Share on other sites More sharing options...
Greg Carter Posted July 8, 2022 Author Share Posted July 8, 2022 Thanks the very quick replies i should have added that we are in Canada. Jim Bob can you say where you found the pre filter? i thought those were long gone! certainly would be nice to find some as well. im going to try the Napa store as they are up here in Canada as well. so far the Donaldson was all my regular Lordco supplier could cross to but it’s not able to take the lower bowl for sure. thanks all Great source of info on this site that’s for certain. cheers te Link to comment Share on other sites More sharing options...
Just Jim Posted July 8, 2022 Share Posted July 8, 2022 MD Distributors has the 300200 as well. Link to comment Share on other sites More sharing options...
waterskier_1 Posted July 8, 2022 Share Posted July 8, 2022 This is the info I have from my 1997 C8.3 Mechanical Dynasty. Primary Fuel Filter: FS1295, FS20402 (20 micron), FS20401 (2 micron?), P552040 Secondary Fuel Filter: FS1251 -Rick N. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 8, 2022 Share Posted July 8, 2022 2 hours ago, Greg Carter said: I know this has been asked but thought I’d just check Has anyone found a compatible fuel filter that fits the old Wynn system used by Monaco Current filter is a Racor S3230P which allows the original lower water separator and switch to be used. While I found a Donaldson replacement it will not take the original lower bowl and water switch. Thank you __________________ 95 Dynasty 36 97 Dynasty 40 original to the family Are you sure about the Racor # you posted - S3230P? My Windsor with the ISC-350 used the Racor S3201T which has the lower collection bowl. Those are available on eBay and Dieselfiltersonline.com racor s3201t: Search Result | eBay [S3201T]Parker Racor ELEMENT- REPLACEMENT B32001T (dieselfiltersonline.com) If your Racor # is correct, then they are available on eBay. racor s3230p: Search Result | eBay Link to comment Share on other sites More sharing options...
Old Dog Posted July 8, 2022 Share Posted July 8, 2022 A replacement for my RACOR Primary w/ filter S3226P is a Baldwin BF1346-0. Not sue if you have the same Racor unit because of the different size engines. Hope this helps. Link to comment Share on other sites More sharing options...
Greg Carter Posted July 8, 2022 Author Share Posted July 8, 2022 Not sure if this was a update or not but certainly been working for years. thks Link to comment Share on other sites More sharing options...
Old Dog Posted July 8, 2022 Share Posted July 8, 2022 Hope this helps Link to comment Share on other sites More sharing options...
Greg Carter Posted July 8, 2022 Author Share Posted July 8, 2022 Starting to think that these filters are more readily available than I was told and that in some cases the different part numbers have a connection to the filters micron size so that 3201 seems to state 10 microns and the 3230 shows 30 microns. will see what I can come up with here in Canada. thks all. cheers Link to comment Share on other sites More sharing options...
Old Dog Posted July 8, 2022 Share Posted July 8, 2022 Racor is certainly not the only source but most likely the most expensive. Link to comment Share on other sites More sharing options...
Dr4Film Posted July 9, 2022 Share Posted July 9, 2022 (edited) I am picky when it comes to filters. There are some filter brands that I refuse to use. That's why I ALWAYS supply the filters to the shop that is doing my yearly service. I give them the spares that I have been carrying with me for emergencies and place the newest ones back into my filter storage compartment. I treat my engines with care as I know they are VERY expensive to repair or replace. On the Windsor I always used the Parker Racor Primary and a Fleetguard Secondary. The Dynasty will be needing service once I get back to Florida for the winter. I will be purchasing filters for it this summer while in New Hampshire, so I will have them ready to go when needed. Edited July 9, 2022 by Dr4Film Link to comment Share on other sites More sharing options...
Old Dog Posted July 9, 2022 Share Posted July 9, 2022 Once you compare all the specs, Donaldson filters are about the best on the market, I would rate Fleetguard second but more expensive. The difficult part is finding certain filters, not all are porduced by the major mfgs. A web site called "Bob is the oil guy" has a load of info on oils and filters. He knows what he's talking about. It's worth a visit if you're concerned about these things. 1 Link to comment Share on other sites More sharing options...
Greg Carter Posted July 9, 2022 Author Share Posted July 9, 2022 Don thanks for that as well. I have a Donaldson to put on but I’ll loose the original lower water cup sensor and water purge system. Least I’m not stuck without. While I didn’t cut the racor open to inspect it it certainly drained out very clean so I guess one could reuse it for a while if it sealed back up ok. cheers Link to comment Share on other sites More sharing options...
Craggar Posted July 10, 2022 Share Posted July 10, 2022 On 7/8/2022 at 1:00 PM, Greg Carter said: Thanks the very quick replies i should have added that we are in Canada. Jim Bob can you say where you found the pre filter? i thought those were long gone! certainly would be nice to find some as well. im going to try the Napa store as they are up here in Canada as well. so far the Donaldson was all my regular Lordco supplier could cross to but it’s not able to take the lower bowl for sure. thanks all Great source of info on this site that’s for certain. cheers te You're better off to go to a Traction if you have one near by. They are Napa's truck division and should be a little cheaper. Link to comment Share on other sites More sharing options...
Paul Brown Jr Posted May 12 Share Posted May 12 On 7/8/2022 at 2:07 PM, Greg Carter said: I know this has been asked but thought I’d just check Has anyone found a compatable fuel filter that fits the old Wynn system used by Monaco Current filter is a Racor S3230P which allows the original lower water separator and switch to be used. While I found a Donaldson replacement it will not take the original lower bowl and water switch. Thank you __________________ 95 Dynasty 36 97 Dynasty 40 original to the family 533621 wix filter I used the same one on my rig wix 533621 water/ fuel separator filter. however I am having trouble getting it to prime. Link to comment Share on other sites More sharing options...
Dr4Film Posted May 12 Share Posted May 12 I always have my fuel filters prefilled before attempting to start the engine.Never had any problems with no prime. Link to comment Share on other sites More sharing options...
Just Jim Posted May 12 Share Posted May 12 I'm not exactly sure what trouble you are having Paul. Most specifics would be nice. However, if you have changed out the pre-filter make sure you have the o rings on correctly. Sometimes the old one will stay on and cause it not to seal correctly. My old Wynn system always primed with about 3 cycles after changing filters. Link to comment Share on other sites More sharing options...
CRY1942 Posted May 12 Share Posted May 12 We changed to the upgraded RACOR. 790R, filter. Just simple install, only had to drill one mounting hole, 97 Dynasty. Racor_Fuel_Filtration_-_700-Series-Priming-Pump_-_7631.pdf Link to comment Share on other sites More sharing options...
Old Dog Posted May 12 Share Posted May 12 The original on mine is a Racor, found that out when the water sensor went out. Link to comment Share on other sites More sharing options...
Gary Petersen Posted May 13 Share Posted May 13 Regarding the original post: Is there some reason that you don't want to replace the Racor S3230P with another Racor? I see that my Sig uses this same filter element which, I see is available online at the RacorStore for $35.11 Should I be considering different replacement brand? Link to comment Share on other sites More sharing options...
