ido70 Posted November 11, 2022 Share Posted November 11, 2022 So we are headed to Texas and parked in a Wal Mart Campground in Louisburg. I tried starting the generator and it runs for a few seconds then stops. On investigation it appears I am low oil. The strange thing is my dip stick is missing everything but a plastic knob on the end. Could some kind soul tell me the measurement from the tip back to the “add 1qt” mark and to the “Full” mark? The generators probably use the same dip sticks however for the record mine is model HDKAJ, 7500 watts from a 2004 Windsor. Thank you for your time. JimB2 Link to comment Share on other sites More sharing options...
Ray Davis Posted November 11, 2022 Share Posted November 11, 2022 Operating from memory here, but I believe if you remove the drivers side panel of the gen there is a tube for that dip stick. that's where you will probably find the dip stick. Link to comment Share on other sites More sharing options...
Dr4Film Posted November 11, 2022 Share Posted November 11, 2022 Until you can replace the dip stick, pour oil in until the error code goes away. Link to comment Share on other sites More sharing options...
jacwjames Posted November 11, 2022 Share Posted November 11, 2022 I looked at the parts manual I have, the oil dip stick goes through the coolant tank and the tube then goes down to the general location of the oil filter. To get the dip stick out you may have to take the coolant tank loose, not sure if there wold be enough free play to remove the tube without removing the coolant tank. I'll try and look at mine today and see if I can come up with any crazy ideas. Link to comment Share on other sites More sharing options...
jacwjames Posted November 11, 2022 Share Posted November 11, 2022 Well, without a lot of effort I can't look at mine since I have my house batteries out while installing new drawer slides. But you might try making a fishing tool to get the old dip stick out. The stem of the dipstick is flexible cable, the tube itself is pretty large. Go to a big box store and buy a long flexible screen door spring. These come with loops on the end, cut one end off and bend the wire so it protrudes out some. Shove it down the hole an rotate slowly trying to get the bent wire to go under the flexible cable. If it catches you start feeling some resistance, continue rotating until you know you have 3-4 wraps around the cable and slowly try to pull out. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 11, 2022 Share Posted November 11, 2022 You need to get the old dip stick out before you do any damage. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
myrontruex Posted November 11, 2022 Share Posted November 11, 2022 I stole this from someone. A grabber might fit down the tube to grab the old one. This one shows just the plastic being retrieved but it might grab the whole thing. Worth a try. The grabbers are not expensive and very handy sometimes. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 11, 2022 Share Posted November 11, 2022 What a class act you are, stealing from others. Chuck B, 2004 Windsor Link to comment Share on other sites More sharing options...
myrontruex Posted November 11, 2022 Share Posted November 11, 2022 Just now, Chuck B 2004 Windsor said: What a class act you are, stealing from others. Chuck B, 2004 Windsor No, no. I'm just a gypsy traveling around and speading information. Stealing schematics is never beneath me for sure. I have a great software to clip out what I need and then take credit for it. Sure fire trick, works everytime. Where I borrowed this picture from most folks can guess. I did a google search on removing a broken dip stick and a picture popped up of me. Drilling down I found the picture and clipped it out. I have heard of the dip stick problem before so a Google Search helped me. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted November 11, 2022 Share Posted November 11, 2022 IMO, too late now to cover it up. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Ivan K Posted November 11, 2022 Share Posted November 11, 2022 Sometimes the dipstick tube is removable for easier fishing, no idea what engine is in the 7500. Link to comment Share on other sites More sharing options...
veraken Posted November 11, 2022 Share Posted November 11, 2022 Don't know the length, but the Onan part number you need is 123-2051 https://shop.cummins.com/CSSNAStore/s/product/a2w4N000003sJNVQA2/generator-oil-level-indicator-1232051 Link to comment Share on other sites More sharing options...
Dr4Film Posted November 13, 2022 Share Posted November 13, 2022 On 11/11/2022 at 4:24 PM, veraken said: Don't know the length, but the Onan part number you need is 123-2051 https://shop.cummins.com/CSSNAStore/s/product/a2w4N000003sJNVQA2/generator-oil-level-indicator-1232051 That part number states that it is Designed for Onan Marquis Generators: HGJAB, HGJAC, HGJAA His generator is an Onan QD model HDKAJ, 7500 watts Link to comment Share on other sites More sharing options...
veraken Posted November 13, 2022 Share Posted November 13, 2022 Look at page 29 of the attached Parts List for the HDKAJ generator. The part he needs is the 123-2051Onan Generator Parts Manual.pdfOnan Generator Parts Manual.pdfOnan Generator Parts Manual.pdf Link to comment Share on other sites More sharing options...
ido70 Posted November 13, 2022 Author Share Posted November 13, 2022 Yes, this is it I believe. I am missing all of the plastic mould attached to the end cable. Thanks for the direction. I’ll order one when settled. Just for your info I believe I added too much oil. The gen works great but there is a tube which extends from below that oil blows out, guessing when too much is added. Luckily there wasn’t a whole bunch and it blended well with the years of drips from past cars, sorry “Wally”. JimB2 Link to comment Share on other sites More sharing options...
Dr4Film Posted November 13, 2022 Share Posted November 13, 2022 4 hours ago, veraken said: Look at page 29 of the attached Parts List for the HDKAJ generator. The part he needs is the 123-2051Onan Generator Parts Manual.pdfOnan Generator Parts Manual.pdfOnan Generator Parts Manual.pdf Sorry about the misinformation. I was solely basing my post and information based on the link you had provided. When I clicked on it, below is what it stated. Nothing about an Onan QD Generator nor model HDKAJ. Generator Oil Level Indicator - 123-2051 Designed for Onan Marquis Generators: HGJAB, HGJAC, HGJAA. RV Green Label Parts Reference Guide Link to comment Share on other sites More sharing options...
