Rikadoo Posted April 12, 2023 Share Posted April 12, 2023 Hello everyone, so I am in the throws of replacing my exhaust manifold, I had blown a gasket and decided I did not want to try to machine an reuse them. So it really wasn't a bad price, however today as I started tearing it down it was brought to my attention that my charge air cooler is leaking. Given im sure the new ones are costly im sure I was wondering if anyone had luck having them fixed, I mean I really only want to do this once, I know when my radiator started to leak no one recommended repairs, they all said to replace... so I did and it has been fine!!! Link to comment Share on other sites More sharing options...
Bill R Posted April 12, 2023 Share Posted April 12, 2023 @Rikadoo Following this post. But can you share how you determined your CAC was leaking? Link to comment Share on other sites More sharing options...
Dr4Film Posted April 12, 2023 Share Posted April 12, 2023 If your tanks are still in good shape it can be recored very easily by a reputable shop. The CAC on my Windsor was done at CG&J when the replaced the radiator. Link to comment Share on other sites More sharing options...
Rikadoo Posted April 12, 2023 Author Share Posted April 12, 2023 Looking at the CAC right where the the top 5 rows coming out of the tanks there was a definite sign of black dirt right where the tubes came out on one side. For sure im gonna pull it to have it pressure tested and decide from there. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 12, 2023 Share Posted April 12, 2023 10 hours ago, Dr4Film said: If your tanks are still in good shape it can be recored very easily by a reputable shop. The CAC on my Windsor was done at CG&J when the replaced the radiator. Who is CG&J? I'll add it to my list of service providers. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
waterskier_1 Posted April 12, 2023 Share Posted April 12, 2023 44 minutes ago, Gary 05 AMB DST said: Who is CG&J? I'll add it to my list of service providers. Gary 05 AMB DST https://cgj.com/ -Rick N. Link to comment Share on other sites More sharing options...
Robert U Posted April 12, 2023 Share Posted April 12, 2023 I had some engine work done and they had to remove the CAC and radiator .Cummins sent the units to a radiator shop for cleaning. They said that both were in bad shape and recommended replacing both.They made knew ones out of brass.Had around 90,000 miles on coach. While they are out I would replace both. 2000 Dip Bob U Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted April 12, 2023 Share Posted April 12, 2023 8 hours ago, waterskier_1 said: https://cgj.com/ -Rick N. Thanks! Gary 05 AMB DST Link to comment Share on other sites More sharing options...
tomgagne55 Posted April 13, 2023 Share Posted April 13, 2023 I had my radiator recore done last year while getting engine work done and replaced the cac with one from cgi. Along with them I replaced the coolant pump and thermostat as a preventative measure. Cac was around 1k at the time. 2002 diplomat Link to comment Share on other sites More sharing options...
