Kimber Posted December 5, 2023 Share Posted December 5, 2023 2004 Dynasty 400 Cummins warning light for low coolant stays on even tho tank is at full line local rv service wants $240 for new sensor, is it possible to find one cheaper? AF1QipO5VEIiC0IeOJS0NT_cai8fh_3kUdqOqKBv2Hjv.url Link to comment Share on other sites More sharing options...
JDCrow Posted December 5, 2023 Share Posted December 5, 2023 Yes, I believe I put a Ford one in. Just spliced the two wires together. You can search for thread, it’s on here somewhere Link to comment Share on other sites More sharing options...
jacwjames Posted December 5, 2023 Share Posted December 5, 2023 (edited) I had the plastic type tank, I used this Ford Parts Coolant Level Warning Sensor XC4Z-10D968-AA Bought from Ebay ~$25 I just put both wires together and use a spade connector onto the sensor, I used some silicon to seal it. Edited December 5, 2023 by jacwjames 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted December 5, 2023 Share Posted December 5, 2023 (edited) $240 for that sensor is a MAJOR ripoff! Is that the sensor from the Surge Tank or from some location on the engine? I don't see any wires on that sensor, why? Did the wires snap off? Take it to NAPA auto. I would bet they could match it up with one that they have in stock. Edited December 5, 2023 by Dr4Film Link to comment Share on other sites More sharing options...
Tdkkart Posted December 5, 2023 Share Posted December 5, 2023 Polish up the metal part with Scotchbrite and try it again. Mine was doing the same and cleaning it fixed it. Pretty common issues from what I've seen. 1 Link to comment Share on other sites More sharing options...
zmotorsports Posted December 5, 2023 Share Posted December 5, 2023 Same as Jim. This is the sensor I used when I built my new surge tank. Fits an F-800 Ford with a Cummins engine. I purchased mine from Rock Auto. More Information for STANDARD MOTOR PRODUCTS FLS164 (rockauto.com) Link to comment Share on other sites More sharing options...
vito.a Posted December 5, 2023 Share Posted December 5, 2023 I assume you have a 1 wire sensor? If so, then clean up the probe with some Scotchbrite. Also clean up the surface where the wire terminal attaches. 1 Link to comment Share on other sites More sharing options...
ktloah Posted December 5, 2023 Share Posted December 5, 2023 Source Engineering in Oregon...he makes his own sensors! 1 Link to comment Share on other sites More sharing options...
dl_racing427 Posted December 6, 2023 Share Posted December 6, 2023 Mine has the one wire aluminum sensor. Cleaning it has helped in the past. One day I might get around to making one from stainless, which should eliminate the oxidation issue for good. Link to comment Share on other sites More sharing options...
