Scott Le Magicien Posted April 14 Share Posted April 14 And I really don't like taking my eyes (and more importantly my peripheral vision) off the road to find the correct switch on the side panel... So I added my own remote! The Lights button turns on ALL THE LIGHTS! And the Horns button activates the airhorns on the roof. They're loud, but nice have sometimes! The remote is a Visonic. They're not made any more, sadly, but sometimes you can find them on eBay... Link to comment Share on other sites More sharing options...
timaz996 Posted April 14 Share Posted April 14 Good Idea 1 Link to comment Share on other sites More sharing options...
BradHend Posted April 15 Share Posted April 15 How was that to wire up into the steering column and back to the switches? What exactly does ‘all the lights’ consist of? Link to comment Share on other sites More sharing options...
Scott Le Magicien Posted April 15 Author Share Posted April 15 It's a wireless remote. All the lights = Low Beams, HIgh Beams, and the Fog Lights. Link to comment Share on other sites More sharing options...
cbr046 Posted April 15 Share Posted April 15 I could use a remote for my Dometic roof AC's 5 button thermostat . . . . either for temp adjustment or mode. Going down the road I can turn on the generator without much load but shutting the generator off while drawing 20A isn't advised. - bob Link to comment Share on other sites More sharing options...
Ivan K Posted April 15 Share Posted April 15 18 minutes ago, cbr046 said: I could use a remote for my Dometic roof AC's 5 button thermostat . . . . either for temp adjustment or mode. Going down the road I can turn on the generator without much load but shutting the generator off while drawing 20A isn't advised. - bob Get a Microair thermostat and control it all from your phone or tablet. That's what I do for all the AC units from anywhere. Switch to heat, cool, fan, set temp, whatever. It uses Bluetooth or wifi depending on distance. Link to comment Share on other sites More sharing options...
cbr046 Posted April 15 Share Posted April 15 8 minutes ago, Ivan K said: Get a Microair thermostat and control it all from your phone or tablet . . . I really don't like the Dometic 5-button but for $250 I'll pull over somewhere! Unless you're buying it for me . . . 😁 😁 - bob Link to comment Share on other sites More sharing options...
jacwjames Posted April 15 Share Posted April 15 I took a leap of faith and bought a Microair when I installed both AC's new. I would have had to replace the 5 button anyway so the cost difference wasn't that bad. The Micorair has some nice features and am very satisfied with the purchase. When boon docking in really cold weather I can just use the phone app to turn the furnace on. 2 Link to comment Share on other sites More sharing options...
bryan browne Posted April 16 Share Posted April 16 (edited) I had the same issue last month on a 2007 Dynasty, it was my clockspring that is under the steering wheel, I took it out, removed steering wheel and column cover and disconnected at base of steering column and from steering wheel, check continuity on the wires and they all showed good, put back in and some buttons worked so I new it had a back spot in it, ordered a new one and my issue appears to be fixed. Edited April 16 by bryan browne Link to comment Share on other sites More sharing options...
