Romeo84 Posted October 3, 2020 Share Posted October 3, 2020 Thanks. Link to comment Share on other sites More sharing options...
granvillebarker Posted October 3, 2020 Share Posted October 3, 2020 The company listed on there was gone when I looked, these are the same O-rings I got from amazon a week or so ago. I also use the super lube on them, I think it came from McMaster.com on a previous oring order. Link to comment Share on other sites More sharing options...
Romeo84 Posted October 3, 2020 Share Posted October 3, 2020 Niiiiice!!!!!! Thanks!!!! How did u get the threaded bolt out of the brass? Does it just unscrew? Link to comment Share on other sites More sharing options...
miacasa_2000 Posted October 4, 2020 Share Posted October 4, 2020 Ryan, Sorry I didn't get back to you sooner Anyway I agree with Granville they are the exact O-rings I plan to order. please take pictures and let us no how you make out. Roy Link to comment Share on other sites More sharing options...
granvillebarker Posted October 4, 2020 Share Posted October 4, 2020 (edited) 22 hours ago, Romeo84 said: Niiiiice!!!!!! Thanks!!!! How did u get the threaded bolt out of the brass? Does it just unscrew? It just unscrews, I’ll post back if the nitrous solenoid tool fits, once it arrives. It was in one of the links in my last post. I just realized it’s another thread... Yes, the center part unscrews, there are two indentions the tool should fit into, you can also use two of the solenoid nuts in a jam situation to get them out, but some of those nuts are a little soft for that. This latest service I went with brown orings, just to make sure I didn’t mix any up or miss any. The old ones were black. Just make sure you get everything super clean. Here are some close ups of the pieces, there’s also a spring in each one that’s not in the pictures: Edited October 4, 2020 by granvillebarker Added link to other thread. 1 Link to comment Share on other sites More sharing options...
Romeo84 Posted October 4, 2020 Share Posted October 4, 2020 Thanks for the info bud! Never seen the nitrous tool b4. I wonder if their was an actual tool for that. Totally used your pics to order from Amazon. Super ez!!! Thanks again. Link to comment Share on other sites More sharing options...
rpasetto Posted October 5, 2020 Share Posted October 5, 2020 Add me to the "slow-leak" list too. Recently replaced the two big ping-tank-to-airbag hoses on passenger side front. That helped; now the leak down is slower. My wife says she can hear a faint leak. Did some dawn spraying yesterday; more spraying is scheduled as soon as weather permits later today. I suspect leak is in line which feeds ping tanks; it's hard to see all of it. [Diagram from Monaco air-line book is confusing. I'd expect to see lines from Ride Height valve to HWH-manifold but it doesn't show it that way. HWH book shows lines from RH valve to one set of manifold ports, then on to airbags, but Monaco diagram seems to show wrong ports going out.] Link to comment Share on other sites More sharing options...
Romeo84 Posted October 5, 2020 Share Posted October 5, 2020 Yours was built on a friday at 2:59 pm 😄 Link to comment Share on other sites More sharing options...
granvillebarker Posted October 6, 2020 Share Posted October 6, 2020 On 10/5/2020 at 7:28 AM, rpasetto said: Add me to the "slow-leak" list too. Recently replaced the two big ping-tank-to-airbag hoses on passenger side front. That helped; now the leak down is slower. My wife says she can hear a faint leak. Did some dawn spraying yesterday; more spraying is scheduled as soon as weather permits later today. I suspect leak is in line which feeds ping tanks; it's hard to see all of it. Dang, I don’t think I’ve ever checked those lines to the ping tanks, i will check them this week. If a 2006 has leaks in them, I’m betting my 2005 is in the same boat. Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2020 Share Posted October 6, 2020 Your Windsor may not even have ping tanks. My 2002 Windsor does not that I know of. Link to comment Share on other sites More sharing options...
rpasetto Posted October 6, 2020 Share Posted October 6, 2020 19 minutes ago, granvillebarker said: Dang, I don’t think I’ve ever checked those lines to the ping tanks, i will check them this week. If a 2006 has leaks in them, I’m betting my 2005 is in the same boat. Mine is an '05 too. Spent a lot of time still looking for the small leak. Airbags are staying filled, never go soft. Lines feeding the ping tank should be coming from the HWH manifold according to diagram from a few days back. So it looks like the ping tank and hoses on the airbag side of the HWH block are OK. @Bill Groves explained to me how to force the two check valves closed by rapidly dumping the wet tank. So testing with tanks separated, it appears there's a leak in something connected to the front tank. Fittings at tank show no bubbles so I'm looking at six or eight possibilities like the air chuck, step slide, etc. I'm still having trouble finding the Vac. Generator. It's going to be tough finding it if there's a hole in the middle of an airline. Search continues. 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted October 6, 2020 Share Posted October 6, 2020 Rick , I doubt you have an air powered vacuum generator . Monaco used those devices in the past but I haven't heard of them in a long time . I believe they were a metal box mounted on the firewall . Most coaches use a small 12v vacuum generator mounted on the firewall . Quote I'm still having trouble finding the Vac. Generator. It's going to be tough finding it if there's a hole in the middle of an airline. Search continues. Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2020 Share Posted October 6, 2020 Rick, my 2002 Windsor has an Air Vacuum Generator however yours may have a 12 VDC Vacuum Generator. Both will be mounted on the front of your firewall with a hose going to the Vacuum Reservoir. You can see the air line going to the top of the vacuum generator in my photo. 1 Link to comment Share on other sites More sharing options...
Romeo84 Posted October 6, 2020 Share Posted October 6, 2020 1 hour ago, Dr4Film said: Rick, my 2002 Windsor has an Air Vacuum Generator however yours may have a 12 VDC Vacuum Generator. Both will be mounted on the front of your firewall with a hose going to the Vacuum Reservoir. You can see the air line going to the top of the vacuum generator in my photo. Wait what is that giant ball?? I have 1 as well. What is it for? Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2020 Share Posted October 6, 2020 Vacuum reservoir. If you trace the large hose it will go back to your Vacuum Generator. The small tube goes into your dash controls for your AC & Heat. Link to comment Share on other sites More sharing options...
granvillebarker Posted October 6, 2020 Share Posted October 6, 2020 Richard, What is the blue valve for at the bottom of one of your pics? Link to comment Share on other sites More sharing options...
Romeo84 Posted October 6, 2020 Share Posted October 6, 2020 So interested!! What is a vacuum generator even for? Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2020 Share Posted October 6, 2020 58 minutes ago, granvillebarker said: What is the blue valve for at the bottom of one of your pics? I installed a small self-contained air compressor that sits on top of the storage area in front of my 7.5KW generator to supply air to our step cover. Our step cover is air driven versus 12 VDC powered. I did not want the small air compressor attempting to air up the large tanks so I installed a check valve in the line coming from the tanks to the step cover Mac Valve. Unfortunately after trying a few different check valves (which all leaked to some degree) I chose to install a Ball Valve instead. When the valve is open I let the coach air system maintain air to the step cover. When we are parked I close the ball valve then use the small air compressor to maintain air for the step cover. 16 minutes ago, Romeo84 said: So interested!! What is a vacuum generator even for? The vacuum is used to open and close the various vents for the Dash AC & Heater such as floor, dash front or defrosters. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted October 6, 2020 Share Posted October 6, 2020 13 minutes ago, Romeo84 said: So interested!! What is a vacuum generator even for? Gasoline engines generate vacuum , diesels don't . For yrs car companies used the vacuum to operate things like the doors that direct air in your dash HVAC . When pickups started using diesel engines they didn't want to make a different dash HVAC system so they came up with a small elect 12v vac pump Our coaches use that same technology for controlling ourA/Cs . Link to comment Share on other sites More sharing options...
Romeo84 Posted October 6, 2020 Share Posted October 6, 2020 Awesome!! So well informed! Thanks man! Link to comment Share on other sites More sharing options...
Ivan K Posted October 6, 2020 Share Posted October 6, 2020 Romeo84, in your Sig, the vacuum generator should be just under the vacuum reservoir in Front run bay just like ours. Link to comment Share on other sites More sharing options...
Romeo84 Posted October 7, 2020 Share Posted October 7, 2020 4 hours ago, Ivan K said: Romeo84, in your Sig, the vacuum generator should be just under the vacuum reservoir in Front run bay just like ours. It is but I have no idea what it did. Link to comment Share on other sites More sharing options...
rpasetto Posted October 7, 2020 Share Posted October 7, 2020 11 hours ago, Ivan K said: Romeo84, in your Sig, the vacuum generator should be just under the vacuum reservoir in Front run bay just like ours. Thanks, Ivan, I didn't think of looking there. Link to comment Share on other sites More sharing options...
