jfasano88 Posted January 24, 2021 Share Posted January 24, 2021 My tv reception is great until I turn on my flourcent ceiling lights. The reception is very week on the tv screen when ceiling lights are on. Does anyone know why this happens? I have a regular T antenna. John 2009 Monaco Camelot kfq Link to comment Share on other sites More sharing options...
Ivan K Posted January 24, 2021 Share Posted January 24, 2021 Likely one or more of your lights ballast is bad and causing interference. In my working days as a support for cell service providers I have seen more than one gas station lights totally killing cellphone towers reception at a great distance. These things can and go bad. Convert to LED if you can. Link to comment Share on other sites More sharing options...
Dennis H Posted January 24, 2021 Share Posted January 24, 2021 Yep! Bad Ballast. Time to upgrade. I tried several types of LEDs and found the ones linked below to be the easiest and most effective in replacing the fluorescent bulbs. Simply remove the cover, then the middle metal plate. Remove all the wiring leaving only the positive and negative in the ceiling. Once the fixture is gutted simply stick two or three, (they are really bright) of the strips in and wire them up. Reinstall the fixture. I'd tape up two temporarily and check the brightness. If you want more use three. I use two in the hall and three in the bath where more light is desired....best of luck....Dennis LED replacement lights. Link to comment Share on other sites More sharing options...
Dr4Film Posted January 24, 2021 Share Posted January 24, 2021 I agree with Ivan. I had one ballast in my over the sink kitchen light that would interfere with both my tank level indicators and the display board for my Intellitec EMS in the bedroom. I changed out the ballast and it solved the problem. If you can track down which one(s) of your ceiling lights that is causing the problem just replace that specific one(s). Link to comment Share on other sites More sharing options...
DavidL Posted January 25, 2021 Share Posted January 25, 2021 (edited) You might as well switch to LED...but note that some LEDs cause RF (radio frequency) interference as well. So best to buy one, plug in and test, then mount and order rest to match. Test with fixture closest to the antenna. Edited January 25, 2021 by DavidL Link to comment Share on other sites More sharing options...
jacwjames Posted January 25, 2021 Share Posted January 25, 2021 (edited) I replaced all my fluorescent lights with LED. I bought a couple 15 ft rolls with connectors. I also wanted some flexibility so I added a second switch on each light. I pulled the light out, stripped it of all the electrics and cleaned it good. Put in 3 strips of LED lights wiring the outer two to the original strip and the middle to the new switch. Once I confirmed the final results I would remove 3 at a time and rehab them. When I was done I could have 1, 2, 3, or no LED strips providing light meaning I had lots of flexibility. Total cost to do all the fluorescent lights was less then $100. Edited January 25, 2021 by jacwjames 1 Link to comment Share on other sites More sharing options...
Solution jfasano88 Posted January 26, 2021 Author Solution Share Posted January 26, 2021 This is John f again. I have a dumb question? Maybe two. how do you cut them and how do you mount them. My ballast are tucked behind the lights. Do I need to remove them or can I splice into the wire that feed the lights. Is there a video on how to change to led. Link to comment Share on other sites More sharing options...
jacwjames Posted January 26, 2021 Share Posted January 26, 2021 I bought the ribbon LED lights with the adhesive tape on the back. I removed the entire light, completely gutted it of all the electronic. I then thoroughly washed the metal housing and then used acetone to clean the surface good where the lights would be attached. The lights can be cut at regular intervals, there is marking on the ribbon where to cut. I then bought some connectors that simply snapped across one end of the light making sure the positive and negative were correctly oriented. From there I simply wired the ends through the switches connecting the power supply to all the switches. This is similar to what I bought https://www.ebay.com/itm/16FT-5M-Bright-Cool-White-5M-300Leds-Flexible-SMD-5050-Led-Strip-Light-Lamp-12V/123772196047?epid=14004348850&hash=item1cd165d4cf:g:0PcAAOSwgkZc35vn Here are the ends https://www.ebay.com/itm/10X-LED-STRIP-LIGHT-CONNECTOR-SMD-5050-5630-SINGLE-2-WIRE-10MM-PCB-BOARD-ADAPTER/293956058993?hash=item4471257f71:g:1nYAAOSwKtFgAQQP I bought a simple round on/off switch to add the light but this isn't necessary unless you wants some control how much light you get from each light fixture. Link to comment Share on other sites More sharing options...
Dennis H Posted January 26, 2021 Share Posted January 26, 2021 John, It's a pretty simple process. I've attached some pictures to help you. I don't have a video, but the pictures are numbered 1-6. Hope this helps. If you have more questions don't be afraid to ask. That's how we learn....Dennis Pictures: 1 Light fixture with cover removed. 2. Fixture with bulbs removed. The center rail is removed by squeezing it in the middle and pulling down. 3. Cover, bulbs and center rail 4. Fixture with cover, bulbs and center rail removed. 5. Wiring exposed. Blue circle shows black and white, (power and ground) Red circle shows screws to remove to take down the fixture. 6. Fixture with new LEDs installed. 1 Link to comment Share on other sites More sharing options...
jfasano88 Posted January 27, 2021 Author Share Posted January 27, 2021 Thanks I have the same light fixture that’s in your pictures. Wow thanks again. John F 2009 Camelot kfq Link to comment Share on other sites More sharing options...
Pduggs Posted December 31, 2022 Share Posted December 31, 2022 On 1/26/2021 at 6:58 PM, Dennis H said: John, It's a pretty simple process. I've attached some pictures to help you. I don't have a video, but the pictures are numbered 1-6. Hope this helps. If you have more questions don't be afraid to ask. That's how we learn....Dennis Pictures: 1 Light fixture with cover removed. 2. Fixture with bulbs removed. The center rail is removed by squeezing it in the middle and pulling down. 3. Cover, bulbs and center rail 4. Fixture with cover, bulbs and center rail removed. 5. Wiring exposed. Blue circle shows black and white, (power and ground) Red circle shows screws to remove to take down the fixture. 6. Fixture with new LEDs installed. Thanks Dennis. That’s exactly what I plan to do with my five fluorescent lights. I had an issue with the Intellitec and called M&M. He told me to get rid of the fluorescent lights as they can interfere with the Intellitec system. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 31, 2022 Share Posted December 31, 2022 In my previous Windsor, I had one fluorescent light fixture over the sink that I had to replace as it affected both the EMS display and my tank level system. Took me quite a while to narrow it down but after replacing it with a new one, no more issues. 1 Link to comment Share on other sites More sharing options...
