CLIFF918 Posted March 6, 2022 Share Posted March 6, 2022 Has anyone changed the exhaust fan direction in the rear of oven? What i want to do is have the exhaust go outside the coach where it belongs, hate that blast of air in your face. I have ordered the outside vent and cover and am perfectly capable of cutting the hole and the whole mounting thing. What I don't know is if I will run into any wiring cables etc in the outside wall behind the Microwave ?? Cliff Link to comment Share on other sites More sharing options...
Wrayj1 Posted March 6, 2022 Share Posted March 6, 2022 Cliff, ours is the Sharp R-1874-T convection, which we changed out in 2019. We vented to the outside at that time and did not encounter any obstructions. Link to comment Share on other sites More sharing options...
DavidL Posted March 6, 2022 Share Posted March 6, 2022 (edited) Cut through one layer with a pilot hole, open it up and inspect. Move whatever is in it's way out of the way and continue cutting. Ideally cutting from the inside first just in case there is something immovable in the way. Ensure you are between studs when making your cuts. Edited March 6, 2022 by DavidL Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted March 6, 2022 Share Posted March 6, 2022 We have a 2001 diplomat. Took it slow and easy. Did not run into any wiring or studs. Link to comment Share on other sites More sharing options...
Notn2bars Posted March 6, 2022 Share Posted March 6, 2022 We have a 2000 Dynasty with the kitchen, living room slide. Had no trouble cutting a hole for a microwave vent. Cut from the inside and did not run into any wiring or frame structure. Good luck and God Bless, Ed Link to comment Share on other sites More sharing options...
Dr4Film Posted March 6, 2022 Share Posted March 6, 2022 I had Elite Repair & Renovation in Harrisburg Oregon do mine in the Windsor. I showed them photos I had taken of the superstructure when it was cool and damp outside. They didn't have any problems whatsoever. I now have to do another outside exhaust for the Dynasty. Link to comment Share on other sites More sharing options...
LakeBob Posted March 7, 2022 Share Posted March 7, 2022 Would like to do the same to my Dynasty, interested in how this goes for you. Please update the group if you attempt. thanks! Link to comment Share on other sites More sharing options...
CLIFF918 Posted March 7, 2022 Author Share Posted March 7, 2022 Thanks for all the tips, I knew someone had to have done this already. Cliff Link to comment Share on other sites More sharing options...
granvillebarker Posted March 12, 2022 Share Posted March 12, 2022 A strong magnet will find the cross members in a dynasty, if you want to check before you cut. Link to comment Share on other sites More sharing options...
