Ted Carbonaro Posted March 8, 2022 Share Posted March 8, 2022 06 Monaco Camelot, lost 1 AC cover in heavy winds in Santa Fe. Does anyone have a suggestion on where I can order two replacement covers? Link to comment Share on other sites More sharing options...
jegall Posted March 8, 2022 Share Posted March 8, 2022 Try Amazon Link to comment Share on other sites More sharing options...
RVhorod Posted March 8, 2022 Share Posted March 8, 2022 icondirect.com should have the covers. I ordered AC covers for my coach, they fit perfectly. 1 1 Link to comment Share on other sites More sharing options...
JDCrow Posted March 8, 2022 Share Posted March 8, 2022 (edited) Yeah what brand? Got my “penguin” covers off Amazon. Fit and look great Edited March 8, 2022 by JDCrow Link to comment Share on other sites More sharing options...
Ted Carbonaro Posted March 8, 2022 Author Share Posted March 8, 2022 Mine is Dometic Duo-Therm and looks like the same as your Penguin. Thanks! Link to comment Share on other sites More sharing options...
JDCrow Posted March 8, 2022 Share Posted March 8, 2022 14 minutes ago, Ted Carbonaro said: Mine is Dometic Duo-Therm and looks like the same as your Penguin. Thanks! Mine are duo therm as well. I assumed they were called penguins. I’ll have to read up now . Link to comment Share on other sites More sharing options...
Tom Wallis Posted March 8, 2022 Share Posted March 8, 2022 I just replaced a Duo-Therm cover in October. I also found it at Amazon: https://smile.amazon.com/gp/product/B00IABALBO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
Paul A. Posted March 8, 2022 Share Posted March 8, 2022 Water & Holding Tanks, Skylights & A C Shrouds & More https://www.eztopsworldwide.com/ https://www.icondirect.com/ Link to comment Share on other sites More sharing options...
Cubflyer Posted March 8, 2022 Share Posted March 8, 2022 Icondirect.com was recommended to me at the "gathering"... They sound like they are made of better (thicker, more durable) material than the one I bought on Amazon. I was ok with the Amazon quality... but also hope to not have to replace the cover again.... might have been worth the price difference to go with Icon, if I had known about them... Ken Link to comment Share on other sites More sharing options...
Dr4Film Posted March 9, 2022 Share Posted March 9, 2022 Get the ones at Icondirect as they are indestructible and will last forever. Unless you forget to secure them correctly. Make sure you select the vented ones which come with the vent holes on one side for the Penguin covers. 1 Link to comment Share on other sites More sharing options...
Bill R Posted March 10, 2022 Share Posted March 10, 2022 Now comes the very “green” new RV owner question. Why should I have AC covers? I can think of some obvious reasons like protect from the sun and weather. But are there other advantages if my coach is in covered storage? Link to comment Share on other sites More sharing options...
Ivan K Posted March 11, 2022 Share Posted March 11, 2022 (edited) 1 hour ago, Bill R said: Now comes the very “green” new RV owner question. Why should I have AC covers? I can think of some obvious reasons like protect from the sun and weather. But are there other advantages if my coach is in covered storage? If you really aren't using it, it is only protecting it from elements but if you need to run it, it is absolutely needed to chanel cooling air where it needs to go, through the fins and not around them. Edited March 11, 2022 by Ivan K Link to comment Share on other sites More sharing options...
Tom Wallis Posted March 11, 2022 Share Posted March 11, 2022 It's not really an optional piece. It's a permanent cover that screws on the top of the unit and cover all the internal part. And as Ivan said it also helps direct air where it needs to go. 1 Link to comment Share on other sites More sharing options...
Bill R Posted March 11, 2022 Share Posted March 11, 2022 Thank you. Now I feel even greener. Because I misinterpreted this post thinking it was about temporary covers that you put over the hard shell cover. I believe I am on track now. 1 Link to comment Share on other sites More sharing options...
nyrngrz Posted March 12, 2022 Share Posted March 12, 2022 Someone posted here to make sure we order the "vented ones." Do all covers have the vents? Is there a difference between vents or no vents? Also, It seems that if you order on Amazon the product is from iondirect and is cheaper than if you ordered from the iondirect website. Link to comment Share on other sites More sharing options...
Tom Wallis Posted March 13, 2022 Share Posted March 13, 2022 Just make sure you get the right cover for your specific AC unit. By design some have vent holes in the cover and some do not. Link to comment Share on other sites More sharing options...
nyrngrz Posted March 13, 2022 Share Posted March 13, 2022 I checked my Build Sheet and I have the Dometic Duo-Therm 600315.321 A/C units. I do not believe the original covers on the coach now do not have vents. Link to comment Share on other sites More sharing options...
Ivan K Posted March 13, 2022 Share Posted March 13, 2022 You don't necessarily need the side vent holes in those covers. While they would allow easier air flow through the condenser fins, I personally opted not to have them because where we go, we always run into a dust storm and I believe our solid covers minimize the exposure to blowing sand and all units work just fine without the holes. I had to replace one cover, got an Icon from Amazon and it is really so much better than the originals as far as the solid feel and flexibility without cracking. Your choice. Link to comment Share on other sites More sharing options...
nyrngrz Posted March 13, 2022 Share Posted March 13, 2022 Thanks Ivan, that is the route I am going to take, Icon from Amazon. Link to comment Share on other sites More sharing options...
Cubflyer Posted March 13, 2022 Share Posted March 13, 2022 Ivan, I can't find the ICon brand ones on Amazon.... can you post a link please? Ken Link to comment Share on other sites More sharing options...
nyrngrz Posted March 13, 2022 Share Posted March 13, 2022 https://smile.amazon.com/gp/product/B00IABALBO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
96 EVO Posted March 13, 2022 Share Posted March 13, 2022 When you get your new cover, do a search on this forum. There is some good pic's of where the foam strips should be attached to the top of the unit. Link to comment Share on other sites More sharing options...
Ivan K Posted March 13, 2022 Share Posted March 13, 2022 1 hour ago, Cubflyer said: Ivan, I can't find the ICon brand ones on Amazon.... can you post a link please? Ken Yep, Tony's link is exactly what I bought in 2020. Fits our original units from yr 2000. I think to remember redrilling the mount holes, not sure anymore. 1 hour ago, nyrngrz said: https://smile.amazon.com/gp/product/B00IABALBO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1 Link to comment Share on other sites More sharing options...
Cubflyer Posted March 13, 2022 Share Posted March 13, 2022 I see it ! I had searched for 'Icon A/C cover' using their search "engine" with no Joy.... Thanks! They are priced like the one I bought last fall that was NOT an Icon... Ordered another one for my rear A/C....... Ken Link to comment Share on other sites More sharing options...
