Terryjean Posted April 15, 2022 Posted April 15, 2022 We’ve been camping for three days we filled up our RV with diesel fuel right before the campsite two days later as of now we have just noticed a small leak upfront it’s Good Friday can’t reach anyone going two hours down the road to Lebanon Tennessee will it be safe to drive
JDCrow Posted April 15, 2022 Posted April 15, 2022 36 minutes ago, Terryjean said: We’ve been camping for three days we filled up our RV with diesel fuel right before the campsite two days later as of now we have just noticed a small leak upfront it’s Good Friday can’t reach anyone going two hours down the road to Lebanon Tennessee will it be safe to drive Just for info, what engine, and any pics?
timaz996 Posted April 15, 2022 Posted April 15, 2022 Is it just coming out the vent from your fuel tank? Tim 1
Terryjean Posted April 16, 2022 Author Posted April 16, 2022 The motor is in the back. I don’t know where it is coming from. But the leak is up front. The motor is a Cummings
Notn2bars Posted April 16, 2022 Posted April 16, 2022 Do you have pics of the leak? I believe your fuel tank is up front. Could be coming out of the tank vent as Tim has indicated. More info or pics would help 1
Rex schmeckpeper Posted April 16, 2022 Posted April 16, 2022 I have over filled my 2004 34 Cayman, If it’s warm the fuel will expand and come out the tank vent. If it’s not a lot you just got the tank too full. Just like I did. If it’s not really running out I would say go ahead and run it. If you run the generator a Bit and run the tank down it should stop. 1
Ivan K Posted April 16, 2022 Posted April 16, 2022 Up front, like under the generator or where the tank is further back up front?
Pepperell Posted April 16, 2022 Posted April 16, 2022 If you drive it like that, you’ll likely have diesel fuel on your toad. 1
Terryjean Posted April 16, 2022 Author Posted April 16, 2022 It is up front I don’t have pic it night but in morning I will. Good idea about generator wish I thought of that. Thank you everyone. I will try and look under it is just dripping Terryjean It’s a little back near the leveler
JJMonaco Posted April 16, 2022 Posted April 16, 2022 I had a leak one time after I filled up. What I found was the rubber gasket on the fuel fill cap was missing. Where I had parked was not level and the fuel was dripping out the fill pipe. Hope your problem is as simple as mine. JJ John J 2002 Monaco Signature 1
Squints2c Posted April 16, 2022 Posted April 16, 2022 8 hours ago, Terryjean said: It is up front I don’t have pic it night but in morning I will. Good idea about generator wish I thought of that. Thank you everyone. I will try and look under it is just dripping Terryjean It’s a little back near the leveler Right behind the leveler is where the tank vent is. If it's that it should quit after you use some out of the tank. If I recall correctly it's about a 1 inch rubber hose.
Robert U Posted April 16, 2022 Posted April 16, 2022 I have a rule. When the pump shuts off I remove it. I don't try to overfill the tank. Bob U 2000 Dip
welleking Posted April 16, 2022 Posted April 16, 2022 the most likely point of this leak is on the generator... mine leaked at the seal of the electric fuel pump. my generator was an old constant speed 7.5 , yours maybe a quiet diesel meaning the fuel would be coming from a different point in the genset.
Terryjean Posted April 16, 2022 Author Posted April 16, 2022 Hi everyone. Thank you all for all your help . It was a loose clamp on a hose. Called repair shops near rest stop no one could help with a possible tank leak . There was a truck mechanic at the stop we asked him to look at it and he found the clamp was loose and tightened it for us all was well. So thankful that he was there I don’t know what we would have done it’s amazing I think God was looking out for us to have that mechanic right where we had stopped. 4
Notn2bars Posted April 16, 2022 Posted April 16, 2022 Awesome you were able to get it fixed. Great that it was something simple. God Bless, Ed & Sylvia 1
HarleyR Posted April 16, 2022 Posted April 16, 2022 If you filled your tank just before stopping to camp, the leak may merely be from expansion. The fuel is stored underground at the station. The fuel might have expanded in your tank when exposed to the warmer air, causing the tank to overflow. I made a mess of my driveway when it happened to me. 1
