Thomas Posted March 4, 2023 Share Posted March 4, 2023 Good evening everyone, I am having an issue with cruise control.. Everything on the smart wheel works fine except cruise, I have done all the smart wheel diagnostic tests, and the module passes. The light on the dash works as it should as well.. I have done some other tests on the cancel switch's on outside firewall and I am getting 4.75 volts through both switches. and when brake pedal is pushed it drops to 0 volts on the outgoing terminal to module.. So I am assuming switches are working correctly, However is the 4.75 volts to low..? Where does this 4.75 volt feed come from..? And also I can not find the relay that is for the cruise in the FRP This relay sends power to the ECM when cruise is activated. Does anyone have a picture or a location of this relay.. Any ideas would be great, Been working on this for a while now.. I have also taken dash apart to make sure no wires were rubbed trough and grounding anywhere as I heard that was an issue as well with the 2 wires going to cancel switches.. Thinking that this relay I'm looking for might be the gremlin.. 2004 Holiday Rambler Navigator 45' Detroit 60 series Thanks Thomas Link to comment Share on other sites More sharing options...
Trinidaddave Posted March 4, 2023 Share Posted March 4, 2023 ? Is your exhaust break switch on? My cruise control will not set if the exhaust break switch is on. Link to comment Share on other sites More sharing options...
vito.a Posted March 4, 2023 Share Posted March 4, 2023 Do you have Eaton Vorad Smart Cruise? Does your high idle work? Make sure your Jake brake and brake lights are off. There is an override for the cruise. I think it's On-Set, Off-Set, On-Set in sequence (three times). Link to comment Share on other sites More sharing options...
Todd P Posted March 4, 2023 Share Posted March 4, 2023 Not meaning to state obvious but I missed this on my coach once when I thought cruise was not working. Is your Jake brake off? Link to comment Share on other sites More sharing options...
Thomas Posted March 4, 2023 Author Share Posted March 4, 2023 Yea its off, and I actually have that part of dash apart as well checking wires to jack brake switch.. I do not have the vorad system.. I will try the override, The high idle is not working either.. Link to comment Share on other sites More sharing options...
Dr4Film Posted March 4, 2023 Share Posted March 4, 2023 Have you tested and confirmed that your Clock-spring is good and functioning correctly? Link to comment Share on other sites More sharing options...
Thomas Posted March 4, 2023 Author Share Posted March 4, 2023 I have done the tests that are listed for the smart wheel. I am assuming that with all the functions and the tests passing for the control module, that the clock spring is functioning correctly.. I'm not aware of any other tests that can be done ..? I think I might contact intellitec Monday to see if they can point me in the right direction for this relay I'm looking for, being that they are the makers of all the circuit boards.. Link to comment Share on other sites More sharing options...
Flyinhy Posted March 4, 2023 Share Posted March 4, 2023 I'm curious to what you find out. The only difference is my high idle works as it should. Link to comment Share on other sites More sharing options...
Michael Powell Posted March 5, 2023 Share Posted March 5, 2023 I had the same problem took it to a shop they found the brake switch unplugged or loose... my symptoms started working intermittenting sometimes worked fine then while driving would cut out and not set then would set... I thought so.ething was getting hot... Finally it quit once and for all 3000 miles away from home 🏡 The whole problem was around the brake switch... all good. 1 Link to comment Share on other sites More sharing options...
Thomas Posted March 5, 2023 Author Share Posted March 5, 2023 Michael Powell, Are you referring to the engine brake switch or the cruise cancel switches that are activated by the brake pedal when pushed Thanks Thomas Link to comment Share on other sites More sharing options...
Michael Powell Posted March 6, 2023 Share Posted March 6, 2023 The one to the beake pedal costed me $35.00... The best $35.00 I have spent on my coach since I bought it. Link to comment Share on other sites More sharing options...
Thomas Posted March 8, 2023 Author Share Posted March 8, 2023 Michael Where did you get the switch and do you have a part number.. Rev group wants $135 each Link to comment Share on other sites More sharing options...
Michael Powell Posted March 8, 2023 Share Posted March 8, 2023 Mine was a lose connection.... You may try a local truck center..Don't think they change much.. Take yours out and take pictures and shop for one. Link to comment Share on other sites More sharing options...
jacwjames Posted March 8, 2023 Share Posted March 8, 2023 I have the parts page for my brake pedal and shows the brake switch pn as SM-1C-5R1WP205 This is a Nason switch that was made for Monaco so it won't show the switch on their web site https://www.nasonptc.com/products/switches/low-pressure/sm/ But you could find a similar one and use your wiring harness to connect. The website has a configuration tool, if you can decipher the above part number you might get lucky and find what you need. I remember a post on IRV2 a couple years ago, the individual was having the same problem, I tried to go back and find it but no luck. Ultimately he found that the previous owner had tried to attach a wire for a tow brake harness and that was the problem. But I did try and find a new switch with no luck but found you could find similar ones. Link to comment Share on other sites More sharing options...
ktloah Posted March 8, 2023 Share Posted March 8, 2023 Where did you locate the brake switch Mike, I see 2 switches on the firewall above the generator...thanks Link to comment Share on other sites More sharing options...
Thomas Posted March 8, 2023 Author Share Posted March 8, 2023 jacwjames I got 2 switches ordered from a distributor of nason. $36 each.. Not sure if these are the problem but for that price I will replace them anyway, I have sent the control module to M & M RV electronics along with the steering wheel buttons and PCB #3 in the front run bay to be tested to see if any of them are bad.. I have been chasing this gremlin for months now so hoping that one of them are bad, (Have already replaced control module once but maybe it was bad from the place I got it) otherwise I have a wiring issue.. Think I am going to replace the engine brake on/off switch as well just to eliminate on more thing.. Link to comment Share on other sites More sharing options...
Michael Powell Posted March 9, 2023 Share Posted March 9, 2023 Thanks for the update let me know if that fixes your issue... Link to comment Share on other sites More sharing options...
Flyinhy Posted March 9, 2023 Share Posted March 9, 2023 14 hours ago, Thomas said: got 2 switches ordered from a distributor of nason. $36 each.. Thomas, can you take pics of those? I've got an idea which ones they are but not positive Link to comment Share on other sites More sharing options...
David Pratt Posted March 9, 2023 Share Posted March 9, 2023 Just my two cents worth; The two Nason Pressure Switches on the firewall for the brake pedal are different internally. One will be a normally closed (NC)switch that that is part of the cruise control circuit. You also have several other switches that are necessary for the cruise control to function which includes the park brake switch, engine brake?, ABS/traction control. The other Nason Pressure Switch is a normally open (NO)and activates the brake lights only and provides no cruise control function Link to comment Share on other sites More sharing options...
jacwjames Posted March 9, 2023 Share Posted March 9, 2023 (edited) The parts page I have for my coach only lists one part number so I guess if I ever have a problem I'll have to try and remember there might be a difference. Based on photos of other post I know that my wiring/system is different then other coaches, specifically the high coaches above my model. My wiring diagram shows two switches of the both same type. I went ahead and attached a file showing the treadle valve wiring, it will be blurry when you open it, hit CTRL5 to clear it up. I will not pretend to know how it works. 2002 Windsor Treadle valve wiring for cruise cancel.pdf Edited March 9, 2023 by jacwjames Link to comment Share on other sites More sharing options...
Thomas Posted March 9, 2023 Author Share Posted March 9, 2023 Flyinhi, Here is the picture of my switches the top ones are for the brake lights and the bottom ones are for the cruise cancel The part number from the Nason website is SM-2B-5F QC Approx $35.00 each from one of their dealers From Rev Parts their number is Marson 10119027 $135.00 LOL Link to comment Share on other sites More sharing options...
ktloah Posted March 9, 2023 Share Posted March 9, 2023 Thanks Tom for the info and pics! Link to comment Share on other sites More sharing options...
Flyinhy Posted March 10, 2023 Share Posted March 10, 2023 Yes sir! Painted just like mine.....lol, thanks for the info Link to comment Share on other sites More sharing options...
ktloah Posted March 10, 2023 Share Posted March 10, 2023 Tom, where did you order those switches from, and what are they called? Thx Link to comment Share on other sites More sharing options...
Thomas Posted March 11, 2023 Author Share Posted March 11, 2023 Ronnie, You can copy and paste this website address and then look up dealers near you then give them a call and they can order directly from Nason On this page you can basically build the switch you need if you don't have a part number https://www.nasonptc.com/products/switches/low-pressure/sm/?_gl=1*48d2zi*_up*MQ..&gclid=Cj0KCQiAx6ugBhCcARIsAGNmMbg8AE9l0xFVJpiDs92dRszJ_2C9_JmfevI7xp68QcCnJ713wpYKJKIaAlWpEALw_wcB Let me know if that works !! I ordered mine from the dealer below in Ca. Nathan Stalioraitis, Inside Sales 5370 South Watt Ave, Suite 300 Sacramento, CA 95826 Controlled Motion Solutions, Inc., MFCP Company 800-532-8837 phone 800-370-0447 fax Link to comment Share on other sites More sharing options...
