deputylynch Posted September 8 Share Posted September 8 Any suggestions on how to put a specialized outlet in since a shallow box isn't deep enough? The outlet is 1.5"deep, not taking into consideration the wires. I've attempted to use a specialized old work shallow box but it won't fit in the wall since there's a metal backing plate inside and a normal shallow box is only 1.25" deep. I know I can use a surface mount type box or extension but I want to keep it flush and looking original. Link to comment Share on other sites More sharing options...
deputylynch Posted September 8 Author Share Posted September 8 (edited) Any suggestions on how to put a specialized outlet in since a shallow box isn't deep enough? The outlet is 1.5"deep, not taking into consideration the wires. I've attempted to use a specialized old work shallow box but it won't fit in the wall since there's a metal backing plate inside and a normal shallow box is only 1.25" deep. I know I can use a surface mount type box or extension but I want to keep it flush and looking original. Edited September 8 by deputylynch Description change Link to comment Share on other sites More sharing options...
thomasgibbens Posted September 8 Share Posted September 8 Try Googling Electrical Outlet Extension Rings They are available in metal one non-metal and vary in depth. It will stick out some from the face of the wall though. Tom Gibbens ’15 Dynasty Link to comment Share on other sites More sharing options...
deputylynch Posted September 8 Author Share Posted September 8 As I stated in the post I really don't want to use an extension or surface mount box and want to keep the look original, but thanks anyhow. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 8 Share Posted September 8 Is this a new installation or replacing an existing one?? Your only recourse may be using a RV duplex box. Not a fan of those but if installed correctly could last you a long time. Link to comment Share on other sites More sharing options...
Barry W Posted September 8 Share Posted September 8 https://www.amazon.com/HARDWARE-162C-Conventional-Duplex-Receptacle/dp/B0044EX9MY/ref=asc_df_B0044EX9MY/?tag=hyprod-20&linkCode=df0&hvadid=309793588525&hvpos=&hvnetw=g&hvrand=11780820744389421069&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028392&hvtargid=pla-663527344531&psc=1&tag=&ref=&adgrpid=60862048759&hvpone=&hvptwo=&hvadid=309793588525&hvpos=&hvnetw=g&hvrand=11780820744389421069&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028392&hvtargid=pla-663527344531 Link to comment Share on other sites More sharing options...
Dr4Film Posted September 8 Share Posted September 8 May I suggest using TinyURL.com Link to comment Share on other sites More sharing options...
Barry W Posted September 8 Share Posted September 8 Much easier to copy and paste, especially do not know or where to use tiny url. Link to comment Share on other sites More sharing options...
myrontruex Posted September 9 Share Posted September 9 Here you go Barry. Link to comment Share on other sites More sharing options...
cbr046 Posted September 9 Share Posted September 9 These all look like push-in wire connections which contribute to a poor connection, especially over time. I get a "plastic burning smell" from one of my outlets if I plug in an electric heater. Got any with screw-on wire connectors? - bob Link to comment Share on other sites More sharing options...
Dr4Film Posted September 9 Share Posted September 9 33 minutes ago, cbr046 said: These all look like push-in wire connections which contribute to a poor connection, especially over time. I get a "plastic burning smell" from one of my outlets if I plug in an electric heater. Got any with screw-on wire connectors? - bob You won''t find any with his restricted available space other than to go with a surface mount system. Link to comment Share on other sites More sharing options...
Goodtimes Posted September 9 Share Posted September 9 Try PPL, I think they have these type of rv outlets. Link to comment Share on other sites More sharing options...
olywrestle Posted September 10 Share Posted September 10 You could use a surface mount box over the hole such as this. Link to comment Share on other sites More sharing options...
deputylynch Posted September 10 Author Share Posted September 10 I appreciate everybody's input but in my original posting I stated I do not want to go with a box extension or surface mount. I want to keep it flush and looking original. Link to comment Share on other sites More sharing options...
Steve Merritt Posted September 11 Share Posted September 11 I am an electrician and have been my whole life and I installed these outlets in our Executive but it took some patience, I am assuming it is the outlets with the phone charging ports on them, you will have to get the gray plastic PVC "handy box" from Home Depot. Next you will have to decide how to attach them you can either buy some metal cut in boxes and rob the ears off of the top and bottom and then use F clips to hold them in the wall or you can make side holders out of wood if you prefer but it depends on the thickness of the wall if they will hold up. https://www.homedepot.com/p/Carlon-1-Gang-12-cu-in-Gray-PVC-New-Old-Work-Handy-Box-B112HBR/202077374?source=shoppingads&locale=en-US&pla&mtc=SHOPPING-CM-CML-GGL-D27-027_006_CONDUIT_FIT-NA-NA-NA-PMAX-4035595-NA-NA-NA-NBR-NA-NA-NEW-Live&cm_mmc=SHOPPING-CM-CML-GGL-D27-027_006_CONDUIT_FIT-NA-NA-NA-PMAX-4035595-NA-NA-NA-NBR-NA-NA-NEW-Live-71700000113799906--&gclid=EAIaIQobChMIm9GJ76ahgQMVop5aBR354g68EAQYAiABEgJerfD_BwE&gclsrc=aw.ds#overlay F clips https://www.homedepot.com/p/Box-Conduit-Fitting-Accessory-1-Gang-Rectangle-Metal-Electrical-Box-Cover-820D1U-25R/202590854 https://www.homedepot.com/p/Steel-City-1-Gang-3-in-x-2-in-Old-Work-Metal-Electrical-Switch-Box-LXOW-25R/202591749 Link to comment Share on other sites More sharing options...
windsorbill06 Posted September 14 Share Posted September 14 On 9/10/2023 at 6:50 AM, deputylynch said: I appreciate everybody's input but in my original posting I stated I do not want to go with a box extension or surface mount. I want to keep it flush and looking original. Is the specialized plug your talking about, USB outlets? You could put back the original plug, and daisy chain a new romex over to an area that has the depth to allow for the deeper box (maybe side of cabinet, as an example). Both would be flush mounted/original and you'd still have several outlets for different uses. Link to comment Share on other sites More sharing options...
