jmcnamer Posted July 3, 2020 Share Posted July 3, 2020 I'm experiencing a loss of water pressure after 2-3 minutes in the shower. As you can imagine, it's quite frustrating. When I check the pressure at the city water hose, it's fine. My pressure regulator is fine. If I wait 3-4 minutes the pressure returns then I have 2-3 minutes and they cycle repeats. I also tried unhooking from city water and using the pump. My pump sounds labored but still creates pressure. Any ideas? Thanks, Jody P.S. I just replaced my two stage water filters as well. Link to comment Share on other sites More sharing options...
John Haggard Posted July 3, 2020 Share Posted July 3, 2020 Do you have a screen filter just before the pump ? Only a issue when using the DC. Pump Also Do you have the same issue with your faucet? And Pressure regulator's can be a pain. Link to comment Share on other sites More sharing options...
Hanabc Posted July 3, 2020 Share Posted July 3, 2020 I had a problem somewhat like this and it was mineral scale build up in the water lines and aquahot. The dealer where we fixed it spent quite a while flushing the lines with vinegar to loosen the deposits and reflush with vinegar multiple times. Not saying this is your problem but this remedy cured our problem. Link to comment Share on other sites More sharing options...
jmcnamer Posted July 3, 2020 Author Share Posted July 3, 2020 It happens when I'm on city water as well as when I'm on the DC pump. I took off the pressure regulator. Same issue. I have not checked the screen filter before the pump, as I thought all of the water goes through the two stage filter. Is the screen located at the pump? I'm not sure that would affect the city water intake, but I'm willing to try anything at this point. Thanks very much for the response. Jody I can try flushing the lines as well. It wouldn't hurt. Jody Link to comment Share on other sites More sharing options...
Dennis H Posted July 3, 2020 Share Posted July 3, 2020 Where the city water hooks into your coach there is a backflow device. These sometimes fail. I installed a 90 degree fitting so the hose wouldn't be suspended and installed a screen inside that fitting. You'd be surprised at what collects in that screen. I replace it once, sometimes twice a year. Protects against the crud collecting in the backflow valve and gumming it up. I'd check that first, followed by the screen before your water pump.....Dennis Link to comment Share on other sites More sharing options...
jmcnamer Posted July 4, 2020 Author Share Posted July 4, 2020 Thanks for the reply's. Sorry for the greenhorn question. I have a plumbing diagram, but where exactly is the water pump located? I see the hatch were the plumbing manifold resides as well as the pressure tank, but not locating the DC pump. Thanks for the help. Jody Link to comment Share on other sites More sharing options...
Ivan K Posted July 4, 2020 Share Posted July 4, 2020 I would think that you would hear at least some vibrations when it is running, with an open faucet and maybe locate it that way? It is gonna be feeding the filters from the tank somewhere... Link to comment Share on other sites More sharing options...
Dr4Film Posted July 4, 2020 Share Posted July 4, 2020 Does this happen at every water faucet or just the shower? I always have both the onboard water pump switch on whether I am hooked to shore water supply or not. That way I always have good water pressure. 1 Link to comment Share on other sites More sharing options...
willbo777 Posted July 4, 2020 Share Posted July 4, 2020 Could be your check valve. Link to comment Share on other sites More sharing options...
dl_racing427 Posted July 5, 2020 Share Posted July 5, 2020 This sounds like sediment clogging a screen or valve. Look anywhere that sediment could get swept into a restriction, and then fall off when the flow is stopped for a short time. This could be at a screen, check valve, or possibly at the shower valve itself, if that is the only outlet affected. Link to comment Share on other sites More sharing options...
