Patrick Posted August 1, 2021 Share Posted August 1, 2021 How does one replace these pot lights? I have one that is not working. Do you pull off or unscrew the cover ring? Anybody know what the replacement bulb is? Absolute Newbie here. Link to comment Share on other sites More sharing options...
HarleyR Posted August 1, 2021 Share Posted August 1, 2021 Grab the glass and turn counter clockwise. Use a jar lid grip cloth to get a decent grip if needed. The bulb is a halogen two prong. I replaced the 37 bulbs in mine with LEDs. Link to comment Share on other sites More sharing options...
Land Lubber Posted August 1, 2021 Share Posted August 1, 2021 Harley....Two questions.....do these bulbs just pull straight out & are the LED's you used dimmable as are the halogen bulbs? I understand that the new bubs should be handled with a tissue rather than touching them directly. Link to comment Share on other sites More sharing options...
cbr046 Posted August 1, 2021 Share Posted August 1, 2021 Right. Avoid skin contact as the skin oils can crack the glass when heated by the bulb (so they say). And most LEDs aren't dimable (not sure why). - bob Link to comment Share on other sites More sharing options...
Land Lubber Posted August 1, 2021 Share Posted August 1, 2021 (edited) I have one out in our '09 Camelot that we bought last year so I was "listening in" for an answer to Patrick's question as to what bulb is needed. Edited August 1, 2021 by Land Lubber Goofed! Link to comment Share on other sites More sharing options...
Patrick Posted August 1, 2021 Author Share Posted August 1, 2021 1 hour ago, HarleyR said: Grab the glass and turn counter clockwise. Use a jar lid grip cloth to get a decent grip if needed. The bulb is a halogen two prong. I replaced the 37 bulbs in mine with LEDs. Thanks! Link to comment Share on other sites More sharing options...
Gary M Posted August 1, 2021 Share Posted August 1, 2021 I bought half of my 30+ led’s from cabin bright as a test as the 30+ I bought from Amazon died within two months. Its been over a year now and only two have failed. 100% guaranteed so soon I will test that and buy the rest. 1 Link to comment Share on other sites More sharing options...
Dennis H Posted August 1, 2021 Share Posted August 1, 2021 (edited) A couple of suggestions. First is the ring around the puck light is held on by tabs. Turning the ring will line up the tabs and the ring can be removed. The glass then is held in place by three small plastic tabs. Use caution not to break any of those tabs. When you press the tabs, make sure you don't drop the glass cover on the floor and break it. Just do things slowly. Now here's another 'tip'. If the ring is difficult to turn it might be 'stuck' to the ceiling material. Using the edge of a credit card, insert it under the ring and move it completely around the ring, then try to twist it. Also pushing upward while turning may make it easier. The bulbs are G4 bi pin halogen. I dislike the heat from the lamps so I changed all mine out to LEDs. If you want to use a dimmer you'll have to buy LED dimmable bulbs or stay with the halogen. I kept the halogen over the sofa and desk and changed out all the overheads. The issue with LEDs is size. Most are too long to fit the puck lights. The ones I purchased are in the link below. They are a hair longer than the halogens but they fit easily into the pucks with no modification. No flicker, and they are really bright. I tried the warm light and didn't like them so I went with the daylight ones.....hope this helps....Dennis https://www.amazon.com/Halogen-Equivalent-Daylight-Non-dimmable-CHEERBEE/dp/B089R8HKH7/ref=sr_1_17_sspa?crid=1OSXDV7YL9BYR&dchild=1&keywords=g4+led+bulb+12v&qid=1627788872&sprefix=g4+%2Caps%2C236&sr=8-17-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyOENPWDE1V1c0TEVWJmVuY3J5cHRlZElkPUEwNDIzNTQ3M1VBRlFUNlZSSEg1NSZlbmNyeXB0ZWRBZElkPUEwMDg0NTEzMkhUUlo1MU4zRllBTSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= Edited August 1, 2021 by Dennis H Link added Link to comment Share on other sites More sharing options...
JDCrow Posted August 1, 2021 Share Posted August 1, 2021 I bit the bullet and replaced them all. All new fixtures. These are dimmable https://www.ebay.com/itm/Facon-3Inch-12V-LED-RV-Puck-Light-LED-Down-Light-with-Magnet-Metal-Trim-2W-/303046078787?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 Link to comment Share on other sites More sharing options...
Dennis H Posted August 1, 2021 Share Posted August 1, 2021 6 minutes ago, JDCrow said: I bit the bullet and replaced them all. All new fixtures. These are dimmable https://www.ebay.com/itm/Facon-3Inch-12V-LED-RV-Puck-Light-LED-Down-Light-with-Magnet-Metal-Trim-2W-/303046078787?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&m$krid=711-127632-2357-0 12 dollars a pop is expensive! 12 X 44 = $528.00 plus tax !!! Bulbs are 14 bucks for 10. Wow! Link to comment Share on other sites More sharing options...
Patrick Posted August 1, 2021 Author Share Posted August 1, 2021 Awesome help! Thanks everyone! 51 minutes ago, Dennis H said: A couple of suggestions. First is the ring around the puck light is held on by tabs. Turning the ring will line up the tabs and the ring can be removed. The glass then is held in place by three small plastic tabs. Use caution not to break any of those tabs. When you press the tabs, make sure you don't drop the glass cover on the floor and break it. Just do things slowly. Now here's another 'tip'. If the ring is difficult to turn it might be 'stuck' to the ceiling material. Using the edge of a credit card, insert it under the ring and move it completely around the ring, then try to twist it. Also pushing upward while turning may make it easier. The bulbs are G4 bi pin halogen. I dislike the heat from the lamps so I changed all mine out to LEDs. If you want to use a dimmer you'll have to buy LED dimmable bulbs or stay with the halogen. I kept the halogen over the sofa and desk and changed out all the overheads. The issue with LEDs is size. Most are too long to fit the puck lights. The ones I purchased are in the link below. They are a hair longer than the halogens but they fit easily into the pucks with no modification. No flicker, and they are really bright. I tried the warm light and didn't like them so I went with the daylight ones.....hope this helps....Dennis https://www.amazon.com/Halogen-Equivalent-Daylight-Non-dimmable-CHEERBEE/dp/B089R8HKH7/ref=sr_1_17_sspa?crid=1OSXDV7YL9BYR&dchild=1&keywords=g4+led+bulb+12v&qid=1627788872&sprefix=g4+%2Caps%2C236&sr=8-17-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyOENPWDE1V1c0TEVWJmVuY3J5cHRlZElkPUEwNDIzNTQ3M1VBRlFUNlZSSEg1NSZlbmNyeXB0ZWRBZElkPUEwMDg0NTEzMkhUUlo1MU4zRllBTSZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= Super useful help. Thank you! Link to comment Share on other sites More sharing options...
KevinH Posted August 1, 2021 Share Posted August 1, 2021 I replaced mine three years ago and purchased them on eBay I have had zero failures. As far as removing them. Most of them I was able to turn the glass and replace them. I hade four or five that I had to pry down with a putty knife and pull them out of the ceiling.They also work as a dimmer. I have three puck lights underneath the hall vanity that I forgot to replace I could never figure out why my middle air conditioner would run all the time during the day. Finally figured out that the three vanity lights we’re producing enough heat to kick on the air conditioner because the sensor for the air conditioner is underneath right by the vanity lights. Replaced them with LED never had that issue again. https://www.ebay.com/itm/YITAMOTOR-10-50X-G4-Base-Pin-Reading-Marine-Boat-LED-Light-Bulbs-Pure-Warm-White-/251621202168?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 Link to comment Share on other sites More sharing options...
Patrick Posted August 1, 2021 Author Share Posted August 1, 2021 3 minutes ago, KevinH said: I replaced mine three years ago and purchased them on eBay I have had zero failures. As far as removing them. Most of them I was able to turn the glass and replace them. I hade four or five that I had to pry down with a putty knife and pull them out of the ceiling.They also work as a dimmer. I have three puck lights underneath the hall vanity that I forgot to replace I could never figure out why my middle air conditioner would run all the time during the day. Finally figured out that the three vanity lights we’re producing enough heat to kick on the air conditioner because the sensor for the air conditioner is underneath right by the vanity lights. Replaced them with LED never had that issue again. https://www.ebay.com/itm/YITAMOTOR-10-50X-G4-Base-Pin-Reading-Marine-Boat-LED-Light-Bulbs-Pure-Warm-White-/251621202168?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 Thanks for the tip! Link to comment Share on other sites More sharing options...
JDCrow Posted August 1, 2021 Share Posted August 1, 2021 Yeah, they are not cheap. We had bright brass and wanted a bit more modern, clean look. 1 Link to comment Share on other sites More sharing options...
SigPIlot Posted August 2, 2021 Share Posted August 2, 2021 (edited) I replaced the halogen bulb only with an LED replacement bulb IN 2017. Kept the original receptacle. The retrofit Samsung LED's plug right in. Think I bought about 80. Dimmable and come in ww, cool w, natural. I used warm white on the wood surfaces and natural light everywhere else (galley, heads, closets). Had no problems so far. M4products. com. Good service, located in Chatsworth, CA. Edited August 2, 2021 by SigPIlot Link to comment Share on other sites More sharing options...
Patrick Posted August 2, 2021 Author Share Posted August 2, 2021 26 minutes ago, SigPIlot said: I replaced the halogen bulb only with an LED replacement bulb IN 2017. Kept the original receptacle. The retrofit Samsung LED's plug right in. Think I bought about 80. Dimmable and come in ww, cool w, natural. I used warm white on the wood surfaces and natural light everywhere else (galley, heads, closets). Had no problems so far. M4products. com. Good service, located in Chatsworth, CA. Thanks! Link to comment Share on other sites More sharing options...
Gary M Posted August 2, 2021 Share Posted August 2, 2021 On 8/1/2021 at 7:13 AM, KevinH said: I replaced mine three years ago and purchased them on eBay I have had zero failures. As far as removing them. Most of them I was able to turn the glass and replace them. I hade four or five that I had to pry down with a putty knife and pull them out of the ceiling.They also work as a dimmer. I have three puck lights underneath the hall vanity that I forgot to replace I could never figure out why my middle air conditioner would run all the time during the day. Finally figured out that the three vanity lights we’re producing enough heat to kick on the air conditioner because the sensor for the air conditioner is underneath right by the vanity lights. Replaced them with LED never had that issue again. https://www.ebay.com/itm/YITAMOTOR-10-50X-G4-Base-Pin-Reading-Marine-Boat-LED-Light-Bulbs-Pure-Warm-White-/251621202168?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0 Wow those are the ones I bought first and all failed. They all started flashing like strobe lights one by one after two months. Link to comment Share on other sites More sharing options...
Moonwink Posted August 2, 2021 Share Posted August 2, 2021 (edited) I just tried the ebay link shared above and that listing has been removed = "This listing was ended by the seller because there was an error in the listing." I replaced all my high heat output halogen fixtures (both the puck lights and bullet lights) with these from Command Electronics a couple of years ago.https://www.amazon.com/Command-Electronics-Camper-Trailer-Utility/dp/B07X9C3L7T/ I've been very happy with the additional light I get from these and when they're too much, I can turn off one or two of them by pressing the switch button in the center. 10 fixtures for $37 and free delivery. You can't hardly find the bulbs for that. Edited August 2, 2021 by Moonwink Link to comment Share on other sites More sharing options...
GypsyJo Posted April 9 Share Posted April 9 While on the subject of replacement light bulbs, I am trying to find the 2 pin tiny light bulbs for my coach and keep being the incorrect size. My coach is 2006 Camalot. Can your help me? Thanks Link to comment Share on other sites More sharing options...
JDStew Posted April 10 Share Posted April 10 Hi Joanne - If you can put a picture of the fixture and bulb, it will help us ensure we're giving you accurate info. Best! Link to comment Share on other sites More sharing options...
Gary M Posted April 11 Share Posted April 11 I got my G4’s from Cabin Bright.com. https://www.cabinbright.com/ Call Joe and he will take care of you. I have had failures and he replaced them with no hesitation. Link to comment Share on other sites More sharing options...
GypsyJo Posted April 11 Share Posted April 11 On 4/10/2022 at 7:48 PM, JDStew said: Hi Joanne - If you can put a picture of the fixture and bulb, it will help us ensure we're giving you accurate info. Best! Link to comment Share on other sites More sharing options...
cbr046 Posted April 12 Share Posted April 12 This is what I bought to replace some burned out bulbs. https://www.amazon.com/gp/product/B01LZGG79L/ - bob Link to comment Share on other sites More sharing options...
GypsyJo Posted April 12 Share Posted April 12 20 hours ago, cbr046 said: This is what I bought to replace some burned out bulbs. https://www.amazon.com/gp/product/B01LZGG79L/ - bob Thank you. Link to comment Share on other sites More sharing options...
Woody O Posted April 13 Share Posted April 13 On 7/31/2021 at 8:08 PM, Patrick said: How does one replace these pot lights? I have one that is not working. Do you pull off or unscrew the cover ring? Anybody know what the replacement bulb is? Absolute Newbie here. For replacing the bulb and not the fixture. I've tried several different LED's. The one I like best, is Kohree LED Replacement G4 at 2 watts Natural White, #HP459-US. It is medium priced, but it lasts for years. It 4000 K in brightness, so can use about anywhere. I get them on Amazon. Just unplug old and plug in new. Link to comment Share on other sites More sharing options...
