Norman Austin Posted August 19, 2021 Share Posted August 19, 2021 Holiday Rambler Neptune 2004 I had a mechanic check why my fuel gauge isn't working. He says that both the sender and the gauge in the dash are bad. Does anyone know where I can find a sender unit and possibly a replacement gauge? I need the sender unit but I could fit an after market gauge if necessary. Also the generator doesn't start though it did start when I bought the coach last month. I wonder if it uses a separate battery from the chassis batteries. I'm a total newbie trying to find out the ins and outs of this machine. Thanks guys. Norman Link to comment Share on other sites More sharing options...
Jim Bob Posted August 19, 2021 Share Posted August 19, 2021 regarding the genset, it should use the chassis batteries for starting. No prior experience with the fuel gauge issue. Make sure you have at least a third tank of fuel as it will have a shut off so you can not run the tank dry while camping with the genset running. More info on what the generator is doing would help. turns over but does not start. starts but quits, etc, etc. Link to comment Share on other sites More sharing options...
cbr046 Posted August 19, 2021 Share Posted August 19, 2021 I don't know if you get a fault code for a non-starting unit but the light in the generator switch will blink for any fault codes, then look in the manual to troubleshoot. There's 2 sets of blinks giving you a 2 digit fault code. Details are in the manual. As for the fuel gauge and sending unit . . . . I might get a second opinion. What are the odds both would go bad at the same time? - bob Link to comment Share on other sites More sharing options...
Fonman Posted August 19, 2021 Share Posted August 19, 2021 Does the fuel gauge stay past full when you turn the key off? Link to comment Share on other sites More sharing options...
Norman Austin Posted August 19, 2021 Author Share Posted August 19, 2021 Yes, the photo of the fuel gauge above was taken with the engine off. It doesn't move from that position at all. The guy who sold me the MH said that sometimes it works, but since I have had it there has been no change. Re the generator not starting, I turned on the ignition and pressed the lower end of the button a few times with no reaction, then it blinked 3 times and went off. When I press the top part of the button to start, nothing at all happens. Link to comment Share on other sites More sharing options...
Steven Posted August 19, 2021 Share Posted August 19, 2021 I had the same problem with my fuel gauge. The tech told me my gauge and sender were bad and needed replacement. I changed the sender only and that corrected the problem. fuel gauge reads perfectly. Steve. 2004 Monaco Windsor 40DST Link to comment Share on other sites More sharing options...
IlliniCathy Posted August 19, 2021 Share Posted August 19, 2021 We just replaced our fuel sensor. Here is a link. http://www.centroidproducts.com/ Link to comment Share on other sites More sharing options...
Norman Austin Posted August 19, 2021 Author Share Posted August 19, 2021 Thanks everyone for your helpful advice, and thank you Cathy for the fuel sensor link. Norman Link to comment Share on other sites More sharing options...
Gary Cole Posted August 19, 2021 Share Posted August 19, 2021 Norman I'm somewhat skeptical when a tech decides two components have failed. If you have the Centroid level sensor then I believe that it will be the capacitance variety. Your tech might not be aware of that. Those are difficult to troubleshoot in the traditional manner using a multimeter. The fuel level gauge is of the usual resistance type, 240 ohms empty, 33 ohms full and can be checked by using resistors in a circuit to ground. Interesting bio. Good luck. Link to comment Share on other sites More sharing options...
Norman Austin Posted August 19, 2021 Author Share Posted August 19, 2021 Thank you Gary. I forwarded your advice to the tech. Norman Link to comment Share on other sites More sharing options...
rpasetto Posted August 19, 2021 Share Posted August 19, 2021 +1 on contacting Centroid; they are very helpful. As a quick test you can try disconnecting the wires to the fuel sending unit. Link to comment Share on other sites More sharing options...
Harvey Babb Posted August 20, 2021 Share Posted August 20, 2021 A tip that may apply. some models the generator will not run if fuel is below 1/2 tank. My fuel gauge was intermittent and I finally found a broken ground wire on the sending unit. Link to comment Share on other sites More sharing options...
Norman Austin Posted August 20, 2021 Author Share Posted August 20, 2021 (edited) Thanks Harvey. I followed Bob's advice and found the fault code to be 24 which corresponds to a sensor circuit being either open or shorted. I've informed my mechanic and will take the RV back to him next week to check. I have the wiring diagram so we should be able to find out the cause. RE fuel level, I don't want to put any more fuel in it until we've sorted the fuel tank sender out. I don't know what it involves to replace that but I suspect that removing the old sensor from a full fuel tank would be problematic. Edited August 20, 2021 by Norman Austin Link to comment Share on other sites More sharing options...
Gary Cole Posted August 20, 2021 Share Posted August 20, 2021 Should add one thing regarding the fuel level sensor if it is a Centroid. The unit uses a solid state board to translate capacitance to resistance. Your mechanic should be careful to not short the output leads to ground. Would imagine that the senders are spendy. Link to comment Share on other sites More sharing options...
Norman Austin Posted August 20, 2021 Author Share Posted August 20, 2021 Thanks Gary. I passed that message on too. Link to comment Share on other sites More sharing options...
IlliniCathy Posted August 20, 2021 Share Posted August 20, 2021 We replaced our fuel sensor from the top of the tank. There was a screw on lid in the middle of the coach between the pass thru compartments. Pm us if you need more information. Link to comment Share on other sites More sharing options...
Harvey Babb Posted August 20, 2021 Share Posted August 20, 2021 7 hours ago, Norman Austin said: Thanks Harvey. I followed Bob's advice and found the fault code to be 24 which corresponds to a sensor circuit being either open or shorted. I've informed my mechanic and will take the RV back to him next week to check. I have the wiring diagram so we should be able to find out the cause. RE fuel level, I don't want to put any more fuel in it until we've sorted the fuel tank sender out. I don't know what it involves to replace that but I suspect that removing the old sensor from a full fuel tank would be problematic. Norman, I was actually suggesting that fixing the fuel sensor problem MIGHT also fix the generator start problem. Link to comment Share on other sites More sharing options...
daveyjo Posted August 21, 2021 Share Posted August 21, 2021 My generator manual says :Starting the Generator Push and hold control switch in START position until the generator starts. Release switch. On diesel models the control switch may flash up to 15 seconds, indicating engine preheat. NOTE: Diesel models may require priming. Hold control switch in the OFF position for one minute. Repeat if necessary. The diesel generator fuel pick-up tube is cut to approximately ¼ tank so as not to run the main engine out of fuel. So maybe prime it for a minute. Mine wouldn't start sometimes and gradually got worse until priming wouldn't start it. Turned out the cooling temp sensor was bad. Works beautifully now. Link to comment Share on other sites More sharing options...
Norman Austin Posted August 25, 2021 Author Share Posted August 25, 2021 I just read in the owners manual that if there is water in the bottom of the fuel tank then the fuel gauge will read maximum (over the full mark) and stay there. This is what's happening on my fuel gauge. The guy I bought it off told me that sometimes it reads correctly. I'm thinking that that might used to have been the case but in time more water has got into the tank. I'm arranging for the tank to be drained and will report back my findings. The manual also stated that 90% of senders that are returned to the manufacturer show no faults when bench tested. Link to comment Share on other sites More sharing options...
Gary Cole Posted August 25, 2021 Share Posted August 25, 2021 (edited) Norman, One day you are going to find yourself in the ranks of the respected RV masters when you overcome this latest challenge life has blessed you with. Then you will find yourself attending to the tired, the poor, the hungry, those of whose wives have hidden all sharp objects from. Edited August 25, 2021 by Gary Cole Link to comment Share on other sites More sharing options...
Norman Austin Posted August 26, 2021 Author Share Posted August 26, 2021 I never imagined these things could be so complicated. When I lived in the UK I had a home conversion Mercedes RV similar, though a little bigger than the one in the pic. I never had to do anything to it except empty the cassette toilet. Bliss! This is certainly a steep learning curve. That Mercedes took me from North West Scotland (Isle of Skye) to southern Spain and back several times. The only problem I ever had was a blown tire. I eventually sold it for more than I paid. That'll be hard to achieve with the Monaco - lol. Link to comment Share on other sites More sharing options...
