Bill Hines Posted May 10 Share Posted May 10 Went to move the Motorhome last week and saw it leaning port side. Tried dumping air still leaning. Started engine and aired up and it was worse. Did some investigation and found crack in rear rear airbag. Now I need to replace the bag. Trying to find a part number or what bag to purchase. It’s a RR8 chassis, 34’ Dynasty. Any help would be greatly appreciated. Thanks Bill Link to comment Share on other sites More sharing options...
vito.a Posted May 10 Share Posted May 10 Lots of good information and links in this thread: https://www.irv2.com/forums/f115/2002-monaco-dynasty-3-axel-rear-air-bag-leak-577883.html Link to comment Share on other sites More sharing options...
ktloah Posted May 10 Share Posted May 10 Are you sure the bag is leaking? Could be the solenoids for travel mode on your leveling system Link to comment Share on other sites More sharing options...
Bill Hines Posted May 10 Author Share Posted May 10 Yes there is a hole in the bag. Link to comment Share on other sites More sharing options...
streetrodder Posted May 10 Share Posted May 10 Just replaced the rear bags on my 2000 windsor think there the same got them from NAPA W03589376 $260 each direct fit Link to comment Share on other sites More sharing options...
TW Racing Posted May 10 Share Posted May 10 I had the same issue looking for part numbers on my 2008 Cayman, go to REVRVPARTS.com or call the number on the website. They should be able to get that information to you, I was able to get the paint codes for my Rv as well. They are very helpful. Link to comment Share on other sites More sharing options...
Bill Hines Posted May 12 Author Share Posted May 12 (edited) The only way to find Airbag part number was to remove airbag from Motorhome. I began lowering jacks to raise Rv, then set 2, 12 ton jack stands under rear frame. Removed wheel well cover and mud flap. Then battled with removing the 4 nuts that mount airbag to chassis. Final step remove air lines and fitting. Found part number on top of bag. Should arrive in 3 days. Thanks to all the help. Bill Edited May 12 by Bill Hines Link to comment Share on other sites More sharing options...
Ivan K Posted May 12 Share Posted May 12 Looks pretty good except for that one spot. Thats not an original yr 2000, is it? Any idea what happened there? Stuck dirt or rubbing on something? Link to comment Share on other sites More sharing options...
Bill Hines Posted May 12 Author Share Posted May 12 You are right, previous owner had it replaced in 2011. I have no idea. What ever caused it to crack I won’t do it again. I just don’t know what the cause was. It’s been stored indoors most of it’s life. 1 Link to comment Share on other sites More sharing options...
Bill Hines Posted 3 hours ago Author Share Posted 3 hours ago Replaced airbag yesterday and Motorhome is travel ready. Link to comment Share on other sites More sharing options...
