Guest luke harms Posted October 27, 2022 Posted October 27, 2022 Can someone please suggest an aftermarket vender for the AC shrouds. $300 seems like a ridiculous price for a pound of fragile molded plastic! Thanks
Gary 05 AMB DST Posted October 27, 2022 Posted October 27, 2022 I think Amazon has them. Gary 05 AMB DST
Ivan K Posted October 27, 2022 Posted October 27, 2022 I replaced one of ours by Icon from Amazon, something like $150. Much better.
jacwjames Posted October 28, 2022 Posted October 28, 2022 I never replaced mine but I did notice that there were cracks developing around the 4 screws that held the shrouds on. I added additional screws to prevent them from blowing off.
Scotty Hutto Posted October 28, 2022 Posted October 28, 2022 At Chris @throgmartin’s recommendation, I used Icon from Icon Direct. DON’T FORGET to check the little box for “Driver Side Venting” Currently $175 these are thicker and sturdier than the original shrouds https://www.icondirect.com/dometic-penguin-duo-therm-air-conditioner-shroud-pw/
veraken Posted October 28, 2022 Posted October 28, 2022 Here's the link on Amazon for the shrouds With side vent holes ICON Aftermarket A/C Shroud - for Dometic Pengiun Without side vent holes ICON Aftermarket A/C Shroud - for Dometic Penguin - White
Georgia Mike Posted November 29, 2022 Posted November 29, 2022 I lost my middle ac shroud on my original penguin. Does anyone know if this will fit from Amazon ICON Aftermarket A/C Shroud - for Dometic Penguin - White
Scotty Hutto Posted November 29, 2022 Posted November 29, 2022 Yes, that's what I have on the Penguins on my 2006 Diplomat. EDIT: I bought mine from icondirect.com with the holes, per Hex_Nut and Tom’s notes below. At that time they were the same price on Amazon and Icondirect.com.
Bykerboy Posted November 29, 2022 Posted November 29, 2022 I purchased replacements from Amazon as well and they fit perfectly.
hex_nut Posted November 29, 2022 Posted November 29, 2022 Georgia Mike That shroud listed on Amazon from ICON will fit just fine, BUT if you have heat pumps you should use the ones with vent holes in the sides to better vent when in heat pump mode. Richard
Tom Cherry Posted November 29, 2022 Posted November 29, 2022 6 minutes ago, hex_nut said: Georgia Mike That shroud listed on Amazon from ICON will fit just fine, BUT if you have heat pumps you should use the ones with vent holes in the sides to better vent when in heat pump mode. Richard DOUBLE THAT COMMENT. The REAR HP (HVAC), per Dometic, MAY run hotter. It depends on how the duct work runs. This is for the CAMELOT...but the Dometic Tech said that TYPICALLY, the REAR runs HOTTER. In my case, on side side (driver's but can be reversed) the duct runs FULL length. SO, if you turn ON the rear AC FAN with the front AC fan OFF, you get a small amount of air in the middle vents and also in the most forward one near the driver and copilot seats. NOW, on mine, the OTHER side is blocked due to the shower configuration. THUS, if you go to the OTHER side, there is NO air in the center or up front from the Rear AC. That makes the REAR run HOTTER, in the Heat Pump MODE....so venting is VERY IMPORTANT. I actually did, to prove his point and my own curiosity, measure various point on the front and rear....the compressor and the lines were 15 DF or hotter on the rear....and BOTH had been running for an hour and the outside temps were in the mid 40's. SO, pay attention. if your Rear AC will not put out a small amount of air on BOTH sides, then you definitely need the VENTED or the OEM style....otherwise you are heating up the unit...may NOT be an issue, but Dometic said it was or could be could lessen the life....of the rear one..
