rustykramermetalfab Posted September 9, 2020 Share Posted September 9, 2020 I have been searching for a momentary lighted water pump switch that is located in my living room area panel. This is a green rocker type that is momentary. It will "rock" up or down but returns to center. Light is lit when on and no light when off. My light is out so I can't visually check if my water pump is on or not unless I go to the bathroom and check the light. I had a Hose blow out on the pump once so I don't like to leave it on when I am not in the coach. Coach is 2000 Dynasty. Anyone have a source? Link to comment Share on other sites More sharing options...
Pampero Posted September 9, 2020 Share Posted September 9, 2020 rvautopart.com https://www.rvautoparts.com/Rocker-Switches-Illuminated_c_9598.html You want a two way momentary switch https://www.carlingtech.com/rocker-switches-full-size Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2020 Share Posted September 10, 2020 I always use Northwest RV Supply for all of my switch needs as they seem to have the best selection and variety too. Here is their web site address for Switches - http://www.nwrvsupply.com/category/176.html Here is their web site address for the momentary switch you are inquiring about - http://www.nwrvsupply.com/176/12675.html They also carry the RED indicator light that is usually adjacent to the Water Pump switch. Those never lasted very long as they have an incandescent bulb inside. I have since switched those out and now have small LED's in the same place. I had purchased those from the RV shop in Wildwood FL which has changed ownership and is now Lazy Days RV. Not sure if they still carry them or not. Photos of before & after change-out. 3 Link to comment Share on other sites More sharing options...
rustykramermetalfab Posted September 10, 2020 Author Share Posted September 10, 2020 I bought a switch from NWRV supply. It was not the momentary type, physically it looked the same. The NWRV rep told me they have been trying for years to find a supplier to build this switch. Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2020 Share Posted September 10, 2020 6 minutes ago, rusty@kramermetalfab.com said: I bought a switch from NWRV supply. It was not the momentary type, physically it looked the same. The NWRV rep told me they have been trying for years to find a supplier to build this switch. You have to verify that what you are ordering is in fact a momentary switch versus an On/Off switch as they both LOOK the same and have the same number of contacts. Based on Northwest RV Supply's web site I posted above it appears that they found someone to supply the momentary switch as they now have them available. Link to comment Share on other sites More sharing options...
wamcneil Posted September 10, 2020 Share Posted September 10, 2020 7 hours ago, Dr4Film said: I always use Northwest RV Supply for all of my switch needs as they seem to have the best selection and variety too. Here is their web site address for Switches - http://www.nwrvsupply.com/category/176.html Here is their web site address for the momentary switch you are inquiring about - http://www.nwrvsupply.com/176/12675.html They also carry the RED indicator light that is usually adjacent to the Water Pump switch. Those never lasted very long as they have an incandescent bulb inside. I have since switched those out and now have small LED's in the same place. I had purchased those from the RV shop in Wildwood FL which has changed ownership and is now Lazy Days RV. Not sure if they still carry them or not. Photos of before & after change-out. I like that indicator light. Is that a panel-mount LED that you installed in a switch blank, or was it supplied that way with terminals on the back like a switch? Thanks, Walter Link to comment Share on other sites More sharing options...
Dr4Film Posted September 10, 2020 Share Posted September 10, 2020 47 minutes ago, wamcneil said: I like that indicator light. Is that a panel-mount LED that you installed in a switch blank, or was it supplied that way with terminals on the back like a switch? Walter, it was made that way so they snap right into the panel opening exactly where the larger RED light would go. There are also long leads on the back with I think a small resistor heat-shrinked into one lead. I imagine that one could build these easily by using a switch blank, a LED bulb, a resistor, etc. Link to comment Share on other sites More sharing options...
Moonwink Posted September 11, 2020 Share Posted September 11, 2020 LED Resistor Calculator The package the LED comes in will have the specs needed to fill in the blanks on the website linked to above. LEDs are all low voltage and need a resistor to work correctly. The size of the resistor is determined by the the voltage applied and the maximum current the LED can carry. Just plug those numbers into the blanks at the link above and pick the next standard higher resistance size resistor. It's not rocket science and there's a lot of tolerance in picking the right one. LED too bright, use a resistor with a higher resistance. 1 Link to comment Share on other sites More sharing options...
Guest Tim503 Posted September 14, 2020 Share Posted September 14, 2020 I have two switches I took them out. I hooked up the macerator to the circuit and blew out the relay that controls the pump. Be careful as I believe it was over $50 for a new one. I leave mine on all the time. They are not lighted. Mine had separate lights, front panel and bathroom, that should have been replaced with LED. Link to comment Share on other sites More sharing options...
Pepperell Posted December 27, 2020 Share Posted December 27, 2020 I bought a bundle of 100 led’s with resisters and leads already attached. I think I paid $10 or $15. There were 20 each of 5 different colors. You can drill out the back of the existing light assembly and hot melt glue an led in. Or you can drill a small hole in the panel adjacent to the switch and hot melt the led there. The only one that stumped me was the light for the 120v Aquahot switch which was 120v. Maybe neon? I suppose I could have sacrificed a cheapo receptacle tester. Link to comment Share on other sites More sharing options...
Dr4Film Posted December 27, 2020 Share Posted December 27, 2020 16 minutes ago, Pepperell said: The only one that stumped me was the light for the 120v Aquahot switch which was 120v. Maybe neon? I suppose I could have sacrificed a cheapo receptacle tester. Are you positive that your Aqua-Hot switch is 120 VAC? Mine is a Carling Technology 12 VDC switch. Link to comment Share on other sites More sharing options...
Moonwink Posted December 27, 2020 Share Posted December 27, 2020 Just buy new indicator LEDs: https://www.amazon.com/JR-Products-12725-Indicator-Switch/dp/B002UC14SS/ 1 Link to comment Share on other sites More sharing options...
dl_racing427 Posted December 28, 2020 Share Posted December 28, 2020 15 hours ago, Pepperell said: I bought a bundle of 100 led’s with resisters and leads already attached. I think I paid $10 or $15. There were 20 each of 5 different colors. You can drill out the back of the existing light assembly and hot melt glue an led in. Or you can drill a small hole in the panel adjacent to the switch and hot melt the led there. The only one that stumped me was the light for the 120v Aquahot switch which was 120v. Maybe neon? I suppose I could have sacrificed a cheapo receptacle tester. You can calculate the current at 12v based on the resistor, and use a higher value resistor to get the same current at 120v. The AC vs DC won't matter, as the LED will only conduct when forward biased. 1 Link to comment Share on other sites More sharing options...
Pepperell Posted December 28, 2020 Share Posted December 28, 2020 Thanks! Sometime I’ll have to dissect one to see if I can id the resistor. Link to comment Share on other sites More sharing options...
Pepperell Posted December 28, 2020 Share Posted December 28, 2020 22 hours ago, Dr4Film said: Are you positive that your Aqua-Hot switch is 120 VAC? Mine is a Carling Technology 12 VDC switch. That was on my totaled 2003 Dynasty. My current 2006 Dynasty handles this on the multiplex system. Again, that was the 120v element switch. And I could be confused/mistaken! Link to comment Share on other sites More sharing options...
wamcneil Posted December 28, 2020 Share Posted December 28, 2020 20 hours ago, Moonwink said: Just buy new indicator LEDs: https://www.amazon.com/JR-Products-12725-Indicator-Switch/dp/B002UC14SS/ Are the new ones LED? The replacement I bought couple years ago is not LED... Cheers, Walter Link to comment Share on other sites More sharing options...
Moonwink Posted December 28, 2020 Share Posted December 28, 2020 Walter, I think that's about the time they changed over to LEDs. I bought a couple in an RV Supply store behind Love's in Quartzsite about then and had to look at the fine print on the package to make sure I was getting the LED lamps. Resistor Sizing: The link I shared above has all the information needed size a resistor for LEDs and any voltage you want to use them with. It's not that critical. If the LED is too bright, use a stronger resistor. If it's not bright enough, use a smaller resistor. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted December 28, 2020 Share Posted December 28, 2020 30 minutes ago, Pepperell said: That was on my totaled 2003 Dynasty. My current 2006 Dynasty handles this on the multiplex system. Again, that was the 120v element switch. And I could be confused/mistaken! My 120 VAC Element switch is still a low voltage 12 VDC switch but when activated it triggers an additional relay that can handle the 120 VAC current. I have not seen any Aqua-Hot switches that were 120 VAC. Check your manual also. Link to comment Share on other sites More sharing options...
Ivan K Posted December 28, 2020 Share Posted December 28, 2020 3 hours ago, wamcneil said: Are the new ones LED? The replacement I bought couple years ago is not LED... Cheers, Walter I bought a pack of green ones to replace water pump indicators and they are LED 2 hours ago, Dr4Film said: My 120 VAC Element switch is still a low voltage 12 VDC switch but when activated it triggers an additional relay that can handle the 120 VAC current. I have not seen any Aqua-Hot switches that were 120 VAC. Check your manual also. Few years difference and no multiplex but our AH element switch is also 12V and activates a contractor behind breaker box in bedroom. I can easily hear the contractor clicking. Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted December 28, 2020 Share Posted December 28, 2020 1 hour ago, Ivan K said: our AH element switch is also 12V and activates a contractor behind breaker box in bedroom. I can easily hear the contractor clicking. My 03 Windsor is the same, 12v sw with relay in bedroom. Link to comment Share on other sites More sharing options...
Bob Nodine Posted December 29, 2020 Share Posted December 29, 2020 On 12/28/2020 at 5:50 AM, dl_racing427 said: You can calculate the current at 12v based on the resistor, and use a higher value resistor to get the same current at 120v. The AC vs DC won't matter, as the LED will only conduct when forward biased. I believe the AC versus DC does matter in this case because the current will only flow about 50% of the time on AC. To maintain the same brightness the resistor value would need to be reduced about 50%. Link to comment Share on other sites More sharing options...
dl_racing427 Posted December 29, 2020 Share Posted December 29, 2020 3 hours ago, Bob Nodine said: I believe the AC versus DC does matter in this case because the current will only flow about 50% of the time on AC. To maintain the same brightness the resistor value would need to be reduced about 50%. That may be true, however the 120v is an RMS value. The actual peak voltage is around 170v, which may offset the half-wave effect. Either way, the perceived brightness could be tweaked with the resistor value. Link to comment Share on other sites More sharing options...
Harvey Babb Posted December 30, 2020 Share Posted December 30, 2020 On 12/28/2020 at 4:50 AM, dl_racing427 said: You can calculate the current at 12v based on the resistor, and use a higher value resistor to get the same current at 120v. The AC vs DC won't matter, as the LED will only conduct when forward biased. Do NOT use an LED on 120 volts this way. It works as you say on lower AC voltages but an LED is only able to withstand 20 volts or so in reverse before breaking down. Add a diode in series with the resistor that is rated for the voltage to prevent the breakdown. (A 1N4001 is a good choice. Give me an address and I'll be happy to mail one to you.) Link to comment Share on other sites More sharing options...
dl_racing427 Posted December 30, 2020 Share Posted December 30, 2020 1 hour ago, Harvey Babb said: Do NOT use an LED on 120 volts this way. It works as you say on lower AC voltages but an LED is only able to withstand 20 volts or so in reverse before breaking down. Add a diode in series with the resistor that is rated for the voltage to prevent the breakdown. (A 1N4001 is a good choice. Give me an address and I'll be happy to mail one to you.) Thanks Harvey, I wasn't aware of that. I guess If I'd bothered to look up specs I'd have seen it. LOL Link to comment Share on other sites More sharing options...
waterskier_1 Posted December 31, 2020 Share Posted December 31, 2020 On 12/30/2020 at 5:25 AM, Harvey Babb said: Do NOT use an LED on 120 volts this way. It works as you say on lower AC voltages but an LED is only able to withstand 20 volts or so in reverse before breaking down. Add a diode in series with the resistor that is rated for the voltage to prevent the breakdown. (A 1N4001 is a good choice. Give me an address and I'll be happy to mail one to you.) This is not quite true. Granted there is both a maximum forward voltage and reverse voltage at any diode can withstand, that is the purpose if the resistor. Also, please realize that LED stands for Light Emitting Diode. It is a diode, so putting another on in series is either redundant at best, and if put in the opposite direction, the LED would not work. That said, most LED's operate on 1.5 - 2.0 volts. That means that you will be dropping 118 volts (assuming 120 VAC circuit) which is 98% of the voltage. If the diode draws 20 mA (0.020 Amps) that means that the resistor would be around 5.9K Ohms. That resistor would be dissipating about 2.5 Watts which is just wasted energy. There are devices on the market that use electronic circuits to drive LEDs from high voltage (greater than 20 volts). Or, as other have suggested, use a neon or incandescent bulb. Link to comment Share on other sites More sharing options...
