Dr4Film Posted February 2, 2021 Share Posted February 2, 2021 I last replaced my Safe-T-Alert LPG Detector model 40-442-P in January 2016. Well this past month, January 2021, it started with its EOL alert once again. They say that they should be replaced every 5 years and WOW, this thing has pretty good smarts. It knew that it was almost exactly 5 years. Amazing! Ordered a new one on Amazon for about $50. Such a deal! I guess I should check the date on my CO detector in the bedroom as I think I last changed them about the same time. Have to check my maintenance records. Link to comment Share on other sites More sharing options...
Scotty Hutto Posted February 2, 2021 Share Posted February 2, 2021 I wonder if they have some type "timer" circuitry that runs whenever the unit is powered up... Mine too went south almost exactly 5 years after the manufacture date printed on the unit. I replaced the LPG detector, CO detector, and smoke detectors. Cheap insurance, but still I wonder about that timer... maybe they're just trying to "help" us remember to replace them. 🤣 Link to comment Share on other sites More sharing options...
96 EVO Posted February 2, 2021 Share Posted February 2, 2021 Do they continue to beep till you cut power to them? Mine has never gone off, green power lights still on, and I 'think' they are original. Regardless, I've owned the coach about 8yrs. Link to comment Share on other sites More sharing options...
Dr4Film Posted February 2, 2021 Author Share Posted February 2, 2021 The model that is in my coach was flashing 2X's Green followed by 2X's Red and a short beep every so often. You can reset it but after 30 days it has to be replaced. Link to comment Share on other sites More sharing options...
Gary M Posted February 2, 2021 Share Posted February 2, 2021 Mine are original and still working also. My cell is 5 and going wacko. My desktop computer that was a refurbished unit in 2010 keeps on going and going and going. Link to comment Share on other sites More sharing options...
J & Di Cooper Posted February 2, 2021 Share Posted February 2, 2021 Our coach is parked on a pad at our house, hooked to electricity. A couple weeks ago i went inside to put something in the bedroom, while back there heard a BEEP, assumed it was the smoke detector (don't assume stuff), took it off the ceiling on my way out-brought it inside to install a new battery. A few days pass before i take it back to the coach and just as i was securing it to the ceiling....beep.... H'mmm that was not the smoke detector???? look under the kitchen cabinet and see the propane detector flashing the 2 red/2green code. I remember there's some warning information printed on the front, get a flashlight so i can read it and EOL exactly 60 months. Not as lucky as Richard, amazon says 3-4 week lead time, should deliver next week. Agree with Scotty, they must have an internal clock. Choose to enjoy this day. John Hope to see some of you in Perry, I'll be the guy with the mask and parking coaches. Link to comment Share on other sites More sharing options...
Dennis H Posted February 3, 2021 Share Posted February 3, 2021 Mine came with a five year life but 10 year lithium batteries... 🙄 ...Dennis Link to comment Share on other sites More sharing options...
Dr4Film Posted February 3, 2021 Author Share Posted February 3, 2021 Both of my detectors, LPG & CO are hard wired directly to the the house battery and are NOT connected to any switches. My smoke alarm is the only free-standing one that is lithium powered which has a 10 year life for the battery and alarm. Link to comment Share on other sites More sharing options...
Bruce B Posted February 3, 2021 Share Posted February 3, 2021 I have my coach in storage and know that I will have to replace the LPG when I take it out. FYI, I added Nest smoke, carbon monoxide detectors to the basement and interior of the coach which operates of my wifi hot spot and alerts me if there is an issue. I would get an alert well in advance of a potential issue being noticeable to a passerby. Link to comment Share on other sites More sharing options...
Moonwink Posted February 4, 2021 Share Posted February 4, 2021 (edited) From the SafeTAlert 65 Series User's Manual (the LP detector maybe similar): End of Life Signal - The Sensor has a 5 Year Service Life All 65 Series models include an End of Life (EOL) Signal indicating the sensor has reached the end of its service life and you must replace the alarm. The signal is the LED flashing RED RED GREEN GREEN with a beep every 25-30 seconds. The EOL Signal may be reset by pushing TEST / RESET button on the alarm. This will reset the EOL Signal for a period of 72 hours (3 days) for a total of up to 30 days. After 30 days the signal cannot be reset and the alarm must be replaced. DO NOT DISCONNECT THE ALARM UNTIL YOU HAVE A REPLACEMENT ALARM AVAILABLE TO INSTALL. CO - 65_Series.pdf Propane - 40_Series.pdf From https://www.mtiindustries.com/faq/ the Safe-T-Alert website FAQ: How often should safety Alarms be replaced on a RV? Replace your Propane and CO Alarms that are over 5 years old. Only install Propane and CO Alarms that are UL listed for Recreational Vehicle Use. Some CO Alarms or their replaceable CO sensors may have a shorter service life. Check the manufacturer’s owner’s manual for replacement information. Replace your Smoke & Fire Alarms that are over 10 years old. Trouble-shooting Guide Green Operational LED Off 1. Bad Wire Connection 2. Reversed Wiring 3. Main Power Off 4. Missing Or Blown Fuse 5. Contact Customer Service 1-800-383-0269 No Sound When Testing Or No Red Led When Testing Contact Customer Service 1-800-383-0269 Locked In Alarm Contact Customer Service Malfunction Alarm Led Red/Green & Beeps Every 15 Seconds Battery Voltage Is Good And It Will Not Reset To Normal Operation 1. Check Battery Voltage 2. Contact Customer Service 1-800-383-0269 END OF LIFE ALARM Push Reset Button To Reset For 3 Days – Replace Within 30 Days. What do the visual and audible signals on the Alarm mean? Normal Audible Signal: NoneVisual Signal: Steady Green CO Alarm Audible Signal: 4 “Beeps” / 5 Seconds OffVisual Signal: Steady Red Propane Alarm Audible Signal: ConstantVisual Signal: Flashing Red Alarm Malfunction Audible Signal: “Beep” Every 25 SecondsVisual Signal: Alternating Red / Green END OF LIFE SIGNAL Audible Signal: “Beep” Every 25-30 SecondsVisual Signal: Red Red Green Green Flashing Additionally, if the LED lights are blinking on an Alarm that is wired into your RV, your RV battery may be run down. Charge your unit if this occurs. Edited February 4, 2021 by Moonwink Link to comment Share on other sites More sharing options...
Dr4Film Posted February 6, 2021 Author Share Posted February 6, 2021 Just received my new Safe-T-Alert LPG Alarm today from Amazon. The date of MFG. is January 7 2021 so I should be good to go for another 5 years which will take me to 2026. Link to comment Share on other sites More sharing options...
RustyTools Posted March 13, 2021 Share Posted March 13, 2021 I often chuckle with I read about propane-detector problems. I replaced two of them in our Endeavor years earlier than expected because they'd often sound off, and usually at what we thought was random times. That is, til wife noticed it was mounted close to where our dog liked to snooze. Methane is chemically close to propane 🙄 . 2 Link to comment Share on other sites More sharing options...
Dennis H Posted March 14, 2021 Share Posted March 14, 2021 5 hours ago, RustyTools said: I often chuckle with I read about propane-detector problems. I replaced two of them in our Endeavor years earlier than expected because they'd often sound off, and usually at what we thought was random times. That is, til wife noticed it was mounted close to where our dog liked to snooze. Methane is chemically close to propane 🙄 . Which smells better??? Stop feeding your dog refried beans or broccoli..😁😆..Dennis 1 2 Link to comment Share on other sites More sharing options...
Paul A. Posted March 14, 2021 Share Posted March 14, 2021 That's why the Pets bedroom is always by the windshield. Link to comment Share on other sites More sharing options...
dl_racing427 Posted March 14, 2021 Share Posted March 14, 2021 On 3/13/2021 at 3:36 PM, RustyTools said: I often chuckle with I read about propane-detector problems. I replaced two of them in our Endeavor years earlier than expected because they'd often sound off, and usually at what we thought was random times. That is, til wife noticed it was mounted close to where our dog liked to snooze. Methane is chemically close to propane 🙄 . There ya go blaming it on the dog again. LOL Link to comment Share on other sites More sharing options...
Ray Davis Posted March 14, 2021 Share Posted March 14, 2021 6 minutes ago, dl_racing427 said: There ya go blaming it on the dog again. LOL Mans best friend Link to comment Share on other sites More sharing options...
Dennis H Posted March 15, 2021 Share Posted March 15, 2021 7 hours ago, Ray Davis said: Mans best friend Til they fart while the defroster is ON......😁🤣...Dennis Link to comment Share on other sites More sharing options...
