Cubflyer Posted September 5, 2021 Share Posted September 5, 2021 So I'm on the road from SLC to DEN, overnighted at Rawlings, WY ..... arrived there in a rain/hail storm, got on my site and hooked up... water everywhere... This morning as we pulled out the "water low" light came on, I stopped at a local autoparts store on the way to the highway and when I came out with some antifreeze I found out why the light was on.... big puddle and active dripping. Probably leaked all night.... No parts or repair shops in Rawlings so off to Laramie where there was supposed to be a pump. Managed to keep adding water as we go and monitor temps, got to NAPA and they only had one of the two different pumps they showed in stock so I bought the one. I have since looked closely at the new pump and compared it to the installed pump and no way it is the correct pump. Managed to get these numbers off the pulley... 3286293 which crosses to the NAPA pump that was out of stock. Called all the usual local autopart stores and none carry (keep in stock) the cross referenced pump. Hoping I can try NAPA between Laramie and Denver tomorrow and get lucky with one on the shelf. Meanwhile, keeping water in the system I'm going to try to head south tomorrow... anybody think that running mostly tap water for a few hundred more miles will hurt anything as long as I keep water in it?? Ken Link to comment Share on other sites More sharing options...
rvtips Posted September 5, 2021 Share Posted September 5, 2021 1 hour ago, Cubflyer said: So I'm on the road from SLC to DEN, overnighted at Rawlings, WY ..... arrived there in a rain/hail storm, got on my site and hooked up... water everywhere... This morning as we pulled out the "water low" light came on, I stopped at a local autoparts store on the way to the highway and when I came out with some antifreeze I found out why the light was on.... big puddle and active dripping. Probably leaked all night.... No parts or repair shops in Rawlings so off to Laramie where there was supposed to be a pump. Managed to keep adding water as we go and monitor temps, got to NAPA and they only had one of the two different pumps they showed in stock so I bought the one. I have since looked closely at the new pump and compared it to the installed pump and no way it is the correct pump. Managed to get these numbers off the pulley... 3286293 which crosses to the NAPA pump that was out of stock. Called all the usual local autopart stores and none carry (keep in stock) the cross referenced pump. Hoping I can try NAPA between Laramie and Denver tomorrow and get lucky with one on the shelf. Meanwhile, keeping water in the system I'm going to try to head south tomorrow... anybody think that running mostly tap water for a few hundred more miles will hurt anything as long as I keep water in it?? Ken When mine went out,I could only find one at Cummings Link to comment Share on other sites More sharing options...
ncsteve Posted September 5, 2021 Share Posted September 5, 2021 When you say out of stock, was that in the whole Napa system or just that store? If they do have one in the system, I would call the closest to your next stop and order to be there when you arrive. Normally the can get them in a day or two. as for running water, I would think it would be ok for a short time to get by. Them a good flush and fill once repaired. I may add a water pump to my spare parts list. I am sure it is just a matter of time before I will have to change one. 1 Link to comment Share on other sites More sharing options...
klcdenver Posted September 5, 2021 Share Posted September 5, 2021 Ken, You should sign up on Cummins Quick Serve, it is free. You will need your engine serial number when you register. From it you can get part numbers and schematics etc... Good luck. Kenneth Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 Thanks for the replies, NAPA part search was while in Rawlings, they said Laramie had one, not sure the search extended beyond that. NAPA in Laramie, where I'm at, is closed today but stores in Colorado open at 9 today and I will be calling them.... and even if they do not have it on their shelf, maybe they can get one soonest. I will sign up for the Cummins Quick Serve.... but I have to find my s/n. As for continuing running with filling water every 20 miles, we are re-evaluating that idea... may get a rental car and chase the part with that and just hit the only campground in town for a few days.... they were booked up for last night so we spent the night in a truck parking lot. Ken Link to comment Share on other sites More sharing options...
WayneC Posted September 5, 2021 Share Posted September 5, 2021 Morning it is a tough call to make, if it was ME I would have stayed close to the first Napa I came to, try to find a camp site and or stay in a parking lot close by where I could have access to LOTS of parts/tools. I just returned from the east coast (Canada) in my 2010 Dodge 6,7 L pulling my 5000lb boat, got up in the morning and same thing (water pump) called the Dealership and they took it in, Napa had the pump there in a few hours, it was not even worth the stress or getting my hands dirty for $ 550.00 for water pump,new belt and labor. I am doing a turn around and back to the east coast at the end of the month,this time with the coach pulling my 2010 Dodge Crew cab Cummins Diesel, fingers crossed that we have no issues , if I do I am going to make a cup of coffee and make a plan, find a Cummins dealership /shop and limp it in. I am very hesitant to drive any distance with a failing water pump. Just being Wayne Wayne 1999 Signature Caesar Link to comment Share on other sites More sharing options...
Ivylog Posted September 5, 2021 Share Posted September 5, 2021 Running straight water to get to Denver will not hurt anything. I would leave the the cap off so hopefully, you loose less water. Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 It is leaking profusely with no cap and even with the engine off.... decided to park it here in Laramie until fixed. I'll be doing a lot of walking unless I find a rent-a-car.. Wayne, Note to self... do not breakdown in Rawlings, WY .... very limited resources. I hope things work out as good as that for me. Link to comment Share on other sites More sharing options...
klcdenver Posted September 5, 2021 Share Posted September 5, 2021 Laramie has on O'Reilly auto parts that should be open. 307-721-3030. Laramie FBO #307-742-4165 they show courtesy cars, maybe they would rent or let you use one. Kenneth 1 Link to comment Share on other sites More sharing options...
WayneC Posted September 5, 2021 Share Posted September 5, 2021 31 minutes ago, Cubflyer said: It is leaking profusely with no cap and even with the engine off.... decided to park it here in Laramie until fixed. I'll be doing a lot of walking unless I find a rent-a-car.. Wayne, Note to self... do not breakdown in Rawlings, WY .... very limited resources. I hope things work out as good as that for me. Thanks, good luck, it always works out. Wayne 1999 Signature Caesar Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 Kenneth, I've tried O'Reilly's and no joy... great idea on the airport car, I had not thought of that... sometimes it pays to be a pilot..! Ken Link to comment Share on other sites More sharing options...
Rikadoo Posted September 5, 2021 Share Posted September 5, 2021 Mornin everybody, so earlier this summer one of the cooling system repairs was to replace my original water pump, i had used my “esn” to order the pump thru a truck shop. The one i recieved was so different looking i took it back to have them verify or to “recheck” there part, in case it was boxed wrong cause its such a pita to assemble. They came back an told me the original design had been updated soooo many times since the original was released, so i installed it and HUH! It was the right one. In the pictures the one on the right is the original, and i ordered mine thru a HD truck shop. Cause the amount of issues i had trying to get the correct tensioner thru napa was such a disaster, which i eventually quit them, cause they were getting pissy with me due to there special orders were all wrong. 1 Link to comment Share on other sites More sharing options...
Rikadoo Posted September 5, 2021 Share Posted September 5, 2021 By the way the damage from running water in place of coolant has already begun, hot engine vs dropping level of water, plus the cavitation = rust on the cylinder walls and erosion on all the wrong gaskets. With Ford diesel engines when ever a customer brought there truck in for repair an they had used water we had special chemicles we had to use to stop the rusting / flaking process that had already begun. After you replace your WP, remember to replace your coolant filter and to use a quality cummins approved coolant “100k” in fact i would recommend Running the concentration over the 50/50% just cause you have a straight water concentration thru out the system right now. One more thing is the thermostat, if its original, its not that much more work and it would be a shame to have to loose the coolant you just put one in. I understand all this “emergency” type of repair is alot when your just wanting to get back on the road, however these are not the engines we have in the family grocery Getters, and there longevity Dictates a certain process. 1 Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 Rik, Great info and photos. Any chance you have the part number handy of the "new" style pump you installed? (you have the same year and model coach I have, and your old pump looks just like mine) Thanks, Ken Link to comment Share on other sites More sharing options...
Rikadoo Posted September 5, 2021 Share Posted September 5, 2021 Hey Ken, so it appears i have the info in my files in the coach, im heading there shortly an will read you the PN off my invoice. In the mean time i went to the cummins part catalog its saying for my ESN (46279317) the pn is a 3286293 which reading the supersession list is the Original that was installed, which has been superseded over 5 times to what is being shown is now a 3804927 So like i said i will go get whats writtin on my invoice. 2 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted September 5, 2021 Share Posted September 5, 2021 3 hours ago, Rikadoo said: Mornin everybody, so earlier this summer one of the cooling system repairs was to replace my original water pump, i had used my “esn” to order the pump thru a truck shop. The one i recieved was so different looking i took it back to have them verify or to “recheck” there part, in case it was boxed wrong cause its such a pita to assemble. They came back an told me the original design had been updated soooo many times since the original was released, so i installed it and HUH! It was the right one. In the pictures the one on the right is the original, and i ordered mine thru a HD truck shop. Cause the amount of issues i had trying to get the correct tensioner thru napa was such a disaster, which i eventually quit them, cause they were getting pissy with me due to there special orders were all wrong. Rik W, Tell me about pulling the radiator. Was it a time consuming project? Gary 05 AMB DST Link to comment Share on other sites More sharing options...
klcdenver Posted September 5, 2021 Share Posted September 5, 2021 Ken, I think if you drop your exhaust system from after the turbo you probably can get to it with out removing radiator. At least I can on my 400ISL. It should only be 3 clamps and it should drop all in one piece. Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 Kenneth, and others, We are at a Loves here in Laramie, they found a pump at Freightliner (thanks to Rik's post and photos). They are scheduling me into the shop in the morning. I do not believe the radiator/intercooler/other radiators need to come out to get to the pump, but I'm not going to be doing the work..... I did not bring enough tools to be sure I would not come up one wrench or pry bar short. I believe working thru the closet manhole, that the wire shroud can come loose (maybe a couple of bolts from underneath), rotate out of the way and then get to the tensioner, once the belt is off, remove the tensioner, get to the bolts on the water pump and R&R. But, again that's my guess, and how I would try first before 'digging' my way in from the back..... Link to comment Share on other sites More sharing options...
Cubflyer Posted September 5, 2021 Author Share Posted September 5, 2021 Here is what a bad water pump leak can look like... Engine off, not hot, no cap on system waterpumpLEAK.MOV waterpumpLEAK.MOV Link to comment Share on other sites More sharing options...
Rikadoo Posted September 6, 2021 Share Posted September 6, 2021 So Ken i went out to my mh an took the number of my reciept, it was pn 5579024 which i purchased from Fleetpride. Hope all this helps, please let me know how it works out. Good luck a remember the water filter👍 Link to comment Share on other sites More sharing options...
Rikadoo Posted September 6, 2021 Share Posted September 6, 2021 Yeah the radiator was not fun doing out in the sun, 100 degree days i started out just doing the radiator. However i figured while i was already there… t stat, w.pump, fan blades, rebuilt the alternator, new hoses, belt an tensioner then mounted two valves going toward the heater core so when that day comes around i can just turn off both an cut the water going to the heater. Its not that it was overly dificult, however there were many pieces that had to come off 1st, then go back on in the same order. The most difficult part was the new radiator was just enough different that “modifications” had to be made to the shroud in order for it to fit. The radiator was heavy enough that it took two guys to lift it in an out, it is soooo nice now when pulling a grade an the the temperature gauge shows so much cooler. If i had to get to the water pump i would remove the wire screen, then the tensioner then the water pump, not easy but theres not many options otherwise. Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted September 6, 2021 Share Posted September 6, 2021 Rik, I give you so much credit to do that project. Does your 03 have the eight air bag suspension? I'm trying to determine when the Endeavors started with the 8 air bag because my 05 Ambassador was the first year for the 8 air bag. Basically my Ambassador is a downgraded Endeavor with the same platform. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
frankogrly Posted September 6, 2021 Share Posted September 6, 2021 Endeavor with 8 air bags started in 2001. That was the first year it was built on the Roadmaster chassis. Frank O 01 Endeavor Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted September 6, 2021 Share Posted September 6, 2021 Thanks Frank. For some reason I thought it started in 04. That opens up new territory that I should be following advice for. Gary 05 AMB DST Link to comment Share on other sites More sharing options...
Dr4Film Posted September 6, 2021 Share Posted September 6, 2021 This thread is a great advertisement for Coach-Net Emergency Roadside Service. If you or anyone who runs the roads would have had Coach-Net, a simple phone call they would have dispatched a tow company with the proper sized tow truck to haul your coach to a proper repair facility which would replace your pump and hopefully they would have had one in stock. Or could have gotten one over-nighted to your location. Plus the good part is that the tow no matter how many miles they would have towed you to the repair facility would only cost you just a signature. Link to comment Share on other sites More sharing options...
