amphi_sc Posted October 6, 2021 Share Posted October 6, 2021 Where's the best source for a matching aluminum wheel? Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2021 Share Posted October 6, 2021 There are two brands used by Monaco, Accuride & Alcoa. Look in the Monacoers Parts List for more information. Link to comment Share on other sites More sharing options...
Paul J A Posted October 6, 2021 Share Posted October 6, 2021 1 hour ago, amphi_sc said: Where's the best source for a matching aluminum wheel? You did not state if you wanted New, or Used, so i thought you may have success at one of these sources. I called Accuride when i upgraded my tire size to 315's and they were very helpful and provided the information i requested. RV Parts & Salvage Yards https://bontragers.com ; http://www.paramountautobody.com/reno-nevada-used-rv... www.rvdoctorgeorge.com https://colawrvsalvage.com/, https://www.veurinksrv.com/ https://www.rvyard.com/ findmyrvparts.com 1 Link to comment Share on other sites More sharing options...
jacwjames Posted October 6, 2021 Share Posted October 6, 2021 There should be make/PN stamped on your current rim. Once I got the part number, it was an Accuride rim) I just did an internet search and bout one on line. Best price I found at the time was from Florida Shores Truck Center I bought one back in 2009 prior to going to AK, carried a mounted spare. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 6, 2021 Share Posted October 6, 2021 A few things to keep in mind when purchasing aluminum rims. Most rims are Not polished on Both sides. Therefore when rotating tires, you have to dismount, turn over, and remount tires when moving from axle to axle. The openings in the rims are unique to Monaco only. Don't know if Monaco used the same rims on Beaver coaches. The inner rims on the rear axle is made from steel. Rotating tires can be an expensive cost. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
bftownes Posted October 6, 2021 Share Posted October 6, 2021 34 minutes ago, Chuck B said: A few things to keep in mind when purchasing aluminum rims. Most rims are Not polished on Both sides. Therefore when rotating tires, you have to dismount, turn over, and remount tires when moving from axle to axle. The openings in the rims are unique to Monaco only. Don't know if Monaco used the same rims on Beaver coaches. The inner rims on the rear axle is made from steel. Rotating tires can be an expensive cost. Chuck B 2004 Windsor I have NEVER heard of anyone rotating motorhome tires, nor have I heard it recommended.. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 6, 2021 Share Posted October 6, 2021 Rotating tires on a coach has come up several times in the past decade. I Never say Never. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Ivylog Posted October 6, 2021 Share Posted October 6, 2021 (edited) 2 hours ago, amphi_sc said: Where's the best source for a matching aluminum wheel? Good luck finding a matching oval hole new rim as they are very scarce… going used from a RV salvage yard is about your only choice. Edited October 6, 2021 by Ivylog Link to comment Share on other sites More sharing options...
Dr4Film Posted October 6, 2021 Share Posted October 6, 2021 8 minutes ago, bftownes said: I have NEVER heard of anyone rotating motorhome tires, nor have I heard it recommended.. 5 minutes ago, Chuck B said: Rotating tires on a coach has come up several times in the past decade. I Never say Never. Chuck B 2004 Windsor Sounds like a James Bond movie. I say "to each their own". I personally will never rotate tires nor would I recommend it. If someone is rotating tires to compensate for a tire wear problem then I say FIX the problem. Moving used tires from the steers to the tag axle seems to make sense to me but to dismount and rotate tires around the coach is a waste of money in my opinion. Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted October 6, 2021 Share Posted October 6, 2021 I would not either. I am just posting what problems one might have if they rotate their tires. Chuck B 2004 Windsor Link to comment Share on other sites More sharing options...
Ivan K Posted October 6, 2021 Share Posted October 6, 2021 When I was looking for a spare rim, I found a used one and polished it back to shiny life from http://www.rivervalleytruckparts.com/ Link to comment Share on other sites More sharing options...
vito.a Posted October 6, 2021 Share Posted October 6, 2021 Monaco used Accuride wheels with a proprietary hole shape. In 2009 Accuride stopped making the Monaco style wheels. Some coaches came with coated wheels and some with a bare polish finish. XP= high polish, SP= standard polish, and adding a "C" after makes it coated. If you have 295/80-R22.5 tires, the wheels are 8.25" wide X 22.5" diameter. In 2009, the coaches with 315 front tires came with 9" wide X 22.5 wheels. https://www.accuridecorp.com/ Link to comment Share on other sites More sharing options...
Happycarz Posted October 21, 2021 Share Posted October 21, 2021 To the OP, you can call these folks to see if they have a match for you. https://fleetwheel.com Link to comment Share on other sites More sharing options...
