Venturer Posted November 27, 2023 Share Posted November 27, 2023 (edited) Where are the jacking/lift points on the Roadmaster chassis with air leveling? I assume the axles, but does one rely on the air bags to remain inflated to change a tire? Edited November 27, 2023 by Venturer Link to comment Share on other sites More sharing options...
JDCrow Posted November 27, 2023 Share Posted November 27, 2023 I’ve Always use the axles Link to comment Share on other sites More sharing options...
Dr4Film Posted November 27, 2023 Share Posted November 27, 2023 When changing tires they lift on the axles evenly from side to side so the body doesn't get tweak. You can raise the body on the air bags then block the frame from the chassis to prevent it from lowering. 1 Link to comment Share on other sites More sharing options...
Venturer Posted November 28, 2023 Author Share Posted November 28, 2023 Thanks. It was the chassis to frame area to block that I was wondering about. I won't be doing any changing, however, I want to know where in the event it's needed. I'd like to know it's being done correctly and safely. 1 Link to comment Share on other sites More sharing options...
Guest Ray Davis Posted November 28, 2023 Share Posted November 28, 2023 Some guys want to put a jack in the center of the axle & lift both sides with one jack, don't let them do that, it can bend an axle. Even the front axle. Link to comment Share on other sites More sharing options...
jacwjames Posted November 28, 2023 Share Posted November 28, 2023 27 minutes ago, Ray Davis said: Some guys want to put a jack in the center of the axle & lift both sides with one jack, don't let them do that, it can bend an axle. Even the front axle. X2 on this, unstable and the coach could tilt. When I had my tires changed they used two bottle jacks, one under each side. 1 Link to comment Share on other sites More sharing options...
Venturer Posted November 28, 2023 Author Share Posted November 28, 2023 (edited) Then you rely on the air suspension to keep the body up? There must be body support places to support it for changing air bags. Edited November 28, 2023 by Venturer Link to comment Share on other sites More sharing options...
dl_racing427 Posted November 28, 2023 Share Posted November 28, 2023 My coach has jacks instead of air leveling. For long term storage, I raise it on the jacks, and place properly rated jack stands under the chassis, then retract the jacks to protect the rams from corrosion. This keeps weight off the airbags and tires, and to lift a tire only requires a regular floor jack under the axle. Look for points on the chassis that the suspension ties into, and that have vertical members running up to the main rails for strength. Link to comment Share on other sites More sharing options...
Venturer Posted November 28, 2023 Author Share Posted November 28, 2023 Thanks, I'll do some searching. After several coaches, this is my first one without jacks and my first Roadmaster chassis. 1 Link to comment Share on other sites More sharing options...
MHRookie Posted November 29, 2023 Share Posted November 29, 2023 You don’t need to support between the chassis & house frame to change tires. As mentioned, the use of 2 jacks is most important to lift coach equally on both sides under the axle. 1 Link to comment Share on other sites More sharing options...
Venturer Posted November 29, 2023 Author Share Posted November 29, 2023 2 hours ago, MHRookie said: You don’t need to support between the chassis & house frame to change tires. As mentioned, the use of 2 jacks is most important to lift coach equally on both sides under the axle. I realize that, which is what I would do. However, I like to use a safety backup for the "just in case" event a jack would fail. I don't want the body coming down on myself or a service man. Maybe it's not needed, but it only takes one time to ruin one's day, or worse. 1 Link to comment Share on other sites More sharing options...
Michael Powell Posted November 29, 2023 Share Posted November 29, 2023 I made 8ea 2x2 square tubes with saddle on each end and put them next to each air bag then lower the coach on them... When I get back to the toy barn I will take pictures of them with measurements. Seam to work great... 3 Link to comment Share on other sites More sharing options...
MHRookie Posted November 29, 2023 Share Posted November 29, 2023 59 minutes ago, Venturer said: I was only referring to the event you don't need to go under the coach to change tires. When I get under the coach, I drive it up on "DIY" ramps or I would really prefer the square tube method that Michael will be providing us when he gets pictures posted. Link to comment Share on other sites More sharing options...
Venturer Posted November 29, 2023 Author Share Posted November 29, 2023 Thanks. I've built the ramps in the past, but they're gone. The square tube support sounds like the answer to what I want. 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted November 29, 2023 Share Posted November 29, 2023 I have two one foot sections of PT 4x4 which I place between the rails and the frame body after it has been raised up on the air bags. I release the air from the bags which secures the 4x4 in place. That allows me to easily crawl under the coach and work on various locations. 2 Link to comment Share on other sites More sharing options...
Solution Venturer Posted November 29, 2023 Author Solution Share Posted November 29, 2023 (edited) 55 minutes ago, Dr4Film said: I have two one foot sections of PT 4x4 which I place between the rails and the frame body after it has been raised up on the air bags. I release the air from the bags which secures the 4x4 in place. That allows me to easily crawl under the coach and work on various locations. That is what I need. So 12" is the correct length? Edited November 29, 2023 by Venturer Link to comment Share on other sites More sharing options...
Paul Brown Jr Posted December 24, 2023 Share Posted December 24, 2023 i need a picture of thesept4x4 tools On 11/29/2023 at 11:09 AM, Michael Powell said: I made 8ea 2x2 square tubes with saddle on each end and put them next to each air bag then lower the coach on them... When I get back to the toy barn I will take pictures of them with measurements. Seam to work great... send me the pictures to brownjrpaulj@yahoo.com. thanks Link to comment Share on other sites More sharing options...
Michael Powell Posted January 1 Share Posted January 1 Ok got pictures of 2x2" tubing here are the pictures of what I use...The only modification I would do is use the wide u bracket on both sides put one at each air bag and let the air out of the air bags... 3 minutes ago, Michael Powell said: Ok got pictures of 2x2" tubing here are the pictures of what I use...The only modification I would do is use the wide u bracket on both sides put one at each air bag and let the air out of the air bags... If you have any questions inbox me.. Michael and Terry Powell mpowell@powellwatson.com 20231216_151006.heic 20231216_151001.heic 20231216_150951.heic 20231216_150845.heic 1 1 Link to comment Share on other sites More sharing options...
Paul Brown Jr Posted January 1 Share Posted January 1 can you send these pictures to: brownjrpaulj@yahoo.com ? thanks On 11/29/2023 at 11:09 AM, Michael Powell said: I made 8ea 2x2 square tubes with saddle on each end and put them next to each air bag then lower the coach on them... When I get back to the toy barn I will take pictures of them with measurements. Seam to work great... please send the pictures to my email: brownjrpaulj@yahoo.com, thanks Link to comment Share on other sites More sharing options...
Twomed Posted January 1 Share Posted January 1 4 inch square tube 5/16 wall 11 inches tall. Two points having had mine for 15 years now. A)I know and saw 4x wood split...not mine B) A friend made his 12...with just a little uneven ground one side got stuck. Hyd jack in there to get a little lift...not fun. C) This info for tag axle RR10 chassis only. D) They fit neatly laid down next to the 150 gallon fuel tank so you can have fun on the road occasionally too! Happy New Year Link to comment Share on other sites More sharing options...
Paul Brown Jr Posted January 1 Share Posted January 1 17 hours ago, Michael Powell said: Ok got pictures of 2x2" tubing here are the pictures of what I use...The only modification I would do is use the wide u bracket on both sides put one at each air bag and let the air out of the air bags... If you have any questions inbox me.. Michael and Terry Powell mpowell@powellwatson.com 20231216_151006.heic 644.93 kB · 28 downloads 20231216_151001.heic 521.68 kB · 13 downloads 20231216_150951.heic 822.95 kB · 11 downloads 20231216_150845.heic 483.99 kB · 11 downloads I can not open these downloads, Please send the pictures to my email: brownjrpaulj@ yahoo.com or message me at 321-443-6168, Thanks 1 Link to comment Share on other sites More sharing options...
MHRookie Posted January 2 Share Posted January 2 7 hours ago, Paul Brown Jr said: can you send these pictures to: brownjrpaulj@yahoo.com ? thanks please send the pictures to my email: brownjrpaulj@yahoo.com, thanks I emailed you 2 of the 4 titled “Monaco braces”. Since he said he’d make both ends 3”, you don’t need the other 2 pictures. Link to comment Share on other sites More sharing options...
Trevor and Laura Posted January 2 Share Posted January 2 Good Morning, I am also unable to open those pictures and would really appreciate having them as jpegs, email is qcktvr2@gmail.com Many thanks Trevor Topley 1 Link to comment Share on other sites More sharing options...
MHRookie Posted January 2 Share Posted January 2 Moderator, I was able to open the files above and attach as .jpeg. If that’s not allowed please remove. Since the OP of the pictures attached them here, I assumed that is consent to share. 2 Link to comment Share on other sites More sharing options...
Trevor and Laura Posted January 2 Share Posted January 2 Thank You for the pictures and description, did you consider using thinner tubing, 5/16in seems prtetty hefty, but no doubt very safe. Regards, Trevor Link to comment Share on other sites More sharing options...
