StillRunning_60 Posted February 24 Share Posted February 24 Are there any new type locks for the glass sliding closet doors. Tired of replacing the old plastic locks Link to comment Share on other sites More sharing options...
bklaes Posted February 24 Share Posted February 24 I use broomsticks in the floor channels. Not too elegant, but keeps them shut. 1 Link to comment Share on other sites More sharing options...
96 EVO Posted February 24 Share Posted February 24 May want to post a pic of what you have. I believe they changed design over the years. Link to comment Share on other sites More sharing options...
MurrayD Posted February 24 Share Posted February 24 We use the Burglabar lock, simple, cheap, and effective. Check it on Amazon. Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 24 Share Posted February 24 If you have SEA (Shower Enclosures of Anerica), you can order new latches. The design is improved and they work great. Picture would be great also Link to comment Share on other sites More sharing options...
Dr4Film Posted February 24 Share Posted February 24 I had replaced so many of those cheap plastic latches in my previous Windsor that I finally gave up. I went to Amazon or Target and purchased two brass colored spring loaded adjustable closet/shower rods. I place those into the lower track and those doors will not move a cm now. Easy peasy! Link to comment Share on other sites More sharing options...
Bobkat11208 Posted February 24 Share Posted February 24 3 hours ago, bklaes said: I use broomsticks in the floor channels. Not too elegant, but keeps them shut. Similar. DW found square dowel to fit in channels. Cut to length and added string to easily remove. Got tired of messing with the old locks (and I use that word loosely). 😀 Link to comment Share on other sites More sharing options...
MyronTruex Posted February 25 Share Posted February 25 This simple plastic flip over latch has worked for years on ours. It flips flat when not needed. A simple flip and it goes into a 90 degree angle and blocks the one door while holding the other. latch Sliding Closet.pdfCloset latches supplier.pdf Link to comment Share on other sites More sharing options...
veraken Posted February 25 Share Posted February 25 X2 on above. This is what I purchased. https://www.amazon.com/gp/product/B00I8OH1VQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
J Goddard Posted February 26 Share Posted February 26 Here is a picture of the SEA (Shower Enclosures of America) Travel Latch (PN 9000TL-SA). I installed these several years ago when I replaced the plastic latches. In addition to the Travel Latch I also have a Southco Grabber Door Latch on the back side of each door. The combination seems to provide an effective solution. Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 26 Share Posted February 26 8 hours ago, J Goddard said: Here is a picture of the SEA (Shower Enclosures of America) Travel Latch (PN 9000TL-SA). I installed these several years ago when I replaced the plastic latches. In addition to the Travel Latch I also have a Southco Grabber Door Latch on the back side of each door. The combination seems to provide an effective solution. That what Monaco used on my Camelot. Two caveats. 1. make sure the hanging hardware is tight and locked…as in nuts and screws tight. 2. Install and get it centered both horizontal and vertical. Only issues I have had was sliding door sagging and the mating snap catches will break. Parts readily available… Link to comment Share on other sites More sharing options...
96 EVO Posted February 26 Share Posted February 26 13 hours ago, J Goddard said: Here is a picture of the SEA (Shower Enclosures of America) Travel Latch (PN 9000TL-SA). I installed these several years ago when I replaced the plastic latches. In addition to the Travel Latch I also have a Southco Grabber Door Latch on the back side of each door. The combination seems to provide an effective solution. I have the SEA latches. Replaced one broken plastic piece, and it's replacement never survived the first weekend 😖! I used hardwood blocks to make my own. Still working well after many years! Link to comment Share on other sites More sharing options...
Tom Cherry Posted February 26 Share Posted February 26 1 hour ago, 96 EVO said: I have the SEA latches. Replaced one broken plastic piece, and it's replacement never survived the first weekend 😖! I used hardwood blocks to make my own. Still working well after many years! Very resourceful. I had to ADD a 1/2” block to the facing on the interior (one that is clesest to the closet). That gave me a surface to screw in the latch. I’ve replaced them about 8 years ago…one was OK, but door dropped down and it was not properly aligned and mating. They don’t like to copulate at odd angles… Link to comment Share on other sites More sharing options...
Happycarz Posted February 28 Share Posted February 28 I’m like Ben, build your own. 1 1 Link to comment Share on other sites More sharing options...
