saflyer Posted May 1 Share Posted May 1 A recent article in RVTravel.com was about a water check valve that went bad. The issue came to light when the fresh water tank was emptied while driving down the highway when the pump was left on, the valve failed and the water was pumped out the fresh water hose. Their advice is to carry a spare. My questions are do I have that valve and if so where is it located? Actually, I can’t imagine how the plumbing would be designed to connect the fresh water fill hose to the pump. I’d think they would be very separate. 2005 HR Ambassador Link to comment Share on other sites More sharing options...
jacwjames Posted May 1 Share Posted May 1 My coach has one that is part of the Swann "City Fill" valve. Mine started to fail, allowing the pump to put water back into the fresh water tank, I didn't loose any water but the pump started to cycle on a very rare frequency!! Here is the Swan Quick fill valve https://swanindustries.com/collections/retail-customer/products/copy-of-wsv150st-quick-water-fill You can see the check valve on the left side of the block. Here is the check valve I bought, check around for the best price, I paid ~$14 3 years ago, much higher now. https://jrproducts.net/product/62195/ 1 Link to comment Share on other sites More sharing options...
cbr046 Posted May 1 Share Posted May 1 (edited) There's a valve on both hot and cold water circuits for dumping / winterizing the lines. If either CW or HW are left open and pump is on it will empty the tank. Not a failure item IMO. edit - OK, didn't consider higher end coaches. Endeavor / Diplomat are pretty basic. - bob Edited May 1 by cbr046 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 1 Share Posted May 1 Every coach can be plumbed differently. it is the owners responsibility to research their own coach as to how it is plumbed and wired. What may be correct for one coach may not necessarily be how it is plumbed or wired in ALL coaches. That was one of the very FIRST things I did once we got our Dynasty back home from Salt Lake City. As a result I found that the consignment dealership had mis-installed and mis-wired the two GFCI Circuit Breakers in my main power panel. That mistake could have cost us one of our lives! I also found that there was no water check valve on the inlet side of the shore water hose when the water pump is active. I generally have the water pump on ALL the time regardless of whether we are hooked to shore water or not. 2 Link to comment Share on other sites More sharing options...
Benjamin Posted May 1 Share Posted May 1 Exactly. The plumbing is always connected, there is one pressure water system, that supplies the cold and hot sides that go to the bath and kitchen. The pump comes on, that will flow out the city water connection if it can, the check valve is the only thing keeping the water from running backwards out the city water connection unless there's a manual valve or plug that you use in addition to the check valve. Even IF you bought the RV new, it could be different from the next one on the assembly line. I purchased a very well used RV from a very meticulous owner, and still find obvious mistakes from the factory that were never identified in 100k miles and who knows how many hundreds or thousands of hours of working on the various systems. Quality control and reliability on RV's are not even in the same universe as cars and most other consumer products these days. 3 Link to comment Share on other sites More sharing options...
saflyer Posted May 1 Author Share Posted May 1 2 hours ago, Dr4Film said: Every coach can be plumbed differently. it is the owners responsibility to research their own coach as to how it is plumbed and wired. What may be correct for one coach may not necessarily be how it is plumbed or wired in ALL coaches. That was one of the very FIRST things I did once we got our Dynasty back home from Salt Lake City. As a result I found that the consignment dealership had mis-installed and mis-wired the two GFCI Circuit Breakers in my main power panel. That mistake could have cost us one of our lives! I also found that there was no water check valve on the inlet side of the shore water hose when the water pump is active. I generally have the water pump on ALL the time regardless of whether we are hooked to shore water or not. OK, I'll keep looking for it but not exactly sure where to look. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 1 Share Posted May 1 23 minutes ago, saflyer said: OK, I'll keep looking for it but not exactly sure where to look. OK... using your cell phone UNDER the panel where the FILL VALVE is...so you can see behind....Shoot a Picture. Otherwise, a WISE investment (less than $30 ) is a SPY CAM with a 6 ft semi rigid probe. I changed out a heater fan in my GS's GF's Ford Escape last night. Had watched the YouTube and pulling apart plastic panels and such on a car is something that I will do...carefully and have experience on maybe 10 different cars over the years. I had to use my camera to see WHERE the hidden one (in the rear and up) was and then guided my Torx bit into the recess. If you had one of this....ODDS ARE...your Check Valve is attached to the City Fill Valve. That is how MOST Monaco's or at least the ones that I have read about or seen or such have. The system is simple. A standard Fill Valve is just a TWO WAY valve. Monaco attached a Check to the side of it. There was a guy out west that had cornered the market and bought up the OEM valves and the OEM Checks. Probably $30 total. He SOLD the completed OEM Monaco assembly for $85 or so. I passed. He may STILL be out there or is listed on some OTHER forums.... not here, I think. SO, do some detective work. Have you read the WATER section (6 or so...memory) in the manual. It usually has details. SOME manuals actually have a schematic at the end. Your Manual, Research and Google will usually, in that order, solve 75% of the questions here.... Past that....then tap into the knowledge base here... Let us know what you find during the "Exploratory" phase.... Link to comment Share on other sites More sharing options...
96 EVO Posted May 1 Share Posted May 1 Stopped travelling with the water pump on many years ago after reading a thread on IRV. Owner of a brand spanking new, top of the line Tiffin, on it's maiden voyage! Owner didn't know anything was wrong till his first stop, a wave of about 50gal of fresh water rushed to the front of the coach 😮! 1 Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 1 Share Posted May 1 1 minute ago, 96 EVO said: Stopped travelling with the water pump on many years ago after reading a thread on IRV. Owner of a brand spanking new, top of the line Tiffin, on it's maiden voyage! Owner didn't know anything was wrong till his first stop, a wave of about 50gal of fresh water rushed to the front of the coach 😮! That's a BIG 10-4, BUDDY. Never leave on the water pump whilst driving. Turn on and off if someone is cooking or needs to wash their hands when MH is moving. Just chiming in and PILING ON to a good piece of advice... 1 Link to comment Share on other sites More sharing options...
Dr4Film Posted May 1 Share Posted May 1 3 hours ago, saflyer said: OK, I'll keep looking for it but not exactly sure where to look. Or, you may be looking for something that you don't even have in your coach. Link to comment Share on other sites More sharing options...
jacwjames Posted May 1 Share Posted May 1 On some coaches they mounted the valve behind the white panel in the wet bay, other times they mounted it on the outside. And or they could have used a standard water valve and just put a check valve in the line between the fitting you attach your water hose to and the valve. In my case the valve is mounted on the outside of the white panel, but to be able work on it I removed. They put finger nuts on the water lines behind the panel so I could reach up behind and unscrew the two finger nuts. I then was able to put the valve in a vise to hold it so I could replace the check valve, which on the left side of the valve. Link to comment Share on other sites More sharing options...
Tom Cherry Posted May 1 Share Posted May 1 1 minute ago, jacwjames said: On some coaches they mounted the valve behind the white panel in the wet bay, other times they mounted it on the outside. And or they could have used a standard water valve and just put a check valve in the line between the fitting you attach your water hose to and the valve. In my case the valve is mounted on the outside of the white panel, but to be able work on it I removed. They put finger nuts on the water lines behind the panel so I could reach up behind and unscrew the two finger nuts. I then was able to put the valve in a vise to hold it so I could replace the check valve, which on the left side of the valve. Sometimes you ought to thank whatever power or such that you respect, for the charmed life of having easy access to the “USUAL” Monaco madness. Too many here, based on reading posts for 15 years are in my boat. My “white” panel was put in my an 800 pound trained mammal. It has to be warped with the strength of an “ATLAS”. Most folks that have issues must pull it out. But even after removing all the peripherals, then it has to be bent and wedged in. I know maybe 5 or so Camelot owners…..one or two finally got a weight lifter or such to bend it….and the others split it with a saw and then reconnected with s plastic or aluminum strap or plate. I used my phone (technically in today’s vernacular “up skirt” and saw the whole mess. One of these days, I’ll use my probe or spy cam and video it. Ease pr access and Serviceability are not terms to be used. That is why, I adamantly use a washing machine screen filter and flush my hose and the faucet prior to hookup… Link to comment Share on other sites More sharing options...
Georgia Mike Posted May 1 Share Posted May 1 I always put a cap on the end of my fresh water power reel hose end. If the check valve fails it won’t empty your tank when your driving down the road. Link to comment Share on other sites More sharing options...
Bill R Posted May 2 Share Posted May 2 10 hours ago, jacwjames said: On some coaches they mounted the valve behind the white panel in the wet bay, other times they mounted it on the outside. And or they could have used a standard water valve and just put a check valve in the line between the fitting you attach your water hose to and the valve. I installed a 1/4 turn ball valve in between the fresh water hook up and 3-way valve. Easy to access and I keep it closed if I am not hooked up to shore power. Just an option if it does not already exist. Link to comment Share on other sites More sharing options...
Donflem Posted May 8 Share Posted May 8 I just replaced the check valve on my Dynasty a few weeks ago. I was able to get to it without removing anything. I went through the slide out tray compartment. Don Link to comment Share on other sites More sharing options...
Georgia Mike Posted May 8 Share Posted May 8 It’s always fun laying down inside there trying to reach behind yourself for tools and such 😄 I feel like a contortionist. Link to comment Share on other sites More sharing options...
trailmug Posted July 8 Share Posted July 8 On 5/8/2024 at 2:14 PM, Donflem said: I just replaced the check valve on my Dynasty a few weeks ago. I was able to get to it without removing anything. I went through the slide out tray compartment. Don Mind sharing where I can get one of those? Thanks, Rob Link to comment Share on other sites More sharing options...
Donflem Posted July 8 Share Posted July 8 I got it from a mobile mechanic. It was made by Campco I wouldn’t recommend it it leaks back a little. Don Link to comment Share on other sites More sharing options...
willbo777 Posted July 8 Share Posted July 8 6 hours ago, trailmug said: Mind sharing where I can get one of those? Thanks, Rob I just got several from RVupgrades. Sit down before you look they have certainly gone up in price. Link to comment Share on other sites More sharing options...
BennieH Posted July 8 Share Posted July 8 I had my panel out of our 03 Camelot and it was fun getting it out, but it wasn’t the worst. It was actually harder putting it back in and lining the screw holes back up. while I was working on it redid some of the Pex lines to make things easier to get out and change valves, etc. Link to comment Share on other sites More sharing options...
Tom Cherry Posted July 8 Share Posted July 8 30 minutes ago, BennieH said: I had my panel out of our 03 Camelot and it was fun getting it out, but it wasn’t the worst. It was actually harder putting it back in and lining the screw holes back up. while I was working on it redid some of the Pex lines to make things easier to get out and change valves, etc. Bob, you may be a newbie or a well respected and experienced MH’er. If I could elevate your stature….even though your post count is low…I WOULD. Anyone that has successfully removed the 09 (maybe older and definitely newer) Camelot/Scepter SERVICE WHITE PANEL…and lived to tell about it and fixed whatever and got is back in, without sawing it in half, vertically….has my esteemed DIY admiration…. Please give a few tips as well as any pictures and what was wrong and any mods. I have photographed mine from the bottom as well as run a lighted spy cam up behind it….and hope I NEVER have to do, or attempt, what you did. Thanks in advance…. Link to comment Share on other sites More sharing options...
georgecederholm Posted July 8 Share Posted July 8 I had one of those gray plastic Camco ones, fortunately relatively easy to access. When mine started un-backflow-preventing I replaced it with a PVC residential version from Home Depot. I relocated it to an easier spot to access and built it into the plumbing for my portable water softener that I made space for in the bay (theft prevention). Link to comment Share on other sites More sharing options...
Dr4Film Posted July 8 Share Posted July 8 A simple Two-Way Y Valve with 2 shut-offs on the end of my shore hose solved the failed check valve and I didn't have to be any kind of contortionist or take anything apart. When hooked to the shore water spigot, I have an extra bib to hookup my long garden hose for washing the coach, etc. When stowed, both shut-offs are closed. No leaks whatsoever. 1 Link to comment Share on other sites More sharing options...
BennieH Posted July 8 Share Posted July 8 1 hour ago, Tom Cherry said: Bob, you may be a newbie or a well respected and experienced MH’er. If I could elevate your stature….even though your post count is low…I WOULD. Anyone that has successfully removed the 09 (maybe older and definitely newer) Camelot/Scepter SERVICE WHITE PANEL…and lived to tell about it and fixed whatever and got is back in, without sawing it in half, vertically….has my esteemed DIY admiration…. Please give a few tips as well as any pictures and what was wrong and any mods. I have photographed mine from the bottom as well as run a lighted spy cam up behind it….and hope I NEVER have to do, or attempt, what you did. Thanks in advance…. Tom, I did it on a real warm day so things were a bit more flexible. Didn't take any pictures because it was pretty warm and I had it facing the sun for additional help. I did reach behind and was able to remove all the water lines before working on the panel. Biggest thing was adding some length to the existing water lines so it was easier to reconnect after the panel was back in. I also replaced the plastic water connectors with brass ones and new rubber seals. I pulled the panels out to put in a better water pump and redo the bay heater. Link to comment Share on other sites More sharing options...
LilGTO71 Posted July 9 Share Posted July 9 I have two check valves. One before and one after the Ball Selector Lever for fresh water fill or city water. Replaced both in about 15 min. Link to comment Share on other sites More sharing options...
