millionroy Posted March 30, 2021 Share Posted March 30, 2021 I am curious how others clean the radiator/intercooler on a HR Endeavor with a Cummins 330. I have sprayed the Extreme Green solution from the closet access as well as from beneath the coach, spraying afterward with a water hose. I find this a really questionable method and still can't believe an engineer would place the radiator/intercooler in a place so exposed to dirt/dust/oil/engine/blowby/whatever!! Link to comment Share on other sites More sharing options...
Dr4Film Posted March 30, 2021 Share Posted March 30, 2021 After doing my research for almost one year, the two main reasons for purchasing the 2002 Windsor were the side radiator and the semi-monocoque chassis. Some folks here have been very successful in cleaning a rear radiator so I am sure they will chime in soon. Link to comment Share on other sites More sharing options...
RVSSNAKE Posted March 30, 2021 Share Posted March 30, 2021 That is how I clean my except I use a power washer with the tip set to 45 and don't get any closer than 3-4' or from what I understand the pressure used too close could damage components. I went from not being able to see any light through it to seeing allot of light and the engine running cooler. Allow the engine to cool down completely, make sure you let the Simple Green sit for 15-20 minutes and then spray again and let set for a a few minutes then spray. You may have to do this a couple or three times to get it mostly cleared if you haven't done it before. I put a large piece of carboard underneath to catch the debris and it was nasty when I was done. Link to comment Share on other sites More sharing options...
Robert U Posted March 30, 2021 Share Posted March 30, 2021 I have a shop nearby that cleans them with a steam cleaner. Bob U 2000 Dip Link to comment Share on other sites More sharing options...
Scotty Hutto Posted March 30, 2021 Share Posted March 30, 2021 9 minutes ago, Robert U said: I have a shop nearby that cleans them with a steam cleaner. Bob U 2000 Dip Bob, is that our buddy on Canton Rd? Link to comment Share on other sites More sharing options...
Paul A. Posted March 30, 2021 Share Posted March 30, 2021 Put a light on the engine side of the radiator at NIGHT and you will what you missed. Link to comment Share on other sites More sharing options...
Harvey Babb Posted March 30, 2021 Share Posted March 30, 2021 I spray "Gunk SC" on the engine side, wait for at least 30 minutes, then spray from the outside at a car wash. As stated above, don't get too close with the high pressure or you can damage the radiator. Link to comment Share on other sites More sharing options...
Dennis H Posted March 30, 2021 Share Posted March 30, 2021 Remember whatever 'degreaser' you choose to use, make sure it's designed for aluminum. These posts mention Simple Green as the most used item. That will kill your radiator. Simple Green Pro HD is PURPLE and is safe for aluminum. Some words of advice : READ THE LABELS BEFORE USING ANYTHING TO CLEAN YOUR RADIATOR. Dennis Link to comment Share on other sites More sharing options...
Chuck B 2004 Windsor Posted March 30, 2021 Share Posted March 30, 2021 Glad you posted that. My air conditioner repairman DOES NOT RECOMMEND using the standard Simple Green on air conditioner coils. Chuck B Link to comment Share on other sites More sharing options...
Robert U Posted March 30, 2021 Share Posted March 30, 2021 5 hours ago, Scotty Hutto said: Bob, is that our buddy on Canton Rd? Hey Scott. Yes it is. Jacks Diesel Link to comment Share on other sites More sharing options...
RVSSNAKE Posted March 30, 2021 Share Posted March 30, 2021 7 hours ago, RVSSNAKE said: That is how I clean my except I use a power washer with the tip set to 45 and don't get any closer than 3-4' or from what I understand the pressure used too close could damage components. I went from not being able to see any light through it to seeing allot of light and the engine running cooler. Allow the engine to cool down completely, make sure you let the Simple Green sit for 15-20 minutes and then spray again and let set for a a few minutes then spray. You may have to do this a couple or three times to get it mostly cleared if you haven't done it before. I put a large piece of carboard underneath to catch the debris and it was nasty when I was done. Yes, sorry, should have been more specific Simple Green Pro HD (purple stuff). Link to comment Share on other sites More sharing options...
glang11082 Posted March 31, 2021 Share Posted March 31, 2021 Just now, glang11082 said: Great product by both cans as a kit. I use it often. Link to comment Share on other sites More sharing options...
Dennis H Posted March 31, 2021 Share Posted March 31, 2021 This is what was recommended to me by the HVAC guy. $10 bucks a can if you buy four from Amazon. It works great on the HVAC system but I found the Pro HD works best on the radiator. HVAC units are mostly dust and surface grime whereas radiators gather road dirt and greasy residue......Dennis 1 Link to comment Share on other sites More sharing options...
SkyKingII Posted April 24, 2021 Share Posted April 24, 2021 Hi Dennis,Thankx for sharing info on Pro HD...This annual project is cumming up and Amazon was kind enough to deliver through Prime account the gallon of HD..Was curious as to what mix ratio have you found works best on radiator? I have the rear rad in my 04 40'Diplomat PDQ. I am anxious to see how this works out! Thank's, Bruce Crocker 04 40' Diplomat PDQ Link to comment Share on other sites More sharing options...
Dennis H Posted April 25, 2021 Share Posted April 25, 2021 Mixing directions are on the label. I followed their instructions and was pleased with the results....Dennis Link to comment Share on other sites More sharing options...
SkyKingII Posted April 26, 2021 Share Posted April 26, 2021 Dennis,thanks for the reply,I did also read the label but was curious as to which mixture you found worked on your radiator? My reason for the question is usually with these chemicals the less you need is better(and cheaper) as this SP isn't cheap,don't want to "overkill the mix",to get the job done thats all! Did not mean to beat this to death was really not aware of this product(PRO-HD) previous to your comments,again thank's! Bruce Crocker 2004 Dip 40'PDQ Link to comment Share on other sites More sharing options...
