ktloah Posted July 17, 2021 Share Posted July 17, 2021 04 Dynasty, 400 ISL, Today while traveling in NC, the cruise control stopped working. Pushed SET again and it worked for less than a minute. Shutoff cruise and tried again to no avail. Now it won't engage at all but light on dash says it's on. Jake is off....anyone ever experience this before? Link to comment Share on other sites More sharing options...
cbr046 Posted July 17, 2021 Share Posted July 17, 2021 Any chance the ATC light is flashing? Just a hunch . . . . maybe barking up the wrong tree (turned out to be a clogging fuel filter / ISC engine). My cruise was downshifting the transmission, but cruise stayed engaged. Early symptom was a ATC light flashing. - bob Link to comment Share on other sites More sharing options...
Tim-AZ Posted July 17, 2021 Share Posted July 17, 2021 I would check and clean the contacts for your steering wheel system. If you have a slip ring in your steering wheel like I do that was my problem when the crews kept shutting off Link to comment Share on other sites More sharing options...
ktloah Posted July 18, 2021 Author Share Posted July 18, 2021 Ok thanks, I'll check it out Link to comment Share on other sites More sharing options...
Ivylog Posted July 18, 2021 Share Posted July 18, 2021 Check that all the functions of the Smart wheel work…some may not. If not, start with the plug at the base of the steering column…remove and clean. There is a Smart wheel troubleshooting procure using a blinking led on the controller in the FRB…takes two people. While looking at the controller, check for a burnt headlight plug. Link to comment Share on other sites More sharing options...
