LakeBob Posted January 24 Share Posted January 24 Trying to help neighbor in our RV park. Recently deceased husband, however she got her license and brought her 43 ft Dynasty down to Florida for the winter on her own. Upon arrival she plugged into our brand new park's Power center, 50 AMP service. She noticed right away there were issues, ( I dont know exactly what these were). Maintenance came, told her to plug into another pole and they would have this one "fixed". Her primary issues now are: 1. The electric locks on her bay doors are preventing the key lock from opening the bay doors. I've read that this can occur when the locks are overloaded for an extended period of time causing damage and "melting" them in place. They never used the electric locks previously, and never had the keypad programmed. We found the reset for the exterior keypad and tried to reset, however it would not respond to input. Any one familiar with this issue? Any easy way to get into these bays? The key will turn down into the lock position, however will not turn the lock cylinder to the unlocked position. Bay doors are locked on both sided of the effected bays. 2. Washing machine issue, wont drain any longer. I did not look at the brand, I know its a combo unit. 3. Electric side of Aqua hot will not turn on. Diesel side works ok. The park sent a tech out, he did a few random checks and told her to call Monaco and a locksmith.............. Thanks for any ideas suggestions, I'm trying to help her as I can. I My thoughts: 1. Electric door actuators are fried, need to drill a hole in the exterior lock to get to the rod to force open? 2. Moste likely a damaged board or motor on the washer? 3. Damaged board on the Aqua Hot? Is there any other resets? I'm not sure of her model yet. Any good suggestions for a Monaco repair facility or a knowledgeable mobile repair tech? We are in Palmetto FL, just southwest of Tampa Bay. Thanks All!! Link to comment Share on other sites More sharing options...
myrontruex Posted January 24 Share Posted January 24 If the washer is a Splendide, have her call the mfgr or I can attach some troubleshooting information if you would like. I would think a mobile rv tech versus someone the park sent out could address all of those issues quickly. All locks not working is very strange. Even if they were all melted inside for some reason and jamming things up I would think getting inside you may be able to crawl to the other locks and disassemble from inside versus damaging all of them. I know nothing of the aquahot system but there are some real experts here. Link to comment Share on other sites More sharing options...
Robert U Posted January 24 Share Posted January 24 It sounds like a possible bad neutral in campground power box. Too many things damaged. Bob U Link to comment Share on other sites More sharing options...
LakeBob Posted January 24 Author Share Posted January 24 36 minutes ago, myrontruex said: If the washer is a Splendide, have her call the mfgr or I can attach some troubleshooting information if you would like. I would think a mobile rv tech versus someone the park sent out could address all of those issues quickly. All locks not working is very strange. Even if they were all melted inside for some reason and jamming things up I would think getting inside you may be able to crawl to the other locks and disassemble from inside versus damaging all of them. I know nothing of the aquahot system but there are some real experts here. The fist mobile tech was worthless. We cannot acces the locked bays from either side. Hopefully we can find a good tech or an easy way to get into these latches, or both! Link to comment Share on other sites More sharing options...
Tom Cherry Posted January 24 Share Posted January 24 1 hour ago, LakeBob said: Trying to help neighbor in our RV park. Recently deceased husband, however she got her license and brought her 43 ft Dynasty down to Florida for the winter on her own. Upon arrival she plugged into our brand new park's Power center, 50 AMP service. She noticed right away there were issues, ( I dont know exactly what these were). Maintenance came, told her to plug into another pole and they would have this one "fixed". Her primary issues now are: 1. The electric locks on her bay doors are preventing the key lock from opening the bay doors. I've read that this can occur when the locks are overloaded for an extended period of time causing damage and "melting" them in place. They never used the electric locks previously, and never had the keypad programmed. We found the reset for the exterior keypad and tried to reset, however it would not respond to input. Any one familiar with this issue? Any easy way to get into these bays? The key will turn down into the lock position, however will not turn the lock cylinder to the unlocked position. Bay doors are locked on both sided of the effected bays. 2. Washing machine issue, wont drain any longer. I did not look at the brand, I know its a combo unit. 3. Electric side of Aqua hot will not turn on. Diesel side works ok. The park sent a tech out, he did a few random checks and told her to call Monaco and a locksmith.............. Thanks for any ideas suggestions, I'm trying to help her as I can. I My thoughts: 1. Electric door actuators are fried, need to drill a hole in the exterior lock to get to the rod to force open? 2. Moste likely a damaged board or motor on the washer? 3. Damaged board on the Aqua Hot? Is there any other resets? I'm not sure of her model yet. Any good suggestions for a Monaco repair facility or a knowledgeable mobile repair tech? We are in Palmetto FL, just southwest of Tampa Bay. Thanks All!! First….I would have her notify the park and tell them that they may be liable for damages resulting from a faulty pedestal. The electrical issues, assuming they were not present before are alarming…..in that…. Door Locks are 12 DC powered. There is no crossover,,other than the inverter circuit and charging. So a “voltage spike” as in a faulty pedestal may have damaged or caused a high 12 VDC. Now….the specifics…..if the door locks are Trimark (easy to identify from grab handle and the remotes or the control box COULD have been caused by a “short in the wiring”. We had a member with a similar issue many years ago. His system was a bit newer, but Trimark. He reported that he was “messing” around behind the dash and somehow got the Trimark control box in a funk and it sent out a prolonged pulse. There are two different styles of the locking solenoids. Monaco used the cheaper “short” ones and they burn up when an extended or constant pulse is sent out. He replaced these with the upgraded longer or heavy duty ones….that’s about as much as I know….but one does wonder….although the 50 amp service does not interface with the door locks. Next up is the washer. That IS a 120 VAC appliance. Agin, one has to wonder how the control board got messed up. Next is Aqua Hot. That is a 12 VDC system that uses a main control board for the boiler heating. I would suggest that you look at the AH panel. There is a small hole for something like a bent paper clip or a very thin wooden dowel or plastic pin to push in the “reset”. If there was LOW Battery voltage, then there will be a light. Reset it. The electric MAY be working as the indicator light on the switch could have burned out. Simple way to test….turn off diesel. Do the reset. Leave the electric switch on, even if no night. Then run off the hot water until Luke warm or cold comes out. Then wait an hour or two….open the same faucet and see if the water is hot again. IF so, all is well and indicator light is out. BUT you gotta wonder about all these gremlins and whether they have common DNA Link to comment Share on other sites More sharing options...
LakeBob Posted January 24 Author Share Posted January 24 (edited) UPDATE: The coach is a 2006 Executive Denali. Today I looked for the remote panel for the surge guard system, She has a Surge Guard 40250 switch mounted int the one bay that is open. No electric locks, they had been removed. I assume this switch also provides surge protection? The telephone wire for the remote is plugged into the switch, however I cannot find a remote display. The coach does have an Alladin system. I did find the section similar to my remote display listing Line voltages and amp draws, however I could not locate any fault codes as I can on mine. Is there a way to access fault codes using the Alladin system ? Thanks! Edited January 24 by LakeBob Corrected Surge Gurad Model Number Link to comment Share on other sites More sharing options...
LakeBob Posted January 24 Author Share Posted January 24 Additional Question: Regarding the Surge Guard 30250, Can you clear the fault codes displayed on a remote panel. My coach has 50 old faults logged, Would lilke to clear. Link to comment Share on other sites More sharing options...
Viper04 Posted January 25 Share Posted January 25 Suggest contacting, Don't laugh 😂 too much--Camping World located next to the villages, in Wildwood Florida It used to be Alliance Coach. They (Alliance aka now Camping World)until a few years ago, were the largest Monaco service center in the southern US. The facility has over 20 service bays for just class A"s, full wood fab shop and full service body and paint booth. Also, full on site hook ups while you're waiting to get a bay and a tech. Many of the factory trained Monaco techs are still employed there. Sometimes you just got to go where the mechanics with the grey hair are--lol. My contact there is: Dottie, in parts. She has been there at the dealership no matter who owned it,for over 20 years. She knows Monaco coaches from top to bottom and which mechanics that you'll want to work on your coach. At one time they swapped out so many Nocold units that they kept a supply of Samsung residential units in stock. They were high because they were a dealer but I had no complaints on the quality of the work, it was well done. Dottie will tell you flat out the older Monaco's beat the newer products hands down. here is Dottie's number 352-330-3837 They are in central/ north Florida area. Hope this info is of assistance. thx v/r 1 Link to comment Share on other sites More sharing options...
LakeBob Posted Friday at 04:50 PM Author Share Posted Friday at 04:50 PM On 1/24/2023 at 5:18 PM, LakeBob said: UPDATE: The coach is a 2006 Executive Denali. Today I looked for the remote panel for the surge guard system, She has a Surge Guard 40250 switch mounted int the one bay that is open. No electric locks, they had been removed. I assume this switch also provides surge protection? The telephone wire for the remote is plugged into the switch, however I cannot find a remote display. The coach does have an Alladin system. I did find the section similar to my remote display listing Line voltages and amp draws, however I could not locate any fault codes as I can on mine. Is there a way to access fault codes using the Alladin system ? Thanks! I am not familiar with the Aladdin system. I am able to read line voltages and amp usage from the Aladdin screen. Is there a way to read the fault codes from the Adladdin screen? The coach does not have the remote read out that my 2009 has. Thanks!!! Bob Link to comment Share on other sites More sharing options...
tmw188 Posted Saturday at 01:50 PM Share Posted Saturday at 01:50 PM I like that lead on Dottie👍 Link to comment Share on other sites More sharing options...
