azlein Posted March 9 Share Posted March 9 2005 Monaco Windsor Problem - RV pulls to the left Tried – Had front end alignment done (twice) and both time no improvement. Tires are 1.5 years old. Help – I am in Phoenix and I’m looking for a place where I can have a complete check done on suspension to solve the pull issues. Any suggestions? Link to comment Share on other sites More sharing options...
JDCrow Posted March 9 Share Posted March 9 Did you have them switch the front tires, one side to the other to rule out a bad tire? It happens. Pulls left all the time? Link to comment Share on other sites More sharing options...
klcdenver Posted March 9 Share Posted March 9 Do you have a safety steering device added on your rig? If so it probably needs to be re-centered. 1 Link to comment Share on other sites More sharing options...
Corkman Posted March 9 Share Posted March 9 You wanna make sure your RV is level going down the road. For example mine has the auto leveling airbag system. When it is not working properly it’ll pull in one direction or the other depending on which which side is lower 1 Link to comment Share on other sites More sharing options...
JDCrow Posted March 9 Share Posted March 9 11 minutes ago, Corkman said: You wanna make sure your RV is level going down the road. For example mine has the auto leveling airbag system. When it is not working properly it’ll pull in one direction or the other depending on which which side is lower 11 minutes ago, klcdenver said: Do you have a safety steering device added on your rig? If so it probably needs to be re-centered. Nice catch, both is you Link to comment Share on other sites More sharing options...
azlein Posted March 9 Author Share Posted March 9 First shop said they switched the tires, not confident they actually did so will give that a try. I don't have any safety steering installed. As for the system being level, when I measure from the ground to the top of the wheel well on both sides they are equal. Is there a better way to test this? Link to comment Share on other sites More sharing options...
azlein Posted March 9 Author Share Posted March 9 PS Yes pulls left all the time. Link to comment Share on other sites More sharing options...
Ivan K Posted March 10 Share Posted March 10 1 hour ago, azlein said: As for the system being level, when I measure from the ground to the top of the wheel well on both sides they are equal. Is there a better way to test this? Measure between top and bottom airbag mounting plates. Link to comment Share on other sites More sharing options...
Chargerman Posted March 10 Share Posted March 10 How many mile are on the Coach? Could possibly be worn components of the front H frame assembly. Sorry I don’t know of a qualified facility in your area. Link to comment Share on other sites More sharing options...
JDCrow Posted March 10 Share Posted March 10 James is in the Phoenix area and might know a good shop AZRVEXPERT@GMAIL.COM Link to comment Share on other sites More sharing options...
Jdw12345 Posted March 10 Share Posted March 10 Bad wheel bearings? Link to comment Share on other sites More sharing options...
Corkman Posted March 10 Share Posted March 10 This pic shows where to measure the ride height. Link to comment Share on other sites More sharing options...
JDCrow Posted March 10 Share Posted March 10 14 minutes ago, Jdw12345 said: Bad wheel bearings? Yeah or brake grabbing? I carry a laser thermometer and check every stop for equal heat on wheels/tires, drums Link to comment Share on other sites More sharing options...
Ivylog Posted March 10 Share Posted March 10 Measuring to the wheel well is close enough and not a wheel bearing but could be a dragging brake BUT it would heat up enough to smell. I had a pulling issue and rotating front tires helped. Link to comment Share on other sites More sharing options...
David White Posted March 10 Share Posted March 10 (edited) Azlein, you should check the ride height, but it can’t be adjusted as shown above. The Firestone system requires the adjustment to be made with a special computer program, with laptop connected to the Firestone ecu. The measuring underneath is the same points, and yours should be 9 3/4”. Edited March 10 by David White Link to comment Share on other sites More sharing options...
DavidL Posted March 10 Share Posted March 10 have a 4 wheel alignment done. Possibly the rear axle is not at right angle to the chassis. So then the RV "dog tails". Link to comment Share on other sites More sharing options...
azlein Posted March 11 Author Share Posted March 11 Love this site, so much help 1) Thanks for the email JDCrow, I'll contact him 2) I have never smelled anything like burning brakes but have never measured it with a temp sensor (good idea) 3) David - do you have or know where to get the software for the adjustments? 4) Only 45k miles on the coach. Have not been excited about removing tires to check but guess it is time to adventure down that road. Link to comment Share on other sites More sharing options...
Grampy OG Posted March 29 Share Posted March 29 Just tossing this in. My '03 Executive has always pulled to the right. Did all the normal things, alignment, tires, air pressure changes,etc. Finally an alignment shop told me that my rear axle is slightly off and because Roadmaster welded it on I am basically out of luck in less I want to spend huge money to have the axle reseated. The slightly off axle causes the backend to push so no amount of front end correction will remove the push. Bummer. I just deal with it These are the people that gave me the wonderful news: https://www.yellowpages.com/glendale-az/mip/arizona-laser-alignment-7344516 I hope you have better luck. Link to comment Share on other sites More sharing options...
Ivan K Posted March 29 Share Posted March 29 Have you seen this guy fixing his? https://youtu.be/FrQR7ERBtOw Link to comment Share on other sites More sharing options...
Grampy OG Posted March 31 Share Posted March 31 On 3/29/2022 at 1:19 PM, Ivan K said: Have you seen this guy fixing his? https://youtu.be/FrQR7ERBtOw That is exactly what was described to me. However finding "THAT GUY" meaning a shop that would even care to tackle the job will probably be close to impossible. The tolerances seem amazing in themselves. At least this proved to me that the alignment shop was just paying me lip service. It is a true problem with the chassis. Thanks for the great video find, Ken Link to comment Share on other sites More sharing options...
willbo777 Posted March 31 Share Posted March 31 2 hours ago, Grampy OG said: That is exactly what was described to me. However finding "THAT GUY" meaning a shop that would even care to tackle the job will probably be close to impossible. The tolerances seem amazing in themselves. At least this proved to me that the alignment shop was just paying me lip service. It is a true problem with the chassis. Thanks for the great video find, Ken Josam's in Orlando does it all the time. They will align the drive and the tag, it is one of their specialties. Link to comment Share on other sites More sharing options...
Ivan K Posted March 31 Share Posted March 31 That kind of work should not be a problem but calculating the correction is a different story for me. Link to comment Share on other sites More sharing options...
JDCrow Posted March 31 Share Posted March 31 He’s Amazing. Built his own Watts links too, and did his talin plates. I drool when I see his shop Link to comment Share on other sites More sharing options...
Chargerman Posted March 31 Share Posted March 31 On 3/29/2022 at 4:19 PM, Ivan K said: Have you seen this guy fixing his? https://youtu.be/FrQR7ERBtOw Mike is one of my hero’s. Such a talented guy. It’s well worth checking out his thread on IRV2. Have you seen his LS motor swap on his Jeep? So nice. I tried to get him over to this forum but he said he already follows too many. Link to comment Share on other sites More sharing options...
Grampy OG Posted April 5 Share Posted April 5 (edited) On 3/31/2022 at 9:49 AM, willbo777 said: Josam's in Orlando does it all the time. They will align the drive and the tag, it is one of their specialties. Great info there. I am assuming though with travel from Phoenix to Orlando and back and the actual alignment fees it would probably easily be well over 5k for the fix. I am afraid that dumping that amount of money into the coach is just not a wise decision for me at this time. Anybody aware of a Phonix area shop that might do this type of work? Edited April 5 by Grampy OG correct mistake Link to comment Share on other sites More sharing options...
