LakeBob Posted February 19 Share Posted February 19 New 09 45' Dynasty owner. I would like to pull the auxiliary compressor and I dont have hydraulic jacks on the coach. I'm thinking 10 ton jack stands and maybe a bottle jack to get a couple extra inches higher than the travel position. How do you get under your coach? Interested in safe' practical ideas. Thanks! Link to comment Share on other sites More sharing options...
Tom Whitlow Posted February 19 Share Posted February 19 I have the same question. My 09 Dynasty also doesn't have hydraulic jacks. Link to comment Share on other sites More sharing options...
Old Dog Posted February 19 Share Posted February 19 I just use the manual mode on air bags and crack it up then crawl under. Can a air bag blow out and crush me, maybe. It's what I believe to be a low rusk situation. Don't use my advise, do your own research on the pros/cons and make your own decision. I call tell I've been under there a lot and I'm still with us. 1 Link to comment Share on other sites More sharing options...
directorsusa Posted February 19 Share Posted February 19 (edited) $120 12 ton jack stands at harbor freight. Nice piece of mind knowing you dont have to hurry before something fails. Placed under frame rails - not under coach body or storage compartments or axles https://www.harborfreight.com/automotive/jacks-jack-stands/jack-stands/12-ton-jack-stands-34924.html Edited February 19 by directorsusa 1 Link to comment Share on other sites More sharing options...
jacwjames Posted February 19 Share Posted February 19 I had to work on my air system last year and made 6 sets of ramps to raise the coach 6". I could then drop air completely and not have the jacks down and still be able to crawl under the coach and in some cases sit up and work on some of the fittings. I used 2X10" boards cut to 48", 42". 36", 30" stacked and screwed together. I put a stop block on the end of the rear ramps so I wouldn't back off them. I was surprised at how easy I was able to back up on the ramps. I now just have them leaning up against the wall in my garage for use in the future. 1 Link to comment Share on other sites More sharing options...
LakeBob Posted February 19 Author Share Posted February 19 I was thinking about building some ramps, what I did as a very young man, working on my first cars…..,😀 Link to comment Share on other sites More sharing options...
Bob Schmeckpeper Posted February 19 Share Posted February 19 Another old school way of doing it is to dig a pit if you have the property to do it. Link to comment Share on other sites More sharing options...
myrontruex Posted February 19 Share Posted February 19 It is amazing how fast the air can be let out and if you think you can get out before being crushed you are wrong. Even if you have the hydraulic jacks lifting the RV there are so many things that can take it into the emergency retract mode and it can drop like a rock. Just for fun when you are clear of everything for those that have the leveling jacks, put your foot on the brake and put the transmission in D and take the parking brake off. I can tell you from experience that a crazy thing like water getting to the Transmission Control Module can activate the same emergency situation. If in doubt, use jack stands. Even with jack stands you are at risk, says my trip to the emergency room to be checked out after my little Ranger pickup came down off the jack and jack stand and pinned me under the truck. I was only bruised but gained a valuable lesson. Stuff happens. Be careful. 1 Link to comment Share on other sites More sharing options...
Ivylog Posted February 19 Share Posted February 19 Scrape lumber screwed and glued. Link to comment Share on other sites More sharing options...
Hypoxia Posted February 19 Share Posted February 19 I use pieces of pipe in the suspension. Lift the coach as high as the air will go and put these in. 1 Link to comment Share on other sites More sharing options...
RoadTripper2084 Posted February 19 Share Posted February 19 I do the same, inspired by this post It works really well, is easy to do, and there's no problem carrying the 4 pieces of pipe with me to use whenever I may need it, doesn't rely on having perfectly level ground either. Recommended. Link to comment Share on other sites More sharing options...
Flyinhy Posted February 19 Share Posted February 19 I use blocks of wood. Raise my bags all the way up and stack as much wood under it as I can. I've had my suspension drop while I was under it greasing the slack adjusters and linkage ....scared the crap out if me. Luckily I was near the front and the generator was out at the time. 1 Link to comment Share on other sites More sharing options...
jacwjames Posted February 19 Share Posted February 19 My problem is that unless I lift the tires and axle I can't get my chest under the axle. I have to crawl out from one side, out around the tire, and then back in. Using the ramps raises the whole coach and give me plenty of room. Makes it much easier to do a service on the coach. 1 Link to comment Share on other sites More sharing options...
vito.a Posted February 19 Share Posted February 19 Great suggestions here. Just remember that jack stands are rated in pairs. So 10 ton jack stands only hold 5 tons each. That's marginal on the rear. Link to comment Share on other sites More sharing options...
DavidL Posted February 19 Share Posted February 19 (edited) wood Ramps AND timbers, rated jack stands or the proper pipe under the chassis. Do NOT get underneath unless it's just for a second to get a jack stand underneath without having the chassis supported. those that do are completely inexperienced and super lucky. Crap happens ALL THE TIME the more you do this stuff, the more you know that. I moved the RV because a tree was looking sickly. I brought the backhoe up to it and TOUCHED it with the bucket. The 100ft tree cracked and fell towards me, knocking my glasses off my face (that's how close). Pinned me into the seat and bent the seat back unto a U. Crap happens. Be careful. Edited February 19 by DavidL 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted February 19 Share Posted February 19 I was told to put any support under the vertical parts of the chassis not the horizonal sections. I found that raising just the rear makes it impossible to grease the u-joints. Gary 05 AMB DST 1 Link to comment Share on other sites More sharing options...
Ivan K Posted February 19 Share Posted February 19 It helps me to raise one set of drive wheels so that the driveshaft can be rotated to grease the ujoints. 1 Link to comment Share on other sites More sharing options...
Gary 05 AMB DST Posted February 19 Share Posted February 19 Thanks Ivan, I no longer can fit under the MH. I think the suspension is starting to sag after 16 years. LOL! Gary 05 AMB DST 1 Link to comment Share on other sites More sharing options...
Ivan K Posted February 19 Share Posted February 19 18 minutes ago, Gary 05 AMB DST said: Thanks Ivan, I no longer can fit under the MH. I think the suspension is starting to sag after 16 years. LOL! Gary 05 AMB DST That's my excuse also! It is getting tight 🤣 Link to comment Share on other sites More sharing options...
myrontruex Posted February 19 Share Posted February 19 (edited) It is amazing how fast the air can be let out and if you think you can get out before being crushed you are wrong. Even if you have the hydraulic jacks lifting the RV there are so many things that can take it into the emergency retract mode and it can drop like a rock. Just for fun when you are clear of everything for those that have the leveling jacks, put your foot on the brake and put the transmission in D and take the parking brake off. I can tell you from experience that a crazy thing like water getting to the Transmission Control Module can activate the same emergency situation. If in doubt, use jack stands. Even with jack stands you are at risk, says my trip to the emergency room to be checked out after my little Ranger pickup came down off the jack and jack stand and pinned me under the truck. I was only bruised but gained a valuable lesson. Stuff happens. Be careful. Just got out from under mine a few minutes ago. Used jack stands of course. I really like the pipe thing and a welder could put some tabs on it or cut it so they actually cannot kick off sideways. One of my Bilstein shocks was leaky and it took six months to get a replacement. Little do they know the old one is going to get warranted because of the leak. Guess I will have a spare. Suckers went up a bunch of course. Edited February 19 by myrontruex Link to comment Share on other sites More sharing options...
dl_racing427 Posted February 20 Share Posted February 20 13 hours ago, directorsusa said: $120 12 ton jack stands at harbor freight. Nice piece of mind knowing you dont have to hurry before something fails. Placed under frame rails - not under coach body or storage compartments or axles https://www.harborfreight.com/automotive/jacks-jack-stands/jack-stands/12-ton-jack-stands-34924.html MUCH cheaper than a hospital bill or a funeral. 😎 10 hours ago, myrontruex said: It is amazing how fast the air can be let out and if you think you can get out before being crushed you are wrong. Even if you have the hydraulic jacks lifting the RV there are so many things that can take it into the emergency retract mode and it can drop like a rock. Just for fun when you are clear of everything for those that have the leveling jacks, put your foot on the brake and put the transmission in D and take the parking brake off. I can tell you from experience that a crazy thing like water getting to the Transmission Control Module can activate the same emergency situation. If in doubt, use jack stands. Even with jack stands you are at risk, says my trip to the emergency room to be checked out after my little Ranger pickup came down off the jack and jack stand and pinned me under the truck. I was only bruised but gained a valuable lesson. Stuff happens. Be careful. All that, plus if an air or hydraulic line fails, it will drop even faster. Glad you survived your mishap. Many people don't get as second chance. 🙏 7 hours ago, vito.a said: Great suggestions here. Just remember that jack stands are rated in pairs. So 10 ton jack stands only hold 5 tons each. That's marginal on the rear. True for many sets. The ones listed above are rated each, however. Link to comment Share on other sites More sharing options...
